Old 07-06-2008, 03:02 PM   #1 (permalink)
636BOYZ's Avatar
Member Number: 48645
Default sportmax 002
heres a pic of a sportmax 002 with a 0 offset
636BOYZ is offline   Reply With Quote
Old 07-06-2008, 06:38 PM   #2 (permalink)
Extreme3Drc's Avatar
Member Number: 33782
Those would be pimp staggard on a shelby or conquest.
BUTTER BEAN
Extreme3Drc is offline   Reply With Quote
Old 07-06-2008, 06:45 PM   #3 (permalink)
addictedtosin's Avatar
Member Number: 30537
Trader Rating: (114)
I will be interested to see them mounted with tires and on the car. What size tires do you plan on using?
addictedtosin is online now   Reply With Quote
Old 07-06-2008, 06:59 PM   #4 (permalink)
636BOYZ's Avatar
225/45s or 225/50s dk as of yet
Old 07-06-2008, 08:04 PM   #5 (permalink)
JPG
JPG's Avatar
Member Number: 41528
I thought these would not fit?
JPG is offline   Reply With Quote
Old 07-06-2008, 08:31 PM   #6 (permalink)
636BOYZ's Avatar
they will fit in the back with out any spacers but in the front u will need a
5mm spacers
Old 07-06-2008, 08:55 PM   #7 (permalink)
JPG
JPG's Avatar
awesomeness!
Old 07-07-2008, 01:11 AM   #8 (permalink)
my_little_srt's Avatar
Member Number: 41179
What size are those??? They look small as sh!t............
my_little_srt is offline   Reply With Quote
Old 07-07-2008, 06:28 AM   #9 (permalink)
636BOYZ's Avatar
16 by 8
Old 07-07-2008, 08:04 AM   #10 (permalink)
Quote: Originally Posted by 636BOYZ View Post
16 by 8
To small IMO......................
Old 07-07-2008, 08:10 AM   #11 (permalink)
1LAPSRT's Avatar
Member Number: 38267
Trader Rating: (19)
225/50 is almost the same height as stockers....
The 225/45 is over an inch shorter!
Heading for a new track? Just want to improve your times at a track you already run?
Old 07-07-2008, 08:06 PM   #12 (permalink)
I wish you luck in getting them to fit. If you do you will have done something really cool. in the pics the lip is out past the fender. You might be able to make it fit if you stretch a 215 45 16 on there. I would go with a short tire as you will have more room for the A arm to fold up and slightly in over bumps. Make sure to mount only one and try it on all four corners. Just mentioning it so that if they dont work out you can return them and not be out too much dough. Looking forward to seeing pics of it with tires mounted and all put on the car.
Old 07-07-2008, 09:59 PM   #13 (permalink)
Wheels & Tires Moderator
evo77's Avatar
Member Number: 1346
Sorry but the wheel specs don't lie. There is no "making them fit". They don't fit. And least not the way they should.
You'll find that once the tires are on they WILL stick out past the fender.
Not trying to be a hater or anything. I like to see people try different things but sometimes it is what it is.
Old 07-08-2008, 03:07 AM   #14 (permalink)
Member Number: 25409
I think I was the first one to do this but hes right they will not fit unless you roll the fenders, stretch the tire to about a 205/40, slam it and camber the shit out of the wheels, but and even then they still spyder out.....the fronts are even worse...you can try but it looks too crazy trust me....
2005 SRT-4 ACR
"REPPIN 209 STOCKTON CALI"
gen1a420 is offline   Reply With Quote
Old 07-08-2008, 02:03 PM   #15 (permalink)
BobRoss46n2's Avatar
Member Number: 23740
Awe c'mon....It'll fit!
Until the fender slices the back tire in half after the first bump
or the fender digs into the front tire after the first corner at ANY speed.
BobRoss46n2 is offline   Reply With Quote
