Go Back   SRT Forums - SRT4, SRT6, SRT8, SRT10 & Dodge Forum > Chrysler/Dodge Garage > Chrysler Vehicles > Crossfire Discussion
Old 07-01-2004, 08:56 AM   #1 (permalink)
SRToc Member
hemidakota's Avatar
Member Number: 272
Trader Rating: (15)
Default Automobile Mag: SRT-6 Review & Spec
Reviews Automobile Magazine: Preview & Specifications: Chrysler Crossfire SRT-6
Chrysler's cute Crossfire coupe got off to a slow start in the U.S., but sales have picked up since DaimlerChrysler got real on the pricing and started incentivizing, to use the current jargon. It now outsells the Porsche Boxster and Audi TT combined, Chrysler execs are proud to point out. A convertible will no doubt help the car's appeal, as will the very sporty SRT-6 version that goes on sale this summer. The SRT-6, which is available as a coupe and roadster for - deep breath - $45,695 and $49,795 respectively, is billed as Chrysler's fastest ever car, with a top speed of 158 mph. It is also, as you can see from the dollar numbers, Chrysler's most expensive car ever.
The SRT part of the equation denotes that DCX's Street and Racing Technology Group has given the Crossfire some performance and attitude. The attitude is visually denoted by a large fixed tail wing, deeper chin spoiler, and attractive eighteen-inch front and nineteen-inch rear wheels, shod with 225/40 front and 255/35 Michelin Pilot Sport 2s. Inside, Alcantara seat inserts that are supposed to keep your butt better in place under hard cornering and a 200-mph gauge cluster are the only significant modifications over the stock Crossfire.
The performance comes from an AMG supercharged version of the Crossfire's corporate Mercedes 3.2-liter, SOHC, 18-valve V-6 engine. Power goes up from 215 hp to 330 hp, with 310 pound-feet of torque. The engine is mated to a five-speed automatic transmission that has manu-matic actuation.
The SRT-6 shares an awful lot in common with the outgoing SLK32 AMG, other than just the engine and gearbox. The dual control arm front and multilink rear suspension are virtually identical, although they are tuned in this application, with firmer damping and much stiffer spring rates. (They have gone up from 303 pounds per inch front and 337 pounds per inch rear to 451 lb/in and 480 lb/in respectively on the coupe.) The brakes, too, have come in for attention, with vented discs all around (the stock car has solid rear rotors), bigger front discs, and dual piston calipers in place of single-piston items.
The upshot is a car with serious performance credentials. Chrysler claims 0 to 60 mph in about 5 seconds, 0-100-0 mph in less than 16 seconds, and 60 to 0 mph braking in about 115 feet. In terms of bang for your buck, the SRT-6 delivers, although it is far pricier than a 350Z and up there in rarefied BMW/Porsche/Mercedes territory.
