Go Back   SRT Forums - SRT4, SRT6, SRT8, SRT10 & Dodge Forum > Supporting Vendors > Coolingmist
Old 05-12-2007, 10:00 AM   #1 (permalink)
Gmanigio's Avatar
Member Number: 7336
Trader Rating: (40)
Default Which external nozzle size for my setup?
I will be installing stage 3 turbo next month and want an external nozzle. Im llooking for 320-350 in the near future and 380hp by fall.
What size nozzle should I buy from you guys?
Also, What if the nozzle filter gets dirty/clogged, is there a way to clean it??
Also, to UP the pressure on a shurflow pump, I turn clockwise? And what size hex key?
edit: I see that your standard kit doesnt have a relay like my DO kit. Is the realy really necessary? How would the pump know when to turn on without a relay? Sorry if its a dumb question.
Thanks
FS: HID Fogs Kit - 6000K & 3000K(Yellow) - PM Me
Performance Mods: AGP S3D 48lb - Returnline - Mopar Stage 2 w/o Toys - DW 650cc - TurboXS HPMBC - Maddog STS - MaxxFab 3" DP w/o Cat Magnaflow Muffler - AIS Intercooler - ED LPP - ED UPP w/ HKS BOV - Injen Intake - NGK V-Powers @ .032 - FBM Ported Intake Mani/Spacer - DCR 55mm Throttle Body - DCR Oil Mod - Devils Own MethInjection, M5 - DTEC - AEM UEGO
385HP and 385TQ
Gmanigio is offline   Reply With Quote
Old 05-12-2007, 10:43 AM   #2 (permalink)
Member Number: 8193
With a S3R set-up I used a M5 equivalant. But most have been using dual M5's and having good results. With a modded S3R I now use a M5 and A M2 in a dual set up.
The S-HSV
Very bottom of this thread is good way to take'em' apart... The S-HSV
If your getting S3R I like the varicool kit, or the S-HSV kit. But to answer the question. Turn in or clockwise increases the shut off pressure. To turn it out or counter clockwise decreases.
I belive the standard kit uses a hobbs switch or pressure switch to sence boost - adjustable.
The varicool kit uses the controler. The S-HSV will use the controler and a pressure switch.
Thanks
I hope I got all this right...
I'm sure coolingmist will add in if not. Humbly this is just from experiance with the kits I've used.
Peace
Old 05-12-2007, 11:37 AM   #3 (permalink)
Coolingmist's Avatar
Member Number: 14112
Trader Rating: (51)
The only thing I would ad is that I dont recommend to try to adjust the pump. The switch on the pump is very easy to mess up. We have had more than one pump that when we tried to adjust it, perminently messed up.
CM.
Page generated in 0.18996 seconds with 11 queries
