Go Back   SRT Forums - SRT4, SRT6, SRT8, SRT10 & Dodge Forum > Supporting Vendors > Coolingmist
Old 05-13-2008, 11:36 PM   #1 (permalink)
gump1114's Avatar
Member Number: 28766
Default need a little help
ok so today i picked up a used cooling mist w/a injection kit from a friend. i just need to find out what else i need to make the kit work for my car. i am pretty sure it is your 150psi or stage 1 kit w/ tank. i will list here what i have and would really appreciate if someone else can list what i need. i can later post pictures if need be.
i have:
pump
tank
lines connecting tank to pump and pump to injector
injector
boost switch
there are a couple of wires coming out of the pump that run to a connector but i dont have any other wires. whatever else goes with the kit i might can pick up from my friend but they where not sure whatelse goes with it. the kit is coming off of one of their race cars (mustangs) that hasnt run in some time so everything should still be with it.
also i need to know if there is any way to look at the injector and tell what size it is, if not i would assume it would be a good idea to purchase a new one so that i know what i am working with. if that is the case what is a good size to go with a big turbo srt4?
295 HP & 333 TQ - tuned by me 13.076 @ 110.14
gump1114 is offline   Reply With Quote
Old 05-17-2008, 07:14 AM   #2 (permalink)
Coolingmist's Avatar
Member Number: 14112
Trader Rating: (51)
its difficult for me to see what you are or are not missing. You seem to have the major things, other things such as electrical wiring you can pick up locally.
If I were you I would learn the concept of how the system goes together, from there you will know exactly what you need.
Look at our instructions on our website under the installation menu, that may help.
If your nozzle has no effect you may need a larger one, if it bogs your car you may need a smaller. No need to rush out and buy a new one until you install it and see.
CM
Old 05-18-2008, 04:24 PM   #3 (permalink)
gump1114's Avatar
ok thanks. seems like i'm needing the relay and the wiring to go with that to power everything and make it work. i'm going to see if i can snatch that off their car sometime this week so that i can go ahead and get this stuff thrown on the car.
» Search Used Cars
Page generated in 0.17201 seconds with 11 queries
