Old 06-13-2008, 05:30 PM   #1 (permalink)
Member Number: 32921
Default Question about wheel shaking at high speed
well not that high speed. ~50mph and the faster you go the worse it gets. I just put 2 15"s with DRs on my car. The stock lug nuts seemed to fit fine, however Im getting the tuner lug nuts tomorrow.
However one of my friends told me I need a ring to go around the ?HUB? (the inner most part of the wheel) because the one on the 15s is a little bigger then the one on the stock bbs wheels.
BFG 225 50 15s on MB meshx
the wheels and tires im using
STAGE 1 | AGP WGA | MBC | Needswings v5 DP | Maddog 80%
freeze is offline   Reply With Quote
Old 06-13-2008, 09:07 PM   #2 (permalink)
Elected Moderator
stowaway's Avatar
Member Number: 3286
yes, hub centric rings are very good to have, and you need to make sure you've removed the crush washer from the lug studs.
Old 06-13-2008, 11:00 PM   #3 (permalink)
JustForWheels.com
good?
ty again stow, always answer every question I have
Old 06-15-2008, 05:30 PM   #4 (permalink)
Member Number: 7176
Trader Rating: (12)
make sure the wheels are balanced correctly also
8krdlne is offline   Reply With Quote
Old 06-16-2008, 09:06 AM   #5 (permalink)
yea I was in the garage while they were balanced.. so i know they are good.
Old 06-16-2008, 09:27 AM   #6 (permalink)
Member Number: 2096
If the bore for the hub on the wheel is larger than the hub's bore on your car, then you're lining up the wheel with the lugs and moves it off center just a hair. It'll make your wheels feel like they're not balanced properly. You need to measure the bore of your wheel and get hubcentric rings that are the size of your bore by the size of the SRT hub, which is 57.1mm. If you have a 65mm wheel bore then you need a 65mm x 57.1mm hub ring.
xmdfmk7x is offline   Reply With Quote
Old 06-16-2008, 09:59 AM   #7 (permalink)
yea I think the link i have above is to the correct rings.. i guess ill call Discount Tire and see if those are the correct sizes.
thanks
Old 06-16-2008, 10:03 AM   #8 (permalink)
siberian57's Avatar
Member Number: 37918
Trader Rating: (23)
^^check this crush washer. Stowaway told me to do this as I was getting the same exact problems as you, we took it off and it fixed the problem.
R.I.P. Shadow, I'll miss you buddy
siberian57 is offline   Reply With Quote
Old 06-25-2008, 09:59 AM   #9 (permalink)
crush washers were all removed when I changed my pads/rotors..
Maybe its the lug nuts after all.
Old 06-25-2008, 11:24 AM   #10 (permalink)
beyondspexj's Avatar
Member Number: 30264
Trader Rating: (30)
your running no spacers right?
beyondspexj is online now   Reply With Quote
Old 06-25-2008, 07:05 PM   #11 (permalink)
addictedtosin's Avatar
Member Number: 30537
Trader Rating: (114)
hubcentric rings and tuner lugs should fix the problem.
12.0@120 on DRs and 93oct.
addictedtosin is offline   Reply With Quote
Old 06-25-2008, 07:58 PM   #12 (permalink)
SRToc Member
gargoile's Avatar
Member Number: 931
How are you tightening the lugs ? Are you tightening them by hand and let the car down than torquing them or are your torquing them when the wheel is off the ground.?
gargoile is offline   Reply With Quote
Old 06-26-2008, 07:51 PM   #13 (permalink)
Member Number: 27043
im currently having the same problem. but i took off the crush washers, i have spacers, and i have special lugs becuase regular lugs wouldnt fit. but i put the car up in the air and spun the wheels and they are all wobbling badly, then i spun them on a balancing machine and they were fine. so i put the spare tire on the car to see if the car is the problem but the spare spun perfectly straight
element10 is offline   Reply With Quote
Old 06-26-2008, 10:37 PM   #14 (permalink)
Trader Rating: (30)
your spacers are whats causing your shaking. the wheel isnt sitting on the hub 100% so it is not "hub centric". same happened to me after putting on 3mm spacers up front. hit 80mph and get a lil shake.
Old 07-13-2008, 03:28 PM   #15 (permalink)
Ok, i got the tuner lugnuts and the hub centric rings.
those rings fit so perfect.. as did the lugnuts.
wheel shakes like nuts over 50mph still.
Gonna bring wheels back to maybe get rebalanced??? idk.
anything else it could be?
Page generated in 0.19181 seconds with 11 queries
