Old 10-06-2009, 10:09 PM   #1 (permalink)
Member Number: 56190
Default Pic request Rota Wheels on SRT4
I found a set of wheels I love, but would like to see them on an SRT4 before I buy.
They are 18" Rota Grid and look like this:
96 LSC
98 CE
04 E-Blue SRT-4
k9t8m is offline   Reply With Quote
Old 10-06-2009, 10:25 PM   #2 (permalink)
conroy9940's Avatar
Member Number: 46401
Trader Rating: (114)
just buy them... they'll look good.
Pittsburgh Penguins 15-8-0 28 points
Old 10-07-2009, 06:23 PM   #3 (permalink)
MystrySkittle's Avatar
Member Number: 62080
they will look good i bet, but the offset wont be so wild like afrins car. the spokes will be more straight
the only size in our bolt pattern is the 17x7.5, but it has a 48mm offset so you'll need ~8mm spacer with extended lug studs to make it fit.
_________
^found from over 2 years ago with search written by sto
but the Raze r74 if they make it looks somewhat close and are pretty cheap.
big turbo here i come!
Quote: Originally Posted by kup@l View Post
I'm too much of a mangina..
MystrySkittle is offline   Reply With Quote
Old 10-07-2009, 08:26 PM   #4 (permalink)
evo77's Avatar
Member Number: 1346
S2 no toys, Mopar bov, AGP bfmic, 3" turboback
Old 10-07-2009, 08:32 PM   #5 (permalink)
Member Number: 29844
Trader Rating: (122)
If we could only have a different offset for our cars these wheels would be money!
But they will not have the concaveness that the subarus or evos will have.
EvilFlameRedSrt is online now   Reply With Quote
Old 10-07-2009, 09:43 PM   #6 (permalink)
emilio's Avatar
Member Number: 58886
hmm. wider rim = deeper spoke depth? for grids at least
emilio is offline   Reply With Quote
Old 10-08-2009, 09:56 PM   #7 (permalink)
i blieve the evos have a 20 offset or so which is y the rim curves in so much and looks alot better. since our offset is so high 35 plus it makes for a more straight rim
Old 10-09-2009, 08:43 AM   #8 (permalink)
SRT-4runner's Avatar
Member Number: 68134
Trader Rating: (36)
This. Its all in the offset!
Vtec Slayer
SRT-4runner is offline   Reply With Quote
Old 10-09-2009, 11:04 AM   #9 (permalink)
Member Number: 56029
evo77 car looks good, which Rotas are those? and what size?
mannysx is online now   Reply With Quote
Old 10-11-2009, 09:13 AM   #10 (permalink)
Member Number: 33203
Trader Rating: (25)
Those are grids and I'm thinking they're 18x8.5 but I could be wrong.
Precision 6057@30psi on pump
8.50@87 on 10psi w/2.0 60 ft (wg pressure on 30 psi tune, no 2 step)
Contact Turbo666/TDSaaron for your tuning needs.
turbojonsrt4 is offline   Reply With Quote
Old 10-12-2009, 02:56 AM   #11 (permalink)
Member Number: 74866
biggest available size for these wheels on rotas website are 17x7.5
prmsrt4 is offline   Reply With Quote
Old 10-28-2009, 12:36 AM   #12 (permalink)
SRTFighter's Avatar
Member Number: 10108
I found this website that says they can get rota grids in a 18x10 +35 offset in our bolt pattern. I wonder how? Rota Grid
SRTFighter is offline   Reply With Quote
Old 10-28-2009, 05:43 PM   #13 (permalink)
evo77's Avatar
Member Number: 1346
You can get any Rota wheel as a custom order however I don't think I have to tell you that this size is way too big.
Old 10-30-2009, 12:31 AM   #14 (permalink)
SRTFighter's Avatar
not if you had the right offset, I'm thinking you would have to have nearly a zero offset. I have been told a +20 to +25mm offset would work too. I know they will stick out from the fender well and look ugly but i probably won't use these for DD purposes.
Old 10-30-2009, 10:27 AM   #15 (permalink)
evo77's Avatar
Member Number: 1346
When we discuss proper wheel/tire fitment this is always assuming that the fenders remain unmodified because 99% of us don't take the extreme route to install wheels that are impractical for daily use.
There is NO POSSIBLE WAY regardless of offset that a wheel of that size will fit with stock fenders.
If you're thinking about not modifying your fenders and just let them stick out, good luck. Unless you plan to corner like a pansie your fenders and tires will be damaged.
Page generated in 0.16594 seconds with 13 queries
