Old 05-12-2008, 10:28 PM   #1 (permalink)
Member Number: 50897
Trader Rating: (12)
Default Would these fit stock suspension.
I was curious if these would fit on stock suspension for now as I will be installing goldlines in the next few weeks. Also i did not want to go with 18's because of a performance loss will this drastically affect my performance i believe they weigh in at 20lbs.
HDP hairpin Bronze Wheels
18x7.5
5x100/4.5
offset 35
With General altimax UHP
225/40-18
Also what about these rims
HD Stinger
17x7.5
5x100
offset 42
Not sure on tires yet hopefully 245's up front and like 235's out back.
04 Black(kinda) SRT-4
Installed: FM WGA, Modified ED dual Exhaust (black), BDJ's 3" CAI ceramic, Bwoody Checkvalve, X02 BFMIC, Cold Side Pipe with Raptor BOV, Techgauge, Upper DogBone, Oil Modifier, 18" HPD Bronze wheels, and Goldlines
Waiting go be Installed: PTP FTM, Wideband, Lower MM insert
xbladr is offline   Reply With Quote
Old 05-13-2008, 02:27 AM   #2 (permalink)
VanillaXtract's Avatar
Member Number: 27205
Trader Rating: (17)
Did you read through the sticky?
If life was easy, it'd be called "your mom"
VanillaXtract is offline   Reply With Quote
Old 05-13-2008, 10:00 AM   #3 (permalink)
Wheels & Tires Moderator
evo77's Avatar
Member Number: 1346
Yes, what he said.
The sticky thread will usually answer 95% of ALL fitment questions.
Old 05-13-2008, 02:31 PM   #4 (permalink)
Trader Rating: (12)
Yes I have read the sticky and it didnt really answer the question it gives some generalizations. offset of 42 seems high when i look at the generalizations but i know todd got some with i believe 48 on the back of his car. That also didnt talk to much about lowered cars as far as i could tell. I plan on doing goldline springs and I am not sure if that will affect it.
I was also curious if you guys thought the 18's would seriously hinder performance or if it wouldnt make much difference.
Old 05-13-2008, 04:56 PM   #5 (permalink)
Super Moderator
stowaway's Avatar
Member Number: 3286
I think those crappy tires will hurt the performance more than the wheels.
Old 05-13-2008, 05:15 PM   #6 (permalink)
Trader Rating: (12)
lol the tread is almost gone on them it would only be to get them on my car at first they are used but I think I am going to go for the 17's i just dont know if I will have to run a spacer with a 42mm offset when i wanna get 245's on them
Old 05-13-2008, 05:26 PM   #7 (permalink)
Super Moderator
stowaway's Avatar
Member Number: 3286
yoiu can not fit a 245/40-17 safely on a 7.5" wide wheel. A 245/45-17 is tall and heavy, and likely won't fit anyway once you lower the car.
Old 05-13-2008, 06:28 PM   #8 (permalink)
Trader Rating: (12)
really i have heard 225/235 max for a 7" and 245 max for 7.5"
Old 05-13-2008, 06:59 PM   #9 (permalink)
Super Moderator
stowaway's Avatar
Member Number: 3286
225/45-17 = 7" minimum
235/45-17 = 7.5" minimum
245/45-17 = 7.5" minimum
235/40-17 = 8" minimum
245/40-17 = 8" minimum
Old 05-13-2008, 07:11 PM   #10 (permalink)
addictedtosin's Avatar
Member Number: 30537
Trader Rating: (113)
For a 17x7" wheel I would go with a good quality 225 45 17.
Basically it looks like this minus a turbo...... oh and wheels too
addictedtosin is offline   Reply With Quote
Old 05-13-2008, 07:41 PM   #11 (permalink)
Trader Rating: (12)
addicted what a bout a 7x7.5 a 235 45 17?
Stowaway thanks man so a 245/45 would prob be too big then?
Old 05-13-2008, 09:38 PM   #12 (permalink)
evo77's Avatar
Member Number: 1346
Lets compare your questions to what the Wheel & Tire Tech thread says...
1. Your first question asks if 18x7.5 5x100 35 offset wheels with 225/40/18 tires will fit.
Quote: Originally Posted by WHEEL & TIRE TECH Thread
7.0-7.5 inch wide wheels generally fit with offsets of 35-40mm.
