Old 03-06-2007, 02:08 PM   #1 (permalink)
SRTforums Junior Admin
stowaway's Avatar
Member Number: 3286
Default Tire recommendations for the SRT-4 updated 10-27-2009
Tire recommendations, in no particular order.
16x7 wheels
225/50-16
Max dry performance - expect maybe 15k miles:
Yokohama Advan Neova AD07
BFGoodrich g-Force T/A KD
Kumho ECSTA MX
Falken Azenis Rt615
Hankook Ventus R-S2 Z212
Great wet and dry performance - expect 15-25k miles:
Bridgestone Potenza RE050A Pole Position
Goodyear Eagle F1 GS-D3
Good wet and dry performance - expect 20-30k miles:
Avon Tech M500
BFGoodrich g-Force T/A KDW
Bridgestone Potenza RE750
Kumho ECSTA SPT
Firestone Firehawk Wide Oval
Fuzion ZRi
Michelin Pilot Exalto PE2
Falken FK 452
Good wet and dry grip, with some winter weather capabilities - expect 25-35k miles:
Avon Tech M550 A/S
Kumho ECSTA ASX
Yokohama ADVAN S.4.
Bridgestone Potenza RE960AS Pole Position
Falken Ziex Ze 512 (make sure you get the V speed rated, not the H speed rated version)
Toyo Proxes 4
245/50-16 - This size is tall, coilovers will let these fit nicely if you don't drop the car too much. Most are 25.6-25.7" tall.
Avon Tech M500
Fuzion ZRi
Kumho ECSTA SPT
Avon Tech M550 A/S
Kumho ECSTA ASX
Yokohama ADVAN S.4.
Falken Ziex Ze 512 (make sure you get the Z speed rated, not the H speed rated version)
Toyo Proxes 4
Michelin Pilot Sport A/S
Decent all-around tire, drop off from stock grip - expect 30k+ miles:
Goodyear Eagle RS-A
Stock wheels
205/50-17
Avon Tech M500
BFGoodrich g-Force T/A KDW 2 (stock tires)
Kumho ECSTA SPT
Falken FK 452
Avon Tech M550 A/S
Kumho ECSTA ASX
Yokohama ADVAN S.4.
Goodyear Eagle RS-A
Michelin Pilot Exalto A/S
Pirelli P6 Four Seasons
215/50-17
Avon Tech M500
Kumho ECSTA SPT
Fuzion ZRi
Avon Tech M550 A/S
Kumho ECSTA ASX
Toyo Proxes 4
Falken Ziex Ze 512
Goodyear Eagle RS-A
Yokohama AVID V4S
17x7 wheels
225/45-17
Falken Azenis RT-615
Bridgestone Potenza RE-01r
Kumho ECSTA MX
Hankook Ventus Rs2 Z212
Continental ContiSportContact 3
Michelin Pilot Sport PS2
Avon Tech M500
Kumho ECSTA SPT
Falken FK 452
Fuzion ZRi
Avon Tech M550 A/S
Kumho ECSTA ASX
Yokohama ADVAN S.4.
Pirelli PZero Nero M&S
Falken Ziex ZE-512
Toyo Proxes 4
17x7.5 wheels
235/45-17
Kumho ECSTA MX
Avon Tech M500
Kumho ECSTA SPT
Falken FK 452
Fuzion ZRi
Avon Tech M550 A/S
Kumho ECSTA ASX
Yokohama ADVAN S.4.
Falken Ziex ZE-512
Toyo Proxes 4
BFGoodrich g-Force T/A KDWS
17x8 wheels
235/40-17
Bridgestone Potenza RE-01R
Yokohama ADVAN Neova AD07
Falken Azenis Rt615
Kumho ECSTA SPT
Falken FK 452
Fuzion ZRi
Kumho ECSTA ASX
245/40-17
Kumho ECSTA MX
Avon Tech M500
Kumho ECSTA SPT
Falken FK 452
Fuzion ZRi
Kumho ECSTA ASX
Toyo Proxes 4
Yokohama ADVAN S.4.
