My driver's side is awesome, the passenger side is making a lot of noise.
It makes a sound like the delrin bushing is super tight, and creaking against metal every time it has to move, but I get no noise from the driver's side.
This is a set from your original design. Any thoughts on making the noise disappear?
Take it apart and inspect it.. You may have a worn out bushing. It may just need grease. Check the rear spacers.. They may have crushed.. Our new setup comes with machined spacers to prevent this..
Rage-Tek.com
RAGE Technologies The Vendor that Knows!!
Shop 954-915-0016 954-274-4175
1st Turbo Neon 1st 2.4L swap 1st 2.6l stroker in 01 1st all motor 12's, 11's, 11.06/124
1st neon 13's, 12's 12.72/112 in 96
682 whp SRT4 Daily Driven 10.51@131.73 3150lbs w cage/driver Best MPH 138 02/07
i hope they aren't so stiff they stress the control arm so it cracks. just wait until you start tramlining <--its a word in the grooves of the pavement and potentially lose control of the car(psi-fi). I have gone thru a set of stockers, lost a control arm due to psi-fi's and now have a set of energy suspensions that im trying to put off until im ready to do a clutch install.
Nemo i see you help us
2004 Black. SSTv1, Stage 2 with toys, 3" exhaust with cat, Slow4DR shifter, CBD vented hood.
Is it possible to get a new set of the retainers?
It might just need grease. We just installed these (new) a couple weeks ago, and it started creaking as soon as they were installed, so it shouldn't be from anything worn out.
I know more than one person running these with no issues, and I already like them far better than the traction bars I used to have.
Just took me a while to get around to installing them.
Did yours come with welded spacers or machined ones?
They weren't the machined ones, so I'm going to say welded?
They looked like section of alulminum tube, and did not sit down into the joint like the new ones do.
Aluminum Tube wow.. those were version ones like two years old... Does Dale know there missing from his garage.. You need the steel ones with the washers welded to them..
Ahh. Well, these have been sitting around a while.
Can you hook me up with the new ones?
