checkvalve location issues?
not a complaint, just a question. is anyone else having issues having the checkvalve with it placed all the way back in the trunk? I have tuned the controler on the dyno and it works perfict (on at 7psi, full at 14pst. center on 5, 60/40 mix). the issue im having: if I havent recently (AKA, last 3 mins) done a pull with it running, I have to "prime" the system. garenteed, the first pull I do every time I leave a parking lot or wherever its gonna drop HOM. from that pull it will hold it all night. well, till I either drive normal or shut it off. Im not getting any leakdown, I can hold a full tank for a month. I think the lines running from the injectors to the tank are flexing under boost/vac. shy of spending another $60 or whatever for 2 more checkvalves and placing them up by the injectors, any thoughts on how to correct this?
