Go Back   SRT Forums - SRT4, SRT6, SRT8, SRT10 & Dodge Forum > Supporting Vendor Forums > Rage Technologies
Old 04-29-2008, 12:58 PM   #31 (permalink)
NWNeonMatt's Avatar
Member Number: 6649
Quote: Originally Posted by tavenger5 View Post
How new is your clutch? Is the pressure plate torqued properly to the flywheel? It's odd to have the fingers of the pressure plate out that far.
It's an OEM modular clutch with 15k on it per the guy I got the trans from. It's possible the person who wrecked the car might have nuked the clutch in 15k i suppose, but seems unlikely. No torque values for me to worry about.
Not that it matters at the moment because of course i now have to pull the clutch and flexplate... turns out I should have realized the dust shields are incompatible between the older 2.4 and the SRT4 trans. Guess i'm about a week out between getting the part ordered and getting it back together.
-Matt
99 Neon ACR; Awaiting Resurrection.
05 Elise; WTF was I thinking?
NWNeonMatt is offline   Reply With Quote
Old 04-30-2008, 05:45 PM   #32 (permalink)
NemoFoss's Avatar
Member Number: 4163
Trader Rating: (71)
Quote: Originally Posted by NWNeonMatt View Post
Bearing moved, not so much collapsed as repositioned itself. Bought me an eighth or so. Without a shim i'm still .120 preloaded. Acceptable? Well over the .020 max indicated before.
Did you trim the torx screws to clear the body of the HTob? Do that and you'll get to where you need to be..
NemoFoss is offline   Reply With Quote
Old 05-19-2008, 03:32 AM   #33 (permalink)
NWNeonMatt's Avatar
Member Number: 6649
So i'm still waiting on parts (next up, proper sized flexplate!), but i found my extra room I needed.
Turns out that the SRT dust shield is exactly the extra thickness I was preloaded before. It's double the thickness of the earlier piece that was bolted on my motor, and gets me right in the ballpark. The early piece is still bolted to the motor, note how much thicker the new piece is.
Old 08-30-2008, 11:35 PM   #34 (permalink)
Member Number: 26992
Default ok need some help here nemo
ok so if i buy this kit, is there anyone you guys recommend in CA that can do this for me, about 6 month ago i could have done it but not anymore, i was a ASE tech, but due to a motorcycle accedent and a broken back i can no longer wench, so i definatly need this, but being a tech make me nervious giving my car to others to be repaired...so anyone you guys can recommend?
jdh30292 is offline   Reply With Quote
Old 09-02-2008, 02:10 PM   #35 (permalink)
quicky4JR.'s Avatar
Member Number: 43042
Trader Rating: (55)
we no longer sell these
Quote: Originally Posted by darrell cox View Post
Far better than stock but not as good as Nemos!
Leaders not followers! Paving the way and making it easy for everyone else!
(954)-915-0016
Davie,FL
Dyno tuning, installs, and custom builds
quicky4JR. is offline   Reply With Quote
Old 09-17-2008, 01:24 AM   #36 (permalink)
JesseL's Avatar
Member Number: 51882
For the rest of the people that have these in their cars... I ask... wearily... why?
JesseL is offline   Reply With Quote
Old 09-22-2008, 07:24 AM   #37 (permalink)
tgspeedracer's Avatar
Member Number: 25328
ya x2 why?
Best ET 11.41
Best MPH 131
@5860ft elevation
Peak whp 567
Peak tq 607
DSP Tunned by Nick Chestnut with "Unique Solutions Tuning"
tgspeedracer is offline   Reply With Quote
Old 09-23-2008, 10:50 AM   #38 (permalink)
fade's Avatar
Member Number: 27861
Well, since the first shim is .100 I removed one and it feels much better.
As for seal failures....what surface finish did you use on the sealing surface? What kind of tolerances, in the seal area, were used between the machined parts? I'm a mech designer and many of the parts I design require sealing surfaces that HAVE to be as perfect as poss. Losing a $200,000 tool due to seal failure isn't an option here.
'05 Silver SRT
Mods: GT3076R and stuff
fade is offline   Reply With Quote
Old 10-08-2008, 07:54 AM   #39 (permalink)
srt4Rob's Avatar
Member Number: 34154
Trader Rating: (44)
so why isnt this sold again ?
35r... fully built .. Aem Ems ... race gas and 30+ psi
SOLD
srt4Rob is offline   Reply With Quote
Old 10-17-2008, 08:24 PM   #40 (permalink)
JesseL's Avatar
They never said...........
Old 12-28-2008, 11:35 PM   #41 (permalink)
GreaseMonkey69's Avatar
Member Number: 43017
Trader Rating: (23)
hey neimo or quicky4JR i have a few questions for the rage HTOB. it has been working for 10K just fine. well my DCR PS2 clutch went out on me. here is a pic.
now the Throw out bearing looks ok. there is some wear on the tob surface from the pressure plate,but the question is about this ring that goes around the throw out bearing. see the circled area? the ring has a crack on it and when i removed the P.O.S clutch that ring was kinda hanging there. is that ring suppose to have a small break in it to install and remove or no? and if not is there a way i can get that ring from you? does the bearing look good? i can take a better pic if you want. also the ACTclutch/flywheel package is a sprung 6 puck with the flywheel right? im tired of modular the dcr one was my 3rd one on this car. 1 was a bad tob fork messed it up and this last one was the clutch kinda came apart.
GreaseMonkey69 is offline   Reply With Quote
Old 06-12-2009, 12:05 PM   #42 (permalink)
coloRODan_SRT-4's Avatar
Member Number: 40865
How Much Is This!!!!!
Quickest/Fastest Internally Stock SRT-4 in Colorado
Quickest/Fastest Manual in Colorado
*11.10 @ 127 mph
*GT35R @ 23psi
*Daily driven and raced on E85
5,900 ft. of ALTITUDE is a bitch! (COLORADO)
coloRODan_SRT-4 is offline   Reply With Quote
Old 06-12-2009, 01:54 PM   #43 (permalink)
quicky4JR.'s Avatar
Trader Rating: (55)
They are no longer available
Page generated in 0.18347 seconds with 13 queries
