Old 10-20-2009, 04:31 AM   #1 (permalink)
SPCorBUST's Avatar
Member Number: 4476
Trader Rating: (13)
Default whats your take on the XXR 518's???
I'm thinking of either buying Work Emotion CR Kai's or XXR 518's. I was wondering what your guys' take on the best size would be on the 518's... I have BC coilovers (non-inverted) with stock calipers.
17" x 7" 5/100 48 offset 19 lbs $129.99
17" x 8.5" 5/100 48 offset 21.6 lbs $129.99
18" x 7" 5/100 48 offset 20 lbs $149.99
18" x 8.5" 5/100 48 offset 23.5 lbs $149.99
got the info from this site
XXR 518 - Gold Wheels - Wheel Size & Price Details - 1010tires.com
From the looks of it, I could go up in size and out for traction at the negligible cost of $20 per wheel with the 18x8.5. That would be my first pick but I also like the 17x8.5 because I could get traction and same rim size (as stock) for about the same weight as the stock rim. Thoughts?
also, anybody know what the wheel bore size is??? i can't find it and i want to make sure that they'll fit...
what will i need to do to make the 48 offset fit? an 8 mm spacer?
SPCorBUST is offline   Reply With Quote
Old 10-20-2009, 04:57 AM   #2 (permalink)
Member Number: 36825
The rims are fine they are good priced. I like there mesh ones they sell check on the off set some cars have problems with that because of the calipers. There is a rim off set topic on the forum youll have to look it up.I say go for it if you like the design.
SRT Jeff is offline   Reply With Quote
Old 10-20-2009, 05:34 AM   #3 (permalink)
nutz's Avatar
Member Number: 41700
Trader Rating: (19)
I have some XXR's on my DD they are OK (heavy as shit) but the price is right I got 4 new W/ tires and lugs for 500 bucks (mine are BBS style with red lip)
Old 10-20-2009, 10:22 AM   #4 (permalink)
SPCorBUST's Avatar
Member Number: 4476
Trader Rating: (13)
what offset? i noticed that this style only comes in 48 and the tech guide says it should be between 35 and 40
Old 10-20-2009, 12:04 PM   #5 (permalink)
morgantj13's Avatar
Member Number: 47175
id go for the lighter(well, lighter compared to the 18) 17x8.5...
but def. check to make sure they'll fit of course
Old 10-21-2009, 10:22 AM   #6 (permalink)
SPCorBUST's Avatar
Member Number: 4476
Trader Rating: (13)
is 17x8.5 even safe to run? its not listed in the tech guide, just 17x8. but 18x8.5 is listed...
Old 10-21-2009, 04:49 PM   #7 (permalink)
jnathan68's Avatar
Member Number: 59167
Trader Rating: (43)
17x8.5 is possible but not in a 48mm offset. The recommendation for a 17x8 wheel is a 35mm to be on the safe side and that is with coilovers. Not even sure a 7.5 inch wheel will fit with a 48mm offset and if it did, you would probably not want to go wider than a 225/45 tire.
I by no means know for sure that it won't fit but from everything I read, I would try to find a different offset or limit myself to a 7" wide wheel at a 48mm offset.
jnathan68 is offline   Reply With Quote
Old 10-21-2009, 06:43 PM   #8 (permalink)
SPCorBUST's Avatar
Member Number: 4476
Trader Rating: (13)
so then you think the 17x7 in 48 is my best bet of the 4 options? i haven't seen any other offsets in our bolt pattern...
Old 10-21-2009, 07:02 PM   #9 (permalink)
jnathan68's Avatar
Trader Rating: (43)
Truthfully, I am not ever sure the 17x7 48mm offset will work but that would be your best bet out of the 4 options.
Here is the thread you want to read before buying - The WHEEL & TIRE TECH Thread
Old 10-21-2009, 09:27 PM   #10 (permalink)
SPCorBUST's Avatar
Member Number: 4476
Trader Rating: (13)
yeah i've referenced that thread a few times in here
Old 10-21-2009, 11:40 PM   #11 (permalink)
jnathan68's Avatar
Trader Rating: (43)
Ahhh..sometimes reading owns me.
BTW - In your original post, you mention 8mm spacers. To run 8mm spacers safely, you should get extended studs all the way around. I ran 5mm spacers on the rear with stock studs and didn't feel like I was getting enough threads.
Page generated in 0.17162 seconds with 13 queries
