Go Back   SRT Forums - SRT4, SRT6, SRT8, SRT10 & Dodge Forum > Supporting Vendors > Rage Technologies
Old 01-24-2008, 08:44 AM   #1 (permalink)
NemoFoss's Avatar
Member Number: 4163
Trader Rating: (64)
Default Rage 750 whp Turbo Kit
750whp Turbo kit:
Includes:
DNP Manifold.
S366et Turbo t3 .70A/R housing.
3" Downpipe.
Tial 44mm WG.
WG dumptube.
Oil lines + fittings.
4" Aluminium Shortram Intake.
2.5" Hotside IC Pipe
Rage Overflow Bottle
Features:
4500-4700 rpm to full boost in 4th gear.
750 whp capable
Will support 500 whp at 19psi
Price $3449
Options:
2000f Ceramic coating of manifold/downpipe and dumptube. $340
2000f Ceramic coating of Turbine. $180
3.5" downpipe upgrade $140
Matching 3.5 exhaust single 14" long muffler $500 (dump near rear tire)
Add 2nd muffler 6" long Add $100
Turbine blanket $180
NemoFoss is offline   Reply With Quote
Old 01-24-2008, 09:13 AM   #2 (permalink)
ipt
Member Number: 9025
650whp kit!!! Now the 750whp kit!!!
Whats next a 800whp kit???
ipt is offline   Reply With Quote
Old 01-24-2008, 09:28 AM   #3 (permalink)
NemoFoss's Avatar
Member Number: 4163
Trader Rating: (64)
You guessed it..
Old 01-24-2008, 09:46 AM   #4 (permalink)
ipt
Member Number: 9025
Quote: Originally Posted by NemoFoss View Post
You guessed it..
Old 01-24-2008, 09:54 AM   #5 (permalink)
Freaky's Avatar
Member Number: 47525
what internal work do i need for this ?
stage0,cca bfmic, needswings dp no cat, mccord electric opener , agp wga ,dtec fc/bc , front an rear strut bars ,progress front an rear sway bars an springs, tripple pillar pod with auto meter volt an oil pressure guage , turbo xs widebind, turbonetics cold side pipe raptor bov , aem cai,return line ,255 walboro fuel pump, Granatelli wires , 4306 plugs
Freaky is offline   Reply With Quote
Old 01-24-2008, 12:21 PM   #6 (permalink)
NemoFoss's Avatar
Member Number: 4163
Trader Rating: (64)
rods/pistons/ head and main studs and main girdle/ ss valves/ springs and cams..would be the minimum recommended for that power level..
Old 01-24-2008, 02:22 PM   #7 (permalink)
Freaky's Avatar
whats the price for a build like that ?
Old 01-29-2008, 05:39 PM   #8 (permalink)
Nasty_NAS's Avatar
Member Number: 11197
Nemo can I get a pick of the setup mocked up or something?? I wanna know what from an agp kit I couls still reuse and then without those pieces get the price.. would you do that?? I am trying to save up for stuff and plan ahead
Agp dbb 50, Agp race fmic, Agp lhp, Dtec,
rc 750s, Crane fire wires, screamin demon coil,
jmb uhp & 3" cai, Tial bov, Twm sts w/stainless knob, DC strut tower bar, Injen turboback
Lca Bushings w/ Rage Delrine, Cooling Mist stage 2
Inovative wideband w/xd-16 guage, Greddy TT
Stewart Warner guages (Boost, EGT & Oil Pressure)
Blue guages w/red line, Megan coilovers, Dcr Bottom end, dcr head comming soon
Nasty_NAS is offline   Reply With Quote
Old 01-30-2008, 12:39 PM   #9 (permalink)
NemoFoss's Avatar
Member Number: 4163
Trader Rating: (64)
You could use the oil supply line and fittings.. and the wastegate.. or turbo..
Old 02-04-2008, 12:50 PM   #10 (permalink)
Nasty_NAS's Avatar
so a 38 mm wastegate is good?? and what would the price be with the turbo minus the lines and wastgate?? also what is the turbo by itself?? would it fit on the agp mani??
Old 02-04-2008, 01:09 PM   #11 (permalink)
quicky4JR.'s Avatar
Member Number: 43042
Trader Rating: (24)
You'll get boost creep with the 38mm wastegate. Yes it will fit on the AGP manifold (may have to massage the firewall a small bit). The turbo by itself is $1350 plus shipping. I would recommend the Synapse 50mm, Tial 44mm, or maybe even the Tial 60mm but they are V-band and wont work with the AGP mani. The next best thing for you is the Synapse 40mm if your going to stick with the AGP manifold.
quicky4JR. is offline   Reply With Quote
Old 02-05-2008, 12:56 AM   #12 (permalink)
NemoFoss's Avatar
Member Number: 4163
Trader Rating: (64)
Actually the turbo is $1350 now.. DP for the AGP mani is $250 We made 682whp on the AGP mani with a 38mm tial.
Page generated in 0.26048 seconds with 11 queries
