Go Back   SRT Forums - SRT4, SRT6, SRT8, SRT10 & Dodge Forum > General Car Discussion > Other SRT Vehicles > Chrysler/Dodge Garage > Chrysler Vehicles > Crossfire Discussion
Old 06-18-2003, 06:56 PM   #1 (permalink)
hemidakota's Avatar
Member Number: 272
Trader Rating: (15)
Default Suppliers to the Crossfire vehicle
New Chrysler built on Mercedes 'crossover' line
Coachbuilder Wilhelm Karmann began building the new Chrysler Crossfire at its plant in Osnabrück, Germany, in April.
Karmann also builds the new Mercedes-Benz CLK Cabriolet at Osnabrück. The Crossfire is made on the line that was used for the previous-generation CLK Cabriolet, reducing tooling costs for the new Chrysler model.
Crossfire volumes are currently forecast at around 22,500 units a year but Karmann says it can increase this to 40,000 units if the car sells well. The Crossfire was developed in close cooperation with Mercedes-Benz engineers.
About 39 percent of components come from Mercedes models, including the suspension, the heating, ventilation and air conditioning system, and powertrain options.
-- Alex Graham
Suppliers to the Chrysler Crossfire in PDF format
HOMELINK (REMOTE CONTROL): JOHNSON CONTROLS
100% GLAZING: PILKINGTON
SEAT SYSTEMS AND HEADLINER: LEAR
ALUMINUM ROOF STRUCTURE PARTS: ALCOA
HIGH MOUNTED STOP LIGHT: FER
MULTI-FUNCTION TRIM WITH COIN HOLDER: FISCHER
SPOILER: WEBASTO WINDOW REGULATORS: BROSE
FUEL FILLER NECK: BENTELER
LOCKSET AND RF KEY: HÜF
LICENSE PLATE LAMP: SIDLER
GEAR SHIFT MODULE: DELPHI
ABS AND FRONT/REAR BRAKE CALIPERS: CONTINENTAL TEVES
FUEL PUMP: TI AUTOMOTIVE
CVJ BOOTS: FREUDENBERG
TANK LINES: COOPER STANDARD
FRONT AND REAR LIGHTS: VALEO FOAM FILM FOR DASHBOARD: CONTITECH
INSTRUMENT CLUSTER: SIEMENS VDO
COMPLETE AUDIO SYSTEM: HARMAN/BECKER
UNDERBODY PANELS: POLYNORM
COIL SPRINGS AND STABILIZER BARS: ALLEVARD REJNA
TRANSVERSE CONTROL ARM BEARING: VIBRACOUSTIC
EXTERIOR MIRRORS: MAGNA DONNELLY
RESERVOIR PIPE: FTE
SUMMER TIRE: CONTINENTAL CYLINDER HEAD GASKET: DANA
FOG LAMPS: HELLA
FRONT AND REAR BUMPERS: PEGUFORM
CRANKSHAFT AND TRANSMISSION HOUSING: THYSSENKRUPP
PISTON RINGS: FEDERAL-MOGUL
COOLING MODULE AND A/C SYSTEM: BEHR
SPRAG ONE-WAY CLUTCH: BORGWARNER MORSE TEC
BODY ELECTRONICS CONTROL UNIT: CONTITEMIC MICRO V-BELTS: GATES
AIRBAG AND RESTRAINT SYSTEM CONTROL UNIT: BOSCH
WATERBORNE BASE COATS: DUPONT
HEATER HOSES: HUTCHINSON
BATTERY: JOHNSON CONTROLS BATTERIES EUROPE
HOOD HINGE: EDSCHA
E-BOX: KOSTAL
PASSENGER AIRBAG: TRW
WIRING HARNESS: YAZAKI
hemidakota is offline   Reply With Quote
