Go Back   SRT Forums - SRT4, SRT6, SRT8, SRT10 & Dodge Forum > Supporting Vendors > Rage Technologies
Old 01-23-2008, 02:20 PM   #1 (permalink)
NemoFoss's Avatar
Member Number: 4163
Trader Rating: (64)
Default Rage 650whp Turbo Kit info + Pricing
650whp Turbo kit: This is the kit used to run our 10.51@131.7
Includes:
DNP Manifold.
S362et Turbo t3 .70AR V-band housing.
3" Downpipe.
Tial 44mm WG.
WG dumptube.
Oil lines + fittings.
4" Aluminium Shortram Intake.
2.5" Hotside IC Pipe
Features:
4100-4300 rpm to full boost in 4th gear.
660whp capable
Will support 500 whp at 22psi
Price $3399
Options:
2000f Ceramic coating of manifold/downpipe and dumptube. $340
2000f Ceramic coating of Turbine. $180
3.5" downpipe upgrade $140
Matching 3.5 exhaust single 14" long muffler $500 (dump near rear tire)
Add 2nd muffler 6" long Add $100
Turbine blanket $180
Dyno chart:
RED 34psi droping to 32psi vs BLUE agp log manifold at 38psi
Notice Earlier Spoolup!! (100-150 is from the manifold the rest is from the 3.5" exhaust)
This is near the max of the turbo airflow-wise Hence the same exact curve from 5500rpm up. But this is at 4-6 less PSI of boost with lower egts and lower Charge air temps. Thus a safer running engine.
Dyno Chart:
Same graphs unncorrected.
For comparisions sake:
Orange runs Run030 AGP log hp61 32psi - 30 psi (maxed out) 3" exhaust
Violet Runs run021 DNP s362 34psi - 32psi (maxed out) 3.5" exhaust
Same engine and setup both runs.
Orange run is the same setup and tune we used to run 10.89 at 135 with.
Now we have quicker spoolup (100 more FTlbs at 4300 rpm)
More peak Tq by 30 Ft/lbs
More Peak WHP by 60 WHP
And are making more than 550whp for over 3000rpm a power band wider than a stg 3 at almost twice the power!!!!
NemoFoss is offline   Reply With Quote
Old 01-23-2008, 02:58 PM   #2 (permalink)
NemoFoss's Avatar
Member Number: 4163
Trader Rating: (64)
Added more charts and discription.. Comments
Old 01-23-2008, 09:16 PM   #3 (permalink)
ipt
Member Number: 9025
the HP61 to the curb. Borg Warners are looking good!!
ipt is offline   Reply With Quote
Old 01-24-2008, 01:30 AM   #4 (permalink)
can't stop spinning's Avatar
Member Number: 9183
I'm kinda surprised it did so much better then the hp 61.
100% stock engine, stock head, cams, blah blah blah
1st srt in Canada to get kicked off the track
can't stop spinning is online now   Reply With Quote
Old 01-27-2008, 12:39 PM   #5 (permalink)
cuda340's Avatar
Member Number: 24886
Trader Rating: (24)
Is it possible to get the Downpipe/WG Dump Tube separately?
AGP HP-61,AEM EMS, DNP Tubular Manifold,Aaronneon 925cc injectors, Aeromotive A-1000 Fuel Pump,Perrin Fuel Rail,FullyBuilt Motorsports Race Head, TK Motorsports Head Studs, BC Stage 3 Cams, Fidanza Cam Gears, CP Pistons, Eagle Rods, AGP Race FMIC, Modern Performance 62mmTB, AGP CAI, AGP Hardpipes w/HKS BOV, Ported Intake, B&B Turbo Back Exhaust, Perrin Fuel Rail, DCR Oil Pump,
----MOPARS or NO CARS----
cuda340 is offline   Reply With Quote
Old 01-27-2008, 07:01 PM   #6 (permalink)
quicky4JR.'s Avatar
Member Number: 43042
Trader Rating: (23)
For the S362 and DNP mani? If so, yes you could get it seperately.
quicky4JR. is offline   Reply With Quote
Old 01-28-2008, 08:50 AM   #7 (permalink)
NemoFoss's Avatar
Member Number: 4163
Trader Rating: (64)
We can supply a downpipe and WG dump for what ever setup you have... Pm me for prices and options..
Old 01-30-2008, 09:58 AM   #8 (permalink)
Member Number: 51941
how much would it cost to get a stock engine ready for this setup?
parts and labor
turboblacksrt is offline   Reply With Quote
Old 01-30-2008, 12:37 PM   #9 (permalink)
NemoFoss's Avatar
Member Number: 4163
Trader Rating: (64)
A fully built motor with bedplate strap kit, head and mainstuds, full balance job, Rage oil pump, Rage CNC Ported Head with SS 1mm oversize valves, Springs and Ti retainers, B.Crower stg3 Cam or Crane 18's, Cam Gears. Basically everything thats in the 10.51 car.
Price $6900-$7300 (depending on cam and gear choices) plus cores and shipping.
Old 01-30-2008, 10:38 PM   #10 (permalink)
cuda340's Avatar
Trader Rating: (24)
PM Sent!
Old 03-23-2008, 10:45 PM   #11 (permalink)
quicky4JR.'s Avatar
Trader Rating: (23)
Bump. Who else wants this kit and wants to run some 10's consistantly?
Old 03-23-2008, 10:50 PM   #12 (permalink)
Member Number: 28897
Pics please...
antireversion is offline   Reply With Quote
Old 04-09-2008, 02:52 AM   #13 (permalink)
Member Number: 42729
Are those #'s on pump gas or race gas? I have a 50 trim kit and a needswing dp right now, so it possible to buy the s362 and swap it out/bolt it right on?
What's the difference in power level with the s362 on a log manifold compare with the DNP tubular manifold?
dbb 50 trim
EdgarsSrt4 is offline   Reply With Quote
Old 05-09-2008, 01:29 PM   #14 (permalink)
Member Number: 41218
Default wg
hey nemo, what spring is in the 44 wg and with an aem boost controller, what amount of boost will it hold? i thought i read in one of your posts that there was a problem with a weaker spring and you had to upgrade?
reysrt4 is offline   Reply With Quote
Page generated in 0.27117 seconds with 12 queries
