Go Back   SRT Forums - SRT4, SRT6, SRT8, SRT10 & Dodge Forum > Supporting Vendor Forums > Coolingmist
Old 10-27-2006, 10:23 AM   #1 (permalink)
OTownSRT4's Avatar
Member Number: 38911
Trader Rating: (13)
Cool Custom Coolingmist Direct Port Review and Pics
Dave I posted this same thing in the Glacial Graphics section but i thought that you might like it here also. If not feel free to delete the thread.
Well after 6 months of dust collection I've finally got the kit completely installed, and it is exactly what i was hoping it would be. This is a Coolingmist Direct Port W/I, Vari-Cool Controller, Trunk Tank w/Stainless upgrade. Damn thats a mouthful. After spending a good deal of time trying to come up with an installation plan we decided to do it a little custom, when I say we i mean Frank @ XtremeBoost . First off I don't want to give the impression that anything that came supplied with the kit was inferior in any way, everything seemed to be of very high quality and construction we just added our own twist. Without further ado here's a pic.........
The kit came supplied with a distribution block consisting of several brass fittings screwed together. The piece itself is not very appealing to the eyes and there was really no clear cut place to mount it so Frank decided to use a piece of billet fuel rail stock as a distribution manifold along with a nice bracket to mount it to the ignition coil......
I'm not sure if the kit was intended to have the stainless lines running from the distribution to the injectors but i felt it was necessary to do so from an appearance standpoint. Included in the kit were some "plastic" hoses and brass fittings, we opted to go with the fittings you see from purely a bling standpoint.
The next challenge was deciding how and where the injectors were going to be mounted. We were determined to get the injector lined up evenly across the runners of the intake manifold for proper distribution, unfortunately with the way that our upper radiator hose runs off the thermostat housing and the location of the MAP sensor we didn't have many options. I did consider mounting them on the underside of the IM but that wasn't an idea i was happy about. The decision was made to make a hard upper rad pipe with a different angle coming off the neck of the housing, but it still wouldn't have made enough room to get them even so Frank took the thermostat housing of and cut the neck clear off turned it a little clockwise and welded it back together. This created enough room to get the injectors straight across above the Map sensor and wires.
Update: New S-HSV mounted
I know it's not easy to make out the injectors, the problem is that when i sent the IM and injectors to be coated i wanted the IM black and injectors powder chrome but he did everything black so the kinda blend in but you get the idea. Frank is still going to be making the upper hard rad pipe and that will get coated black along with the thermostat housing, and redoing the injectors so they standout from the manifold.
I decided to mount the controller in the glove compartment for the time being I may decide to change that down the line but i wanted it out of the way and no wires showing.
(the car has been vacuumed since this pic )
And lastly the tank..........
The tank and pump combo design is nice and all but there really is no way/where to mount it out of the way so there it is. This may get changed down the road also.
Over all between the kit, installation, coating and custom stuff I've got about $1,000+ into this system. I know, i know a little excessive but I have this disease that doesn't allow me to go half way, I always find myself doing a little extra. And once i get the new turbo and all the other goodies if figure this could save me several thousand $ on a potential engine rebuild (until i decide to do it anyway )
I played around with the system some last night and with straight water i felt a distinct difference in the way the car reacted when going WOT. I don't want to sound like a retard describing the way my car sounded/felt so I'll just leave it at "the power came on much more linear". I didn't expect this to make to much of a performance difference now, like i said it is more in anticipation of the big turbo and etc..
Like i said I don't want anyone to think the changes that were made are because this kit is inferior in anyway.
Thanks to Glacius for carrying the kit, Dave at Coolingmist for a quality system, and Frank at XtremeBoost for the creativity and ingenuity behind this installation. I'm sure i left a some stuff out so LMK if you all have any questions and thanks for reading.
OTownSRT4 is offline   Reply With Quote
Old 10-27-2006, 11:02 AM   #2 (permalink)
Coolingmist's Avatar
Member Number: 14112
Trader Rating: (64)
Delete it? Are you kidding? I have been following the thread in Jeffs forum and frankly I am so impressed with the installation.
