Go Back   SRT Forums - SRT4, SRT6, SRT8, SRT10 & Dodge Forum > Supporting Vendor Forums > Rage Technologies
Old 06-20-2009, 03:18 PM   #1 (permalink)
quicky4JR.'s Avatar
Member Number: 43042
Trader Rating: (55)
Default << quicky4JR's Build thread >>
I'd first like to start off saying this isnt something that will be completed anytime soon.... Times are tough and money is tight. However, this build will stay progressing forward on a weekly basis until all parts are gathered and built.
This is my daily driver and only vehicle. It will be built for both street AND strip driving. Practicality, durability, and reliability are the main concerns with all of our builds... this build is NO exception. I live 64 miles from Rage-tek (work). Aside from my daily commute to and from work I also travel 115 miles to and from a loved one's house on the weekends. Not to mention the little errands here and there that I have to do on a daily basis for both work and personal use. So is it safe to say this is my daily driver?..... I think so.
Goals:
-One of the fastest 5spds (shooting for top 3, with the fastest being the ultimate goal obviously)
-Daily driven reliability
-650+ (sure it will be more but I'm being very modest)
Quote: Originally Posted by darrell cox View Post
Far better than stock but not as good as Nemos!
Leaders not followers! Paving the way and making it easy for everyone else!
(954)-915-0016
Davie,FL
Dyno tuning, installs, and custom builds
quicky4JR. is offline   Reply With Quote
Old 06-20-2009, 03:18 PM   #2 (permalink)
quicky4JR.'s Avatar
Trader Rating: (55)
RAGE-TEK long block
BOTTOM END
- Rage 6.9:1 Pistons (89mm)
- Pauter rods w/ 625+ rod bolts
- Rage 4 bolt-main strap kit w/ ARP Stud & Bolt kit
- Rage oil pump
- Rage modified pick-up tube
- ATI Balancer
- OEM crank (might knife edge it)
- OEM bearing's, gaskets, seals
- Fully Balanced assembly
- O-ring block
TOP END
- Rage RACE port and polish cylinder head
- Larger exhaust valves (sizes TBD)
- ARP Head stud & Bolt kit
- OEM headgasket
- OEM Lifters, seals and gaskets
- ARP cam cap/tower studs
- BC Springs and Ti Retainers
- BC Stage 3 cams
- Fidanza cam gears
Old 06-20-2009, 03:19 PM   #3 (permalink)
quicky4JR.'s Avatar
Trader Rating: (55)
DRIVETRAIN
- Rage acclerator shaft w/ pilot bearing OR Dogbox
- Rage custom 5th gear (for gas mileage)
- Billet shift selector
- Rage billet 3/4 shift fork
- Enforced syncro clips
- ACT 6 puck unsprung OR Rage Twin disk
- Rage shifter bushings
- Rage shifter mount kit
- DSS Stage 3 axles (hope they hold)
SUSPENSION/BRAKES
- K-Sport coilovers
- Torque solution billet mounts (top, bottm, and tranny mount)
- Rage LCA kit
- Rage rear LCA's
- Rage top mount relocate
- Hawk pads
- Powerslot rotors
- SS Brake lines
WHEELS/TIRES
- Rota Slipstreams 15x8
- Tires (still being researched)
- Slicks by MT or MH
ELECTRONICS
- Diablosport Predator
- 5 bar map sensor
- Rage-tek coil on plug ignition kit
- WOT box (using it for the 2-step)
Old 06-20-2009, 03:19 PM   #4 (permalink)
quicky4JR.'s Avatar
Trader Rating: (55)
FUEL SYSTEM
- Rage 1000HP fuel system
- MagnaFuel 2000hp fuel pump
- Rage FPR kit
- Rage -10 rail
- 1600cc Injectors (Possibly 2nd set of 650-750cc on a 2nd rail)
(Will have an E85 and pump gas 93oct map on my predator)
TURBO KIT
- Rage/Bullseye Power (s258, s362, s366, s368).... Heavy debate amoung us at the shop for turbo selection lol.
