Serious? Wow. I'll be giving my local shop a call. This explains why we had some trouble getting some of the rings to fit...
edit: Spoke to the shop, and their listing says 73. Personally, I'd say the number above is accurate. 73's will fit if you're using plastic rings, but for metal ones you're better off with the 72.62mm ones.
My number came from Centerline themselves, just wanted to clarify to make sure everyone got the right size rings.
okay i know this a dumb ? but what are these hub rings you are talking about. whats the purpose
when you purchase aftermarket rims, most of the time they don't sit nice & flush like the stock rims. This makes them shakey at high speeds & you'll bend your studs like it is your job. A $20 investment can save you lot's of little headaches in the future as well as concern for your safety. The hubcentrical rings with proper fit "matching the proper center bore & hubsize" will give you the flushness & fit of the stock setup.
Also, if you guys could limit discussion, that would be great. There are a bunch of other threads about hubcentric rings, so use the Search button. This thread is just to list the info if you have it.
