Go Back   SRT Forums - SRT4, SRT6, SRT8, SRT10 & Dodge Forum > Supporting Vendor Forums > Rage Technologies
Old 11-26-2008, 06:54 AM   #16 (permalink)
BOOSTINSRT04's Avatar
Member Number: 33061
Trader Rating: (30)
Nice!
S256 non extended tip F/IC tuned by Aaronneon
11.88@116 1.74 60'
Old 11-26-2008, 07:19 AM   #17 (permalink)
Member Number: 41077
nice ass dyno guys . that power band at red line is sweet... Now you got a tune for those that have s2 cars ...
dsmlights@rage-tek is offline   Reply With Quote
Old 11-26-2008, 08:14 AM   #18 (permalink)
Member Number: 7593
Wonderful,.. add more fuel to the ego fire! lol
But, also.. keep in mind. From what I understand the car on on the "rollers" for a rather extensive time.
The boys are doing their job thus far.
Side note, this car is also "according to previous info" the first car that would not work AT ALL, with the predator!!
So, again.. props to everyone who has put time into it.. keep up the good work!!
As soon as I get my "plans" ironed out.. you guys will probably be hearing from me.
Will.
Nosfurato is offline   Reply With Quote
Old 11-26-2008, 11:08 AM   #19 (permalink)
NemoFoss's Avatar
Member Number: 4163
Trader Rating: (71)
Quote: Originally Posted by 04CUSTOMBLUE View Post
what kind of dyno?
Dynojet..
The uncorrected numbers are higher..
It's all good..
I love friendly chats
NemoFoss is offline   Reply With Quote
Old 11-26-2008, 11:34 AM   #20 (permalink)
scottw03's Avatar
Member Number: 23435
Trader Rating: (39)
Ditch the AGP wga and get a FM wga. Should be able to hold 20 psi to redline with that. I was able to atleast with my FM E1/wga setup. Held 20-21 psi to redline running a 24 psi spike.
scottw03 is offline   Reply With Quote
Old 11-28-2008, 07:04 PM   #21 (permalink)
daniel427ss's Avatar
Member Number: 51325
i think i still dont have things straight,
does the ds come with a canned tuned(free) for whatever stg2 or 3 pcm u have???
or is this the 93oct. tune? i dont get it
srt stock motor mounts 4 sale
bunch of 350z parts for sale, cp pistons .020over, eagle rods, headgaskets, heads, timingcovers, etc. etc.
daniel427ss is offline   Reply With Quote
Old 11-29-2008, 10:33 PM   #22 (permalink)
Member Number: 7593
No, that is not the canned 93 tune. That is a tune that Nemo put together for my friends car.
The "canned" tunes as far as I understand,.. are designed to be "close" but, given that every car is different,.. there cannot be a "one size fits all" tune.
That is where the fine tuning on the dyno comes in.
I don't know everything that Nemo changed.. but, from what I understand.. they also worked on some driveability tuning also.
Maybe he can chime in and ad to that. All I know, is that my friend seems pretty happy with how things went with the tune.
Will.
Old 11-30-2008, 12:28 AM   #23 (permalink)
93stang434's Avatar
Member Number: 49690
I bet your redline wasn't 6700,and that is alot of rpm for such a small turbo.I had to learn how to drive the damn car again, shifting at 6700-6800 took some getting used to.I had the car at the track in Florida and traction was a serious problem.What i couldn't understand was in HOM the car wouldn't pull past 6000 so i just added timing to Nemo's tune and that sure did the trick.Bradenton raceway is wierd because at home if i trapped 93 mph in the 1/8 i would have trapped 118-119 at the big end but here i could only muster 114.I know most people won't believe me but as far as my daughters and myself could tell i had the fastest car there. I just wish i brought the drag radials instead of race gas.
E1 w/ported 3" anti-surge cover,LCR fully ported ext.gated exh mani,3" o2 housing,3"SEE,N2MB boost box,
S2 injectors,diablosport predator,coolingmist w/m
255 pump,rewire,bottleneck mod,returnline
MPx bfmic,55 t-body,180 t-stat,DCR oil restrictor
Best E.T 12.12 Best MPH 118.71 DR's,full weight no n2o
Tuned by Nemo@Rage-Tek & myself http://www.srtforums.com/forums/f146...charts-480643/
93stang434 is offline   Reply With Quote
Old 12-02-2008, 09:36 PM   #24 (permalink)
duster360's Avatar
Member Number: 45182
Quote: Originally Posted by NemoFoss View Post
Here you go. Pumpgas.