I take no offense for you changing the distribution block. As far as upgrading to our stainless line and connectors thats a great choice.
Again, my hat goes off to you, its really a great install and looks fantastic.
David
Old 10-27-2006, 11:45 AM   #3 (permalink)
OTownSRT4's Avatar
Trader Rating: (13)
David
Thanks Dave
Old 10-27-2006, 06:37 PM   #4 (permalink)
Member Number: 4000
WOW!!!I guess I know what I'll be asking frank for next time I'm at his shop That is a clean install and that piece by the wires man is that nice.Sweet man,are you thinking about going big turbo as well?Once frank lets me know I'll be dropping my car off at xtremeboost to get my engine and turbo kit done on another SRT I just picked up.
Steve
srtcrazy is offline   Reply With Quote
Old 10-27-2006, 08:37 PM   #5 (permalink)
can't stop spinning's Avatar
Member Number: 9183
I just ordered mine. Not that it'll look as pimp as yours otown, but I figure it's worth the money to help save my stock internal engine
100% stock engine, stock head, cams, blah blah blah
1st srt in Canada to get kicked off the track
can't stop spinning is offline   Reply With Quote
Old 10-27-2006, 11:07 PM   #6 (permalink)
XtremeBoost's Avatar
Member Number: 3584
Steve
I just noticed this other thread. Sup man , we're still VERY backed up with work so we're still looking at around 2 months before you can drop your car off . I just checked my E-mails and saw your e-mails , I'm going as fast as I can man trust I still have you in mind . Also you may wanna look into one of these kits for you car as well
Frank
XtremeBoost is offline   Reply With Quote
Old 10-29-2006, 07:29 AM   #7 (permalink)
OTownSRT4's Avatar
Trader Rating: (13)
Steve
Frank
Yea, Franks my slave bitch, back off
Old 10-29-2006, 10:00 AM   #8 (permalink)
Member Number: 3584
Steve
Frank
This guy is even whiter than you Steve and he "knows" people that can get me deported so when things need to get done to his car --they get DONE !!!!!! His white powers are far too strong and his cuban mind control is powerful !!!!
Frank
Old 10-29-2006, 03:28 PM   #9 (permalink)
OTownSRT4's Avatar
Trader Rating: (13)
Old 10-30-2006, 04:06 PM   #10 (permalink)
Glacius's Avatar
Member Number: 3149
Trader Rating: (63)
rotflol @ deportation rights
Glacius is offline   Reply With Quote
Old 02-20-2007, 01:24 PM   #11 (permalink)
OTownSRT4's Avatar
Trader Rating: (13)
Bump for a new trunk pic. I finally cut down the tie down posts, sanded/painted the strap. Oh yea and I picked up 5 gal. of Meth today
Old 02-20-2007, 02:23 PM   #12 (permalink)
Member Number: 17858
Very nice.
Grifter is offline   Reply With Quote
Old 03-19-2007, 05:05 PM   #13 (permalink)
Trader Rating: (64)
Here is a pic of our Direct port kit. We just updated the kit slightly to make it the easiest direct port kit to install. New to this version is our manifold. Its a quick disconnect manifold that is on a swivel so you can move either branch to different directions.
The nickel plated checkvalve is at the pump already connected and so is the manifold. Because of this design there is no need to mount the checkvalve and all the tees in the engine bay. Just route the provided hose through to the engine bay. In otherwords, there is NOTHING to mount in this kit other than the injectors. 60 feet of hose is provided.
Old 03-19-2007, 05:18 PM   #14 (permalink)
OTownSRT4's Avatar
Trader Rating: (13)
Definitely an interesting redesign David. I can see how this would increase the ease of installation
Old 07-15-2007, 07:35 PM   #15 (permalink)
OTownSRT4's Avatar
Trader Rating: (13)
Origional post updated
Page generated in 0.25335 seconds with 13 queries
