Go Back   SRT Forums - SRT4, SRT6, SRT8, SRT10 & Dodge Forum > Supporting Vendors > Rage Technologies
Old 03-04-2005, 05:49 PM   #1 (permalink)
NemoFoss's Avatar
Member Number: 4163
Trader Rating: (65)
Default FPR Kit Install
Access the vehicle on the passenger side, in front of the rear tire. There you will find the fuel pump, and OEM filter/regulator.
Remove the quick-connect fitting from the end of the fuel filter/regulator, by pinching the quick-connect tabs, and pulling the fitting away from the filter/regulator.
Press the tab on the filter/regulator, and rotate it counter-clockwise about 90° until it stops.
Grasp the filter/regulator, and pull away from pump module. The filter/regulator may then be removed as shown.
Remove black 1/8 inch diameter o-ring from nipple of regulator canister. Slide the supplied aluminum bushing over black plastic nipple, insert into canister until flush with metal lip. Reinstall black o-ring onto nipple. Reinstall regulator assembly and reconnect fuel line.
Access the passenger side rear of the fuel tank, and you will find the rubber fuel filler tube, connecting the fuel filler neck to the fuel tank. Wipe the tube clean with a damp rag if it is dirty, to avoid contaminating the fuel in the tank.
Loosen the upper and lower worm-gear hose clamps, and remove the filler tube. Cut a 1” section out of this tube. Install one hose clamp over each end. Insert the supplied pipe with nipple into the filler hose. Replace the fuel filler tube. Secure the filler tube with the worm clamps.
Run 14’ s/s line from filler hose along factory lines underneath car. Once you reach the steering rack run line along rack then up over the driver’s side frame rail. Mount regulator behind drivers headlight or on battery tray bracket. Connect the 14’ line to bottom of regulator. Connect 3’ line to side of regulator, then route line to Schrader valve port on fuel rail (remove Schrader valve first). Run vaccum line from nipple on top of regulator to vaccum line on intake manifold.
Tighten all fittings and hose ends. Start car and adjust you fuel pressure with engine idling.
Some base pressures to start with.
50 PSI for stock injectors.
40 PSI for 650 cc.
28-32 PSI for 750cc.
Always tune with a wide band 02 sensor (lm-1, AEM, zeintronix or dyno based unit)
NemoFoss is offline   Reply With Quote
Old 03-04-2005, 05:49 PM   #2 (permalink)
NemoFoss's Avatar
Member Number: 4163
Trader Rating: (65)
Pics to follow..
Old 03-04-2005, 09:21 PM   #3 (permalink)
srtowner's Avatar
Member Number: 4573
Trader Rating: (78)
So what is stock fuel pressure with S2? And am I correct in understanding this is also fuel return line?
FOR ALL YOUR PERFORMANCE NEEDS
srtowner is offline   Reply With Quote
Old 03-05-2005, 06:52 AM   #4 (permalink)
NemoFoss's Avatar
Member Number: 4163
Trader Rating: (65)
stock pressure for s0 s1 s2 is 58 psi.
Yes the this is for a return system..
Old 03-05-2005, 09:05 AM   #5 (permalink)
srtowner's Avatar
Member Number: 4573
Trader Rating: (78)
How much is the kit from you guys.
Old 03-05-2005, 10:55 AM   #6 (permalink)
NemoFoss's Avatar
Member Number: 4163
Trader Rating: (65)
Old 03-05-2005, 01:28 PM   #7 (permalink)
grindpunk16's Avatar
Member Number: 6772
nemo ill be ordering that asap.
grindpunk16 is offline   Reply With Quote
Old 03-09-2005, 07:55 PM   #8 (permalink)
Project Blue
SRTforums Admin
Member Number: 1161
I have his kit its great and Nemo provides great support for it
http://www.hybridsrt.com
In remembrance of Andrew "HybridKid" Chin Shue
In remembrance of Steven "NightShade" Lorenz
