Old 11-01-2009, 09:08 PM   #1 (permalink)
Member Number: 75457
Default will the 5x100 2002 wrx rims fit
will the rims off a 2002 wrx fit the srt 4 they are 5x100 but what about the hub hole because i ran in to that problem with these 16inch steelies i found they were 5x100 but the hub hole in the middle was too small for the srt 4 hub thanks
2003srt4123456 is offline   Reply With Quote
Old 11-01-2009, 09:11 PM   #2 (permalink)
lyncoo's Avatar
Member Number: 43166
Trader Rating: (92)
no center bore is to small
AGP S256 FS
Old 11-01-2009, 09:13 PM   #3 (permalink)
how would u make them work just grind it out tell it fit
Old 11-01-2009, 09:13 PM   #4 (permalink)
what is srt 4 center bore
Old 11-01-2009, 10:31 PM   #5 (permalink)
ATaylorRacing's Avatar
Member Number: 62238
The WRX is 56.1 mm and ours is 57.1 so very minor grinding should allow it to clear hub.
Another thing is that they have a 55mm positive offset while we have a 45mm set up....this means that using their rim in place of ours and with the 205x50x17 tire your sidewalls will stick in towards the strut an extra .4 inches. This would be okay since that is the same amount of less clearance as if you had put a 225x45x17 tire on the stock SRT4 rims. You might have clearance troubles trying to use their rims (after the center bore issue is solved) with a larger 225x45 tire...this would have the sidewall stick in towards the strut .8 inches more than our stock set up.
35 time NHRA/IHRA champ
12.87 @ 110 05 SRT4 stage 2 / DOTs
15.17 @92 05 V6 stock Mustang / wifes
1790 lb 84 Horizon / winningest fwd car
19.84 @ 65 96 Geo Metro 3 banger
ATaylorRacing is offline   Reply With Quote
Old 11-02-2009, 01:01 AM   #6 (permalink)
well i have 225/40/18 on there now with stage 3 coilovers from dodge so its pretty low and the wrx rims am thinking about getting are 205/50/16 u think i will have trouble besides the grinding
Old 11-02-2009, 07:18 AM   #7 (permalink)
SRTforums Junior Admin
stowaway's Avatar
Member Number: 3286
the offset is the biggest problem in making them fit. You'll need extended lug studs and 8mm or 1/2" spacer to get it pushed away from the brakes and struts, depending on actual width, offset, and spoke design.
Old 11-03-2009, 01:37 PM   #8 (permalink)
If you use those 16" rims with the 205/50/16 tires your diameter will be shorter than the stock 205/50/17 SRT set up by a full inch. That will give an extra 1/2" more clearance all the way around the tire compared to the stock size but the entire package will stick in towards the chassis by 4/10th of an inch still. You might be okay with that set up once youve grinded away that 1 mm from the hub for the smaller center bore.
Old 11-03-2009, 01:39 PM   #9 (permalink)
Also....using the 205/50/16 in place of the 205/50/17 tire will have your real speed at an indicated 60 mph being 57.4 mph.....will slightly change overall gear ratio and give you a bit less mpg, but might help you from getting speding tickets.
Old 11-04-2009, 08:30 PM   #10 (permalink)
Xx_R/T_xX's Avatar
Member Number: 18749
im running 5zigen fno1r-c rims off a 06 wrx tr and i needed 6mm spacers to make them fit upfront without any rubbing issues..the back needs 3mm to clear the strut area..im actually on bc coilovers as well and running 225-45-17 tires
BIG TURBO!
Page generated in 0.15251 seconds with 13 queries