Mods:
AGP WGA no bleed hooked straight to turbo. 23psi falls to 17psi
Full STG2 w toys and STG 2 fuel system.
3" turbo back side exit.
Ported turbo manifold E1.
Ported intake amd 55mm TB
FMIC
SRI
Return line fuel kit. 56psi boost ref.
Dead stk stg2 tune vs final Diablo CMR rage tune:
60 ft/lbs torque gain same boost on all runs:
On the Stock S2 the A/F has a familiar lean trend after 5000rpm, but on the DS tune doesn't.
Was the A/F corrected ONLY with the DS or was there other mechanical means used??
Old 12-02-2008, 10:11 PM   #25 (permalink)
JuanchoSRT's Avatar
Member Number: 50012
Is this the Diblosport flashed in the stage2 PCM or the stock PCM. Is there any difference in performance. I swappped to my stock one and cant quite use the boost controller. it it because of the 3.0 map and tip sensors?
Stage 2w/o//DCR E1//Raily Ext. mani// 3" o2//MPX IC//Perrin C/C /Dog Bone Motormounts/mopar stage 1 springs //mopar STS
ATP cold side pipe with HKS BOV//Agp hot side pipe//HP turboback exhaust// dasmopar mapclamp//ebay 3 inch CAI//3" high-flow Cat
JuanchoSRT is offline   Reply With Quote
Old 12-02-2008, 10:12 PM   #26 (permalink)
JuanchoSRT's Avatar
Is this the Diblosport flashed in the stage2 PCM or the stock PCM. Is there any difference in performance. I swapped to my stock one and cant quite use the boost controller. it it because of the 3.0 map and tip sensors?
Old 12-03-2008, 09:58 AM   #27 (permalink)
blacksin's Avatar
Member Number: 39845
Trader Rating: (18)
Impressive... this is the setup that I'm looking for, just on PCM-controlled boost.
Custom CAI + MOPAR: Stage 2 w/ toys, Borla Cat-back exhaust, STS w/ boogers, S1 springs, RB1 w/ IPOD kit N2MB: Toybox 2.0, Code Scrubber Aeroforce Technology: Scan Gauge MaxxFab: 3" downpipe Forward Motion: E1, wga
blacksin is offline   Reply With Quote
Old 12-03-2008, 07:30 PM   #28 (permalink)
93stang434's Avatar
The car has a returnline that is boost referenced and the base pressure was 56psi.When Nemo tuned it he left the fuel system alone so i think all the changes where made with the CMR software and not the handheld.The handheld is zeroed out so i still have full adjustability.Also stage 2 pcms go pig rich right around 6000 and also kill the timing that is why so much was gained up top and also the fact Nemo is the man.
Old 12-07-2008, 08:41 PM   #29 (permalink)
srt4_riceater's Avatar
Member Number: 22900
Trader Rating: (31)
Quote: Originally Posted by lyncoo View Post
300hp at 6700 is badass on a e1. good job
Were you stock boost control? I'm running e1 and realtune race mani w/ external gate and put 326whp at 16psi. I couldn't get by dual stage hpbc to go higher? Sorry to hijack. The e1 caught my eye cause' i'm in the market for a tuning device. I like this DS Predator.
s2 w/out toys, E1, Realtune mani w/ Turbonetics external gate/dump. DCR 500WHP bottom-end (.20 over), Wiseco pistons, and oil pump and big filter kit. AGP Race FMIC, JMB PP's, DSP, JMB CC, Port/Polish Intake and Lorenzo 55mm TB w/ spacer, Dog Bones, MaxFab full 3" side exit, CoolingMist water/meth injc, IPP coilovers, AEM UEGO, Autometer Pyrometer EGT, Greddy Type RS BOV, K&N Gen II Air Intake Kit, stock solenoid bc, Walbro pump, Lorenzo 55mm TB.
srt4_riceater is offline   Reply With Quote
Old 12-07-2008, 09:45 PM   #30 (permalink)
93stang434's Avatar
No just a AGP wastegate hooked directly to the turbo.It was falling to 17 because 6700 is alot of rpm, hell a stocker would be down to 10-12psi.this thing moves out for the mod list and being on pump gas. race gas is pretty good to i don't know what the numbers would be but i bet they'd be in the 330's.I want to go big turbo and get 400 but this thing on the nitrous is probably pretty close so why bother.
Page generated in 0.16786 seconds with 14 queries