18x7.5 wheels
225/40-18
Falken Azenis Rt615
Kumho ECSTA MX
Avon Tech M500
Fuzion ZRi
Kumho ECSTA SPT
Falken FK 452
Avon Tech M550 A/S
Kumho ECSTA ASX
Yokohama ADVAN S.4.
Falken Ziex ZE-512
Toyo Proxes 4
18x8 wheels
235/40-18
Falken Azenis Rt615
Kumho ECSTA MX
Fuzion ZRi
Kumho ECSTA SPT
Falken FK 452
Avon Tech M550 A/S
Kumho ECSTA ASX
Yokohama ADVAN S.4.
Falken Ziex ZE-512
Toyo Proxes 4
ACR Owners
16x7 wheels
225/45-16
Kumho ECSTA SPT
Falken FK 452
17x8 wheels
235/40-17 - This size is sketchy, a few confirmed cases of them fitting, others saying contact in the rear on the lower spring perch. Use at own risk and don't consider it as a definite fitment on all cars. These tires are 24.3" tall or shorter, but still over 1/2" taller than stock.
245/35-17 - These tires should be used with caution. Load rating is lower than Dodge's spec. Height is ok.
Falken FK 452
Old 03-06-2007, 02:08 PM   #2 (permalink)
stowaway's Avatar
Member Number: 3286
Default Tire recommendations for the SRT-4 - Updated 10-27-2009
OK, I hope to rework the first post soon with all of the new tires. I'm not going to give the breakdown in sizes just yet but I will give you the performance categories and the top selections for what I feel can fit either the best performance in that category or the best value for the category. None of these are in any particular order, just as I see/type/remember them.
Extreme Performance Tires
Yokohama Advan Neova AD08
Hankook Ventus R-S3
Kumho Ecsta XS
Bridgestone Potenza RE-11
Nitto NT-05
Dunlop Direzza Sport Z1 Star Spec
Maximum Performance Tires
Bridgestone Potenza RE-050a Pole Position
Continental Conti SportContact 3
Continental ExtremeContact DW
Hankook Ventus V12 evo K110
Sumitomo HTR Z3
Dunlop SP Sport Maxx TT (new and not much info yet)
Goodyear Eagle F1 Asymmetric
Pirelli PZero (just this, no other words in model name. very important)
Ultra High Performance Tires
BFGoodrich g-Force Sport
Bridgestone Potenza RE760 Sport
Kumho Ecsta SPT
Fuzion ZRi
Yokohama S.drive
Ulta High Performance All Season Tires
BFGoodrich g-Force Super Sport A/S
Goodyear Eagle F1 All Season
Goodyear Eagle GT
Yokohama Advan S.4.
Yokohama Avid W4S
Kumho Ecsta ASX
Falken Ziex ZE-912
Now, given that list, and hopefully you've gone through and thought about what priorities you have for your tires (cost, wet grip, steering response, ride quality, ultimate dry grip), you have to make the final choice. Tires marked in GREEN are going to be the value leaders and likely give up some performance, both wet and dry, compared to other tires in the class. Italicised tires will generally give the best dry performance in the given class.
Old 02-18-2009, 05:29 PM   #3 (permalink)
Member Number: 66834
Quote: Originally Posted by stowaway View Post
Tire recommendations...
Ok now this is based on a 16x7 wheel? like the acr wheels?
Anthony8800 is offline   Reply With Quote
Old 02-18-2009, 05:31 PM   #4 (permalink)
stowaway's Avatar
Member Number: 3286
Yes, a 7" wide wheel can be used on that size tire, like an ACR wheel. Though you may need a spacer due to tire width.
Old 02-18-2009, 08:39 PM   #5 (permalink)
Member Number: 61830
Trader Rating: (17)
hey stow, just a headsup. the potenza re760 sport took the spot of the potenza re750. the re750 has been discontinued for about a year now.
Spaz_22 is offline   Reply With Quote
Old 02-18-2009, 09:05 PM   #6 (permalink)
stowaway's Avatar
Member Number: 3286
I know. Look when this post was made. I haven't had a chance to go back and make a complete new list. There's a lot of stuff that needs updating but I haven't had the time lately to do it.