Reviews Preview & Specifications: Chrysler Crossfire SRT-6
Powertrain and Chassis
3.2-Liter V-6 Engine - Supercharged, intercooled SOHC 18 valve
Brakes - Anti-lock 4-wheel disc
Emissions - Low emission vehicle, U.S. 50 state (Tier II, Bin 9)
Meets Stage IV emission requirements in Europe
Fuel Tank - 15.85 Gallons
Stabilizer Bar - Front and rear
Steering - Power
Tire Fit System
Air Compressor and Can - Tire fit sealant
Tires - Michelin 2nd Generation Pilot Sport Ultra-high Performance
Front - 225/40ZR18
Rear - 255/35ZR19
Transmission - Five-speed automatic with AutoStick(r)
Wheels
Front - 18" aluminum, SRT design
Rear - 19" aluminum, SRT design
Safety and Security
Air Bags - Driver and passenger front, side-supplemental, door mounted
Electronic Stability Program
Emergency Brake Assist
Horns - Electric, dual note
Headlamp Off Time Delay
Illuminated Entry
Keyless Entry
Locks - Power auto central locking
Security Alarm - Premium Sentry Key(r) theft deterrent system
Speed Control
Traction Control - All speed
General Information
Body Style Coupe and Roadster
Assembly Plant Osnabrück, Germany
EPA Vehicle Class Two-seater
Engine: Supercharged 3.2-Liter, SOHC, 18-Valve, SMPI V-6
Type and Description 90-degree bank angle, liquid-cooled with twin ignition
Displacement 195.2 cu. in. (3199 cc)
Bore x Stroke 3.54 in. x 3.31 in. (89.9 mm x 84.0 mm)
Valve System SOHC, 2 intake valves and 1 exhaust valve per cylinder,
roller rocker arms
Fuel Injection Sequential, multi-port, electronic
Construction High-pressure die-cast aluminum alloy block with Silitec
alloy liners and cast aluminum alloy heads
Compression Ratio 9.0:1
Power (SAE net) 330 hp (246 kW) @ 6100 rpm (103.1 bhp/liter)
Torque (SAE net) 310 lb.-ft. (420 Nm) @ 3500-4800 rpm
Max. Engine Speed 6400 rpm electronically limited
Fuel Requirement Unleaded premium, 91 octane (R+M)/2
Oil Capacity 8.5 qt. with dry filter
Coolant Capacity 11.8 qt.
Emission Controls Three-way catalytic converters and internal engine
features (meets Stage IV emission requirements in Europe)
Max. Gross Trailer Weight Not recommended
EPA Fuel Economy 17/25
Transmission Automatic, Five-Speed Overdrive
Description Adaptive electronic control or AutoStick(r) driver interactive
manual control and lockup torque converter clutch
Torque Converter Stall
Torque Ratio 1.96
Gear Ratios
* 1st 3.595
* 2nd 2.186
* 3rd 1.405
* 4th 1
* 5th 0.831
* Reverse 3.16/1.93
Final Drive Ratio 3.07
Overall Top Gear 2.55
Electrical System
Alternator 120 A
Battery Group 48, maintenance-free, 700 CCA
hemidakota is offline   Reply With Quote
Old 07-01-2004, 08:58 AM   #2 (permalink)
Member Number: 326
This car is a huge dissapointment.
SRT4B is offline   Reply With Quote
Old 07-01-2004, 09:32 AM   #3 (permalink)
JCX
Member Number: 553
Why do you say that? I'm thinking when they hit the streets they should be good for mid 13's no brainer - much like the SLK32 AMG cars.
JCX is offline   Reply With Quote
Old 07-01-2004, 10:05 AM   #4 (permalink)
wreckless's Avatar
Member Number: 142
Automatic trans only for one reason...
Rob AKA wreckless
Member Since 12/2002
SRTOC #134
2005 Dodge Ram 250 HD QC Hemi 4X4!
2004 Infiniti G35 Coupe
2004 Lexus LS430
2003 Solar Yellow SRT/4-sold
1998 Black ACR Coupe-sold
1995 Blue ACR Coupe-sold
1986 Black Conquest TSi-sold
1985 Blue Omni GLH Turbo-sold
wreckless is offline   Reply With Quote
Old 07-01-2004, 10:12 AM   #5 (permalink)
Remax Realtor's Avatar
Member Number: 3827
Trader Rating: (49)
no manual???? that sucks. its expensive, but it should be pretty quick. Im not liking the sticker price though.
Old 07-01-2004, 10:25 AM   #6 (permalink)
ViscousCircles's Avatar
Member Number: 2088
automatic!!!!??? thats no fun
ViscousCircles is offline   Reply With Quote
Old 07-20-2004, 08:45 PM   #7 (permalink)
BenzoAMGpower's Avatar
Member Number: 8754
more like a high 12er... im sure the SRT6 can hit high 12s in cool weather just like the SLK32 can!!! And my C32 when it was stock could hit 13.0 in cool weather!! Well, now i should be hitting mid to high 12s in cooler weather with my current mods... you can do the same to your SRT6 too!!!!
BenzoAMGpower is offline   Reply With Quote
Page generated in 0.28244 seconds with 11 queries
