Old 01-24-2006, 11:09 AM   #1 (permalink)
Member Number: 37753
Default ROTA 18" sub-zeros + tires
Hey wassup, i was tryin to buy some rota sub-zeros but the sales rep. told me the offset was gonna b too high or it would rub on the side of the strut, but ive seen some srt's wit them on!?? If anyone can help me out cuz ive heard bout spacers but most ppl dont recommend that so if anyone can juss let me kno that would b great!! And what kinda tires size?? or u can IM me on PR00787 thanks
Edmorales06 is offline   Reply With Quote
Old 01-24-2006, 02:01 PM   #2 (permalink)
Elected Moderator
stowaway's Avatar
Member Number: 3286
18 x 7.5 +45 offset 4h/5h x 100/114.3
45mm offset is too high for that rim width, you'd need to run a ~5mm spacer.
http://www.rotawheels.com/wheels.php
Old 01-24-2006, 04:03 PM   #3 (permalink)
Wheels & Tires Moderator
evo77's Avatar
Member Number: 1346
No it's not. I've ran this size and offset before without any issues.
Old 01-24-2006, 04:08 PM   #4 (permalink)
Elected Moderator
stowaway's Avatar
Member Number: 3286
really? hmmmmmm. if my wheels are really 40mm offset like tirerack says, they are REALLY damn close to coilovers and that extra 1/4" width plus the offset change I thought would get too close, plus the tech sticky says "7.0-7.5 inch wide wheels generally fit with offsets of 35-40mm".
Old 01-24-2006, 04:17 PM   #5 (permalink)
evo77's Avatar
Member Number: 1346
You sure they gave you 40 offset? Did you see the stamp on the back of the wheel?
The only other thing I can think of is that the mounting pad of your ASA is smaller than some other wheels which would result in higher offset sitting wheel.
Old 01-24-2006, 04:18 PM   #6 (permalink)
evo77's Avatar
Member Number: 1346
You also missed an important piece in bold red from the Wheel Tech sticky...
On that same note this does not imply that a wheel with a 42 or 45mm offset will not fit over the calipers. It will all depend on the spoke design of that particular wheel. There are plenty of wheels with a 42mm or 45mm offset that fit but there are also just as many that do not.
Old 01-24-2006, 05:17 PM   #7 (permalink)
Elected Moderator
stowaway's Avatar
Member Number: 3286
i don't remember checking, but caliper clearance is great. I'll have to wait for a few days before i can check.
Page generated in 0.17815 seconds with 11 queries