Old 02-18-2009, 09:36 PM   #7 (permalink)
Trader Rating: (17)
ha, reading owns me, sorry bro
Old 02-19-2009, 08:28 AM   #8 (permalink)
roadflare16's Avatar
Member Number: 41558
Trader Rating: (25)
ok, i'm still kinda new to tire sizing, but i thought that for a factory rim if you wanna go with a 215 you should drop it down to a 45 to keep as close to the same height and speedo accuracy, but there's nothing suggesting that. am i wrong or does it not really matter?
roadflare16 is offline   Reply With Quote
Old 02-19-2009, 09:34 AM   #9 (permalink)
stowaway's Avatar
Member Number: 3286
You are wrong and it does matter.
The stock 205/50-17 is 25.4" tall. 215/50-17 are 25.5" tall. No problems at all with speedometer accuracy. 215/45-17 are 24.6" tall. Also, EVERY 215/45-17 requires a 7-8" rim width, not our stock 6". A 215/50-17 can be used on a 6-8" wide wheel. Also, Dodge had a load capacity rating of 89 for the SRT-4. Most 215/45-17 tires only have an 87 rating.
Old 02-19-2009, 09:44 AM   #10 (permalink)
KBizzle's Avatar
Member Number: 30144
Trader Rating: (28)
you made that original post on my b-day a couple years ago!
i have been really liking my 215/50/17 Falken Ziex 912s running on an aftermarket 17" rim... i think the width is probably 7" but im not positive as they were free, so i didn't ask many questions.
KBizzle is offline   Reply With Quote
Old 02-19-2009, 09:55 AM   #11 (permalink)
SRTie4k's Avatar
Member Number: 45499
Trader Rating: (53)
Bump for updated info. I have faith in you stow.
2008 Mazdaspeed 3
- Cobb SRI, Short Shift Plate, SU Solid Shifter Bushings, 18x8 Konig Runaway's
2008 Kawasaki Z1000
- Laser X-Treme Exhaust, -1 Front Sprocket, Speedohealer, Renthal Ultra-Low Bar, CRG Bar End Mirrors, Pazzo Levers, Motovation Frame Sliders, Targa Fender Eliminator, OEM Rear Cowl
2001 Kawasaki Ninja 250
- For sale soon...
Old 02-19-2009, 09:57 AM   #12 (permalink)
stowaway's Avatar
Member Number: 3286
I just need to find time. I have tons of crap going on at work.
And honestly I'm waiting for the next batch of tires (RE-11, RS-3, AD08) to hit the streets in March to get a feel for it. If they are what I think they will be I'll be removing some tires from some of the categories.
Old 02-19-2009, 10:48 AM   #13 (permalink)
Trader Rating: (25)
Ok, well good thing I didn't buy new tires yesterday then! Well, I went to the local shop and pretty much said I'm looking for something sporty but not pricey, it doesn't need to be the sweetest thing since sliced bread since I'll have slicks for the track, but I want something other than my pirelli all-seasons. He suggested cooper zeon zpt's, they're like $98/each installed and whatnot. Any opinion on them? The other suggestion he had was yokohama s-drive's which were a little more.
Old 02-19-2009, 10:54 AM   #14 (permalink)
stowaway's Avatar
Member Number: 3286
The ZPT is only rated to 130mph and aren't going to be great for overall performance. Do you NEED an all-season tire? I don't think so because the s-drive is only a 3 season tire and as such it will deliver better dry performance.
Old 02-19-2009, 10:58 AM   #15 (permalink)
Trader Rating: (25)
No I've got my honda for the winter. I only got those because at the time there was like a sudden snow storm and I was like F this, my pretty much bald summer tires can't take it. So I slid into a belle tire and it was either get rims and cheap snow tires or get the pirelli's for the factory ones. In hindsight, I should've gotten the rims haha. I've got some alignment issue though and since the outside of one of them is worn almost all the way down while the inside is like brand new, I figured with summer around the corner, new tires and an alignment would be nice. I really don't plan on going over 130 with whatever tires I get, I just want something kinda sporty for the street. Most if not all of my racing will be at the track, my street racing days are done.
Page generated in 0.15676 seconds with 13 queries
