Quote: Originally Posted by Shuggy
What is all needed in order for the kits to be 100% safe. is a wideband a needed? is it only completely safe if only 100% water is used? Should I get a scan gauge to monitor knock. I plan on installing the kit on a mildly modded stg 0 and will only be boosting around 18psi.
100% safe means different things to different people. If you just buy our kit and put it on your car and do no tuning its safe. you will gain maybe 18-20 WHP.
if you tune your ecu/engine and put our kit on, then you need to look at wideband, etc.
I think many people will tell you it will make your SRT-4 come alive.
let me know if you have some more questions.
CM
