Old 06-18-2008, 04:43 PM   #1 (permalink)
Rymanrph's Avatar
Member Number: 31633
Default What offset do I need to go lower?
Right now I have 18x8 Tork Champions on the car with BC coilovers, but I can't go very low (less than about a 4 finger gap) in the back because my tires will rub (225/40/18) around corners. I used to have goldlines and my tires rubbed when I had those. I'm looking to sell the wheels I have and get some new 18s, but I want to make sure that these won't stick out so far so that I can drop the tail end of the car more.
What offsets should I look for in a 7.5" and 8.0" wheel? I can't seem to figure out what the offset of my current rims are. I think they're 38, but I'm not sure. Its supposed to be stamped on the back of the wheel, but it's not.
Obviously, I'm not as worried about strut rub since I have coilovers. Thanks for your input.
Buick - 1; SRT-4 - 0. This car is under construction. Stage 1, BWoody H-Brace & Traction Bars, BWoody Catch Can, ACR Rear Sway Bar, Mopar Catback, Ebay Intake, BC Coilovers, Mopar STS, 18x8 Tork Champions, Fiber Images CF Hood, MPX Intercooler, Slow Boy Racing Crash bar, LED/Halo Headlights, JMB Hard Pipes, HKS SSQ BOV. My car is slower than yours
Sitting at the paint shop. Now I just have to wait.
Rymanrph is offline   Reply With Quote
Old 06-18-2008, 07:39 PM   #2 (permalink)
Member Number: 31283
do you rub on your fenders? cause this is about the same set up i'm going to go with except maybe 18x8.5 maybe x8 depends on the wheel i choose. I wanna go low too but this is what i'm afraid of. Do you have any pics?
black03 is offline   Reply With Quote
Old 06-18-2008, 07:49 PM   #3 (permalink)
bpsrt4's Avatar
Member Number: 40796
Trader Rating: (27)
Roll your fenders, and run a bit of negative camber...I have 8" wide 35mm offset wheels w/ a 225 tire and I've got plenty of room in the back
bpsrt4 is offline   Reply With Quote
Old 06-18-2008, 08:08 PM   #4 (permalink)
Wheels & Tires Moderator
evo77's Avatar
Member Number: 1346
The higher the offset, the more the wheel will sit inward.
The lower the offset, the more the wheel will sit out.
If your looking to go pretty low then stick with a 7 or 7.5 inch wide wheel in a 40-45 offset. A 8 inch or up may limit you with your drop because you have to use a lower offset.
evo77 is online now   Reply With Quote
Old 06-18-2008, 08:11 PM   #5 (permalink)
bpsrt4's Avatar
Trader Rating: (27)
Don't make me post pics
I haven't even rolled the rear fenders and the top of the tire is tucking slightly, absolutely no rubbing...the front is a different story though
Old 06-18-2008, 08:23 PM   #6 (permalink)
evo77's Avatar
Member Number: 1346
Anything short of having to run negative camber, rolling fenders or some other modification, will result in SOME rubbing depending on how low you actually set the height.
If the OP doesn't mind doing the above then the possibility of rubbing is minimized. If he doesn't want to do the above and he wants to definitely go lower than his current coilover position, then the only option he has is to reduce his wheel width and increase his offset.
Old 06-18-2008, 08:26 PM   #7 (permalink)
bpsrt4's Avatar
Trader Rating: (27)
Oh I understand what your saying, but I'm not even talking about a lot of negative camber -1.5* or so in the rear
Old 06-18-2008, 09:19 PM   #8 (permalink)
Rymanrph's Avatar
The problem is finding the offset. Its not listed on a lot of sites. What are the disadvantages of rolling the fenders? I'm repairing my car from an accident, so I'll be repainting the car, so I'm not worried about the paint cracking. I'd imagine running negative camber would cause uneven tire wear right?
Old 06-18-2008, 09:21 PM   #9 (permalink)
bpsrt4's Avatar
Trader Rating: (27)
If you keep it to a reasonable amount there will be little to know difference in tire wear...
I don't really know of any disadvantages of rolling the fenders
Page generated in 0.25695 seconds with 11 queries
