Go Back   SRT Forums - SRT4, SRT6, SRT8, SRT10 & Dodge Forum > Supporting Vendors > Rage Technologies
Old 06-07-2008, 07:06 PM   #1 (permalink)
SRToc Member
blacky's Avatar
Member Number: 18485
Trader Rating: (18)
Default Htob Help Please .
First here is my measurments
Take your FH & subtract your IT
(FH) .313 - (IT) .237 = .076
Subtract this number from your PPH
(PPH) 3.19 - .076 = 3.114
Now subtract your HTOB depth from this number
3.114 -(HTOB depth) 2.971 = .143
+.143 is the amount of my preload
OK I need to know how do I get that to 0 , this is with 0 shims so I can't just take one off or grind any thing down , I put my transmission back on & bolted everything back down because I couldn't think of any way to get that preload off & thought mabe it would be OK but this is what it does with just that small bit of preload , it shifts like butter in all the gears , but the only problem is because of the preload it's like I have my foot half way down on the clutch pedal so when you give it any gas at all it just slips & does not let the clutch grab at all , like if you had a bad burnt out clutch , this is with the clutch pedal adjusted all the way down towards the floor board also & if you adjust it up the clutch does not let the car go untill the pedal is all the way up , also the clutch is a clutchmaster stage 3 & is only 4 months old & worked great before I put this on , this sucks & I need to know how to make this work , please help .
blacky is offline   Reply With Quote
Old 06-08-2008, 03:09 PM   #2 (permalink)
NemoFoss's Avatar
Member Number: 4163
Trader Rating: (65)
You need to grind the two countersink torx screws that hold the plate on..
That will take care of it..
Sorry for the problems
NemoFoss is offline   Reply With Quote
Old 06-09-2008, 03:36 PM   #3 (permalink)
SRToc Member
blacky's Avatar
Trader Rating: (18)
Ya , I had to grind those & the bracket a bit also , it works great now , thanks.
Page generated in 0.18450 seconds with 11 queries
