Go Back   SRT Forums - SRT4, SRT6, SRT8, SRT10 & Dodge Forum > Supporting Vendors > Coolingmist
Old 04-17-2008, 08:57 PM   #1 (permalink)
ck_srt4's Avatar
Member Number: 23711
Trader Rating: (21)
Default led hook up
i have your trunkmount kit and was wondering if you could tell me how to hook up the led for the low level indicator and a led for when the system is activated.
50 trim, kinetic fmic, SB clutch, afc neo, hexalogger,725cc injectors, walbro 255, return line, bwoody solid mounts, h brace & trac bars, and radiator shroud, bdj's 3" intake, agp hardpipes w/tial Q, hp racing 3" tbe, mopar sts, prosport 30/30 boost oil pres & fuel pres, bc coilovers, FBM race combo, b&g reflash
ck_srt4 is offline   Reply With Quote
Old 04-18-2008, 06:44 AM   #2 (permalink)
Coolingmist's Avatar
Member Number: 14112
Trader Rating: (51)
give one end of your LED 12V, hook the other to 1 wire from the low level. Ground the other wire.
For the system activation, give one end of the led ground, connect the other to the NO port on the boost switch.
CM
Old 04-18-2008, 05:20 PM   #3 (permalink)
ck_srt4's Avatar
Trader Rating: (21)
thank you. will be installing this weekend
Page generated in 0.12861 seconds with 11 queries