The following are the most common and popular upgrade tire sizes:
15" wheels = 215/60/15
16" wheels = 225/55/16
17" wheels = 225/45/17
18" wheels = 225/40/18
19" wheels = 225/35/19
These tires are all closest to the overall diameter of the stock tire size and do not interfere with suspension pieces, fenders or any of the above (as long as both the offset of the wheel and the proper ride height is correct). There are other sizes that can be used but they will either be slightly smaller or larger in overall diameter.
2. Your next question asks if they will fit with Goldline springs.
You can avoid any kind of rubbing by maintaining a proper ride height. If your car is dropped more than 2.0 inches than expect some rubbing on anything wider than the stock wheels. Hard cornering, passengers in the back seat and extreme bumps in the road can cause rubbing. There is no way around this. If you want those phat looking 8.5" wide wheels to go along with the massive drop on your coilovers than prepare for the fenders and tires to constantly be in contact. The good thing about coilovers is that you have the ability to adjust the height to give you the clearances needed. So please, don't ask if a certain wheel and tire will fit on your coilovers because common sense will tell you that if it doesn't you need to RAISE THE CAR! On lowering springs you don't have that luxury. Just be aware when you buy those mega drop lowering springs if you plan to buy wider wheels in the future.
Follow the fitment guide provided in this sticky thread and you should not have issues with rubbing UNLESS your car is too low as stated above. Other things that may exhibit rubbing might be a tire too tall (taller than 25.4") or a wheel offset that is too low (less than 35mm). If you follow the fitment guide you should be ok.
3. Your third question asks if 17x7.5 5x100 42 offset wheels fit.
7.0-7.5 inch wide wheels generally fit with offsets of 35-40mm.On that same note this does not imply that a wheel with a 42 or 45mm offset will not fit over the calipers. It will all depend on the spoke design of that particular wheel. There are plenty of wheels with a 42mm or 45mm offset that fit but there are also just as many that do not.
I will add this, 98% of the time a 42 offset wheel in a 7.0-7.5 width will always clear. In the event that it doesn't, a harmless 3mm spacer is all that is needed to give you the caliper clearance.
Old 05-13-2008, 10:02 PM   #13 (permalink)
Trader Rating: (12)
Yes i understand that most of those are in most cases and the most common/popular application I am asking for more of a has anyone had a chance to try similiar specd wheels and had them fit and if so what mods and what not. I read through the sticky and I did see what is "RECOMMENDED" i want to know what the limits are beyond recommendation do you know what i mean? I am not trying to be a dick and the wheels and tires section is really helpful but im trying to see my options outside of what is recommended.
Which wheels do you guys personally like better.
or
Yes both in bronze and the hairpins are 18's while the stingers are 17's unless i can get the hairpins in 17's
Old 05-13-2008, 10:05 PM   #14 (permalink)
lyncoo's Avatar
Member Number: 43166
Trader Rating: (58)
first ones
thats fantastic
AGP S256 + B&G FLASH
Old 05-13-2008, 10:36 PM   #15 (permalink)
evo77's Avatar
Member Number: 1346
I don't think you understand.
There really is no gray area. The information provided in the sticky is from trial and error from many others over the years who have tried MANY different wheel/tire combinations. Also there are basic measurements in regards to wheel and tire dimensions and their relation to caliper and suspension clearance of the SRT-4 that are ALWAYS THE SAME.
A 18x7.5 35 offset wheel and 225/40/18 tire will ALWAYS FIT. The sticky thread tells you this.
On stock suspension? YES.
On lowered suspension? YES ONLY IF THE MAXIMUM LOWERED HEIGHT IS NOT EXCEEDED. The sticky thread tells you this.
Goldline springs lower the car about 1.5". The sticky thread tells you that this drop is within the range where rubbing is NOT an issue given the proper wheel and tire dimensions are being used. Which in the case of the example above, you are!
I don't mean to be hard on you but I'm just trying to point out that the sticky thread takes all the guess work out. I've tried my best to make the sticky thread as clear as possible. If I have not been able to prove this, please tell me how I can improve the sticky.
The whole purpose is to help you guys understand how wheel/tire fitment works for this car. I want someone not knowing a damn thing about wheels to be able to read it and know exactly what wheel size, offset and tire size to buy for his or her ride.
