Go Back   SRT Forums - SRT4, SRT6, SRT8, SRT10 & Dodge Forum > Supporting Vendors > Rage Technologies
Old 05-27-2008, 06:23 PM   #1 (permalink)
nightmare_rebuilt's Avatar
Member Number: 42066
Trader Rating: (39)
Default E3+RAGE built motor: Dyno.
Well finally dyno'd:
- FM E3:
  • 44lb wheel.
  • Ceramic coated and ported by Realtune.
- Realtune race exhaust manifold:
  • Coated jet hot silver.
  • Ported.
  • External gate convertion.
- RAGE built motor:
  • Nemo's race head port work.
  • Over size valves.
  • BC stg2 cams (272s).
  • Fidanza cam gears.
  • BC retainers and springs.
  • JE pistons, 8.8:1
  • Crower rods.
  • Rage oil pump.
  • No balance shaft chain or assembly.
- Devils own W/I kit:
  • Direct port M3 nozzles (4)
  • Progressive controler.
  • 100% methanol.
- Fuel:
  • DCR fuel pump.
  • RAGE 8-AN fuel rail.
  • Nightmare return line set up , ALL fuel lines replaced with 6-AN and inline fuel filter.
- Supporting mods:
  • MAXFAB stg3 O2 housing.
  • MAXFAB full 3" turboback.
  • Custom dump tube for WGA.
  • Trubonetics evolution WGA.
  • CTI intercooler.
  • RAGE race ported intake manifold (gasket matched)
  • RPM services 62mm TB.
  • JMB 3" ultimate intake (modified to short ram).
  • D-TEC FC/BC.
  • Stg0 ECU!
- Thats it for actual power mods, the rest are miscellaneous and dont matter right now.
- Nemo was only able to get 20psi letting it fall to 18psi red line, any higher boost at spike or red line and it was: ♪♫"knock knock knocking on heavens doOOoor... yea... ye-ye-yeaaa..."♫♪. Apparently the 4 M3 nozzles and pump gas (93oct) are not enough, i have had this turbo hold 25psi to red line no problem, unfortunately i dont have enough octane for it yet, and depending on race gas for me is not an option for me. Due to the knock we cut it short and didnt even play with the cams i had them set temporarily at; intake retarded 2* and exhaust advanced 3* to smooth out the idle until i got the car tuned.
So, there you go, 402whp@18psi to red line, pump, RAGE-TEK motor and Nemo's tuning, big thanks to Nemo for being so patient and cuddly .
FloridaSRTOwnersClub.
FS: BUILT SRT4 motor! 3k takes it, needs to go, buying a 68 mustang FL locals only pm me for specs on the motor!
nightmare_rebuilt is offline   Reply With Quote
Old 05-27-2008, 06:26 PM   #2 (permalink)
Trader Rating: (39)
now i just have to order larger w/i nozzles from devils own and turn up the boost, to what? only knock will tell.
Old 05-27-2008, 06:29 PM   #3 (permalink)
TurboMoparGod's Avatar
Member Number: 33697
Trader Rating: (32)
Great now get it to the track.
www.ForwardMotioninc.com
Sales@ForwardMotioninc.com
Stock turbo 12.82@107mph DR's
E1 Turbo 12.48@115mph DR's slipping stock clutch
E3 47lb Turbo and new FM clutch coming soon
TurboMoparGod is offline   Reply With Quote
Old 05-27-2008, 06:35 PM   #4 (permalink)
S2R0T044's Avatar
Member Number: 5620
Very nice.
Josh - 2005 Black SRT-4
Drastic.
blazinsrt built.
S2R0T044 is offline   Reply With Quote
Old 05-27-2008, 06:35 PM   #5 (permalink)
Trader Rating: (39)
i cant, moroso its closed for the next few months, but dont worry im dying to, i have slicks, NDE traction control/2 step, boost by gear, bla bla bla, etc.
dig or die mofos.
Old 05-27-2008, 06:39 PM   #6 (permalink)
CIVICEATER's Avatar
Member Number: 16703
Why does it seem to spool slow is it the cams you have in there, but good power.
2003 Solar Yellow SRT-4
E1 Turbo
Kinetic WGA
Devils Own W/I with Progressive Controller
MPx 3" Exhaust with Cat
MPx Intercooler
AGP CAI
Stage 3 ECU
Walbro 255lph Fuel Pump
Stage 2 Injectors
Perrin Fuel Rail
AEM Wideband
Aeroforce Scan Guage
Greddy Type RS BOV
Mopar STS
Exhaust Depot Hardpipes
DCR Oil Mod
DCR 5 Layer Headgasket
299hp - 324ft-lbs tq
13.1 - 110mph<----- Traction Ownz Me
CIVICEATER is offline   Reply With Quote
Old 05-27-2008, 06:44 PM   #7 (permalink)
goats srt's Avatar
Member Number: 47689
wow awesome numbers, do u know what your timing was?
Old 05-27-2008, 06:46 PM   #8 (permalink)
supermech21's Avatar
Member Number: 42969
Trader Rating: (44)
the loads of knock is caused by the 8.8cr + Pump, correct?
SARCASTIC.
FS: O2 housings(stock/stage 3), stock IC(s), Autometer Wideband (ultralite pro comp $330 gauge), 49lb Ported FnF Stg 3 Big wheel with 3.5" O2 and AGP WGA(CHEAP)...PM for offers
Old 05-27-2008, 06:47 PM   #9 (permalink)
Trader Rating: (39)
well, larger wheels loose spool, cams are not tuned, when you step on it boost is 17psi, creeps to 20psi and falls to 18psi, there was no point really to mess with the boost, where we were was the limit before knocking, so no point in wasting dyno time to figure out the boost until the larger meth nozzles are in.
Old 05-27-2008, 06:48 PM   #10 (permalink)
Trader Rating: (39)
it plays a part in it, yes.
Old 05-27-2008, 06:50 PM   #11 (permalink)
Trader Rating: (39)
i dont remember ill have to ask nemo.
Old 05-27-2008, 06:51 PM   #12 (permalink)
CIVICEATER's Avatar
Yea I know bigger wheels are laggier, but shouldnt be that laggy. I would think a 44lb s3 would hit full boost on the street at 3300-3400 rpm. Not 4500 rpm like it seems in your dyno sheet. It will probally just involve tuning your cams and your spool and torque will come up.
Old 05-27-2008, 06:53 PM   #13 (permalink)
Trader Rating: (39)
Nemo says he thinks it was 28 he doesnt remember exactly.
Old 05-27-2008, 06:59 PM   #14 (permalink)
Trader Rating: (39)
again; when you step on it boost is 17psi, creeps to 20psi and falls to 18psi, there was no point really to mess with the boost, where we were was the limit before knocking, so no point in wasting dyno time to figure out the boost until the larger meth nozzles are in.
yes some playing of the cams is due, but dont judge boost by just looking at the dyno sheet, judge it by looking at the boost gauge, what you see on the graph is when the power comes in, and the power band right now is being affected by the flow of the head, the position of the cams, not just boost alone, we havent mess with the spike anyways.
Old 05-27-2008, 07:00 PM   #15 (permalink)
Trader Rating: (39)
besides this set up needs a higher rev limiter, the flow of the head and the cams are beging for it.