- DNP Tubular mani
- Rage piping kit
- TiAL 44mm WG
- Tial Q bov
BOLT ON'S
- Rage 4" exhaust
- Rage custom intake mani with piping kit and 70mm throttle body
- Rage 4" intake
- AGP RACE fmic
- Rage scatter shield
- Rage belly pan
CAGE
- Race Car builders 10pt
(I'm going to see how long I can go before I get kicked out before I get the cage)
I'm sure I missed some things. If I did I will make sure to mention it later on (gauges, lights, paint, etc). Car will still have power steering and A/C......have to keep the lady's happy.
Old 06-20-2009, 03:22 PM   #5 (permalink)
che'ssrt-4's Avatar
Member Number: 62738
Trader Rating: (63)
wanna see this!
"I downshift next to hybrids so they can hear me killing the enviroment "
che'ssrt-4 is offline   Reply With Quote
Old 06-20-2009, 03:34 PM   #6 (permalink)
jaydawg1983's Avatar
Member Number: 62404
x fucking 10000
jaydawg1983 is offline   Reply With Quote
Old 06-20-2009, 03:53 PM   #7 (permalink)
quicky4JR.'s Avatar
Trader Rating: (55)
Mods added in 2nd, 3rd, and 4th section. Have a handfull of them already but making sure I have them all before installation.
Old 06-20-2009, 04:02 PM   #8 (permalink)
Member Number: 38189
make sure you throw in the magnum 2.7l rockers, better the oil squirter points to the cam lobe instead of straight up like in the srt4 rockers
rico's-srt is offline   Reply With Quote
Old 06-20-2009, 04:04 PM   #9 (permalink)
quicky4JR.'s Avatar
Trader Rating: (55)
Alright Mr.Critque lol
They are being left alone.
Old 06-20-2009, 04:07 PM   #10 (permalink)
quicky4JR.'s Avatar
Trader Rating: (55)
you fail lol, im jus makin sure those baby cams stayed lubed
Baby cams.....I know. We have something in the works with a certain company whom I may not speak of for larger cams. Going to be about 3 months or so before they become available.
Old 06-20-2009, 04:07 PM   #11 (permalink)
conroy9940's Avatar
Member Number: 46401
Trader Rating: (114)
subscribed... i might do a build similar since i drive my car about the same amount as you.
Pittsburgh Penguins 12-3-0 24 points
Old 06-20-2009, 04:09 PM   #12 (permalink)
quicky4JR.'s Avatar
Trader Rating: (55)
Sweet. Yea man I have to keep it a daily driver until I hit the lotto or buy a junker truck.
Old 06-20-2009, 04:15 PM   #13 (permalink)
im jus bustin your balls bro, i got the same cams
Old 06-20-2009, 05:40 PM   #14 (permalink)
reed32's Avatar
Member Number: 4648
Trader Rating: (46)
sounds like a good set up. i'm shooting for the top 5 fastest speed. Nemo and I are keeping in touch through texts for my set up.
Edited by Inzanesrt4
JnR track cars:
blue209 12.23@118 w/1.8 60ft 321hp and 390tq
tkilla 12.28@117.8 w/1.8 60ft new numbers coming soon
jrsrt 12.29@116.9 w/1.87 60ft
blackpearl 12.35@114 w/1.960ft 307hp and 363tq
Winecountry 12.32@112 w/1.7 60ft 315hp and 330tq
yellowsrt-4 12.5@112 w/2.0 60ft 295hp and 323tq
jlozacr 12.7@110 w/2.0 60ft 301hp and 345tq
Kaz109 50 trim 458hp/460tq sae 11.54@121.78 W/1.79 60ft
reed32 is offline   Reply With Quote
Old 06-20-2009, 06:04 PM   #15 (permalink)
supermech21's Avatar
Member Number: 42969
Trader Rating: (72)
Holy off topic...
When is rage gonna get off the BW kick...Delta series is where its at!!!
supermech21 is online now   Reply With Quote
Page generated in 0.19794 seconds with 13 queries
