Old 12-03-2007, 06:57 AM   #166 (permalink)
Member Number: 55255
oooky So i have 18s, And i need to get new tires anyway. So im lookin to get some ALL seasons! Ive found a few in my range.
225/40/18s
Some kuhmo Ecsta ASTs
Then some falken Ziex ZE-912
Any imput would be great because i need to get these summer tires changed out!
Habitathxxxc is offline   Reply With Quote
Old 12-04-2007, 06:25 AM   #167 (permalink)
MEandmySRT's Avatar
Member Number: 41195
225/40/18s
i like the kuhmo's better.
2005 Stone White ---> TRADED <--- 05/15/2008
Stage 2 + Mopar supporting mods
...Next: Stage 3 (Guess Not)
MEandmySRT is offline   Reply With Quote
Old 12-04-2007, 11:55 AM   #168 (permalink)
isthatguy's Avatar
Member Number: 49055
ok you winter wheel sizing gurus.. I have searched for the exact size of these wheels on google and cant find it, but does ne one know..
Quote: Originally Posted by isthatguy View Post
anyone know if these will fit?
they are 15" wheels not sure on width from a lebaron GTC. here is a pic, I found them forsale on craiglist.. could be my winter wheels/tires. thanks
or these
1999 Mercedes Benz C230 P205/55R16
Quote: Originally Posted by CStyles45 View Post
Good deal. You know you need to take some pre-P90X pics so you can monitor your progress and post them up.
[NO HOMO]I am not a homo[/NO HOMO]
isthatguy is offline   Reply With Quote
Old 12-04-2007, 11:56 AM   #169 (permalink)
Member Number: 17645
Ok I finally ordered some winter tires. The bastards cost me $488 mounted and balanced out the door
These are gonna fit ok, right?
195/65/15 General Altimax Arctics on steelies.
MikeMc890 is offline   Reply With Quote
Old 12-05-2007, 08:52 AM   #170 (permalink)
MEandmySRT's Avatar
no problem on the tires, but the wheels fit really close to caliper. i'd say if you just did a brake job with new thick pads the calipers would maybe rub the wheel. that is if i'm correct in assuming that the caliper would indeed be placed closer to the wheel when placing the caliper down over the new thicker brake pads. my pads have 20k on them and the caliper probably only clears by 1 or 2 mm.
Old 12-05-2007, 09:03 AM   #171 (permalink)
missionsk8r21's Avatar
Member Number: 56407
Trader Rating: (21)
3mm wheel spacers FTW.
05 ACR
PTP SST v2.5, Mammoth Mani, S1 PCM, S2 Injectors, SAFC2, MPX FMIC, PTP 3" O2, Maxxfab catless DP, B&B Catback, TWM STS, AEM Ugeo, Aeroforce Scanguage Pro, Autometer 30/30, AGP Coldpipe w/Greddy Type-S & AGP Hotside pipe, Injen SRI, FM WGA *21/16*, Magnecore 8.5mm, NGK 4306s (.032), Ported Intake Mani + Zapp 60mm TB w/spacer, AGP Dogbones, $20 CC + PTP CV, Voxx 17" Black w/Lip Wheels, Falken 615s.
missionsk8r21 is offline   Reply With Quote
Old 12-05-2007, 03:23 PM   #172 (permalink)
MEandmySRT's Avatar
that did the trick, thanks.
Old 12-07-2007, 02:13 AM   #173 (permalink)
Member Number: 41420
This is for anyone with an ACR thats confused about buying winter wheels/tires. After a bunch of reading and testing shit, this is what Ive found...
TIRES
The following sizes are the closest to stock tire size matches and SHOULD fit without modification or strut/brake issues:
185-60-15
185-55-16
195-50-16
195-55-15
205-55-15
205-50-16
Calculated with: Tire size calculator
Pretty much any other size is to big, and will cause rubbing becuase of the strut tower perch on the ACR suspension.
WHEELS:
For wheels your gonna want a 5lugx100 bolt battern with around a 38MM offset. Any 15/16" wheel with that bolt pattern and offset will work. Tuner lugs from your local autoparts store are recommended over re-using stock lug nuts.
PT Cruiser steelies along with most if not all 1999.5-2004 Jetta/Golf wheels have the same pattern and WILL work for the SRT-4.
awesome thank you
'05 Stone White ACR
rpigeon13 is offline   Reply With Quote
Old 12-12-2007, 07:30 AM   #174 (permalink)
LilSparkPlug's Avatar
Member Number: 17636
Trader Rating: (35)
Here's a writeup on the Kelly Wintermark Magna Grip HTs. I posted it in another thread but evo wants it here. So here goes:
They are on Stratus 15" steel wheels in the front and are a 205/65R15.
They've been on the car for about a month now. Here is my reaction:
- It states they have a max of around 34psi, I found 30-32 to be too rough of a ride, so I dropped the pressure down to 28, and they ride much better. Not to mention they handle a bit better, they are very stiff tires.
- Noise: a bit noisy on the highway due to their intense tread, but nothing so obnoxious that it would deter someone from owning them. After all, we own loud cars to begin with. My car is quiet, it can be heard over the exhaust, my friend's SRT is much louder than mine and you cannot hear the tires at all.
- We've had minimal accumulation, just icy conditions and quite a bit of slush. So far in the slush, its pulled without an issue, and has had absolutely NO issues in the ice getting up the hill into my driveway.
- I decided to go without studs, and I'm glad I did, they aren't the best for cornering, but they do okay.
- Dry weather they are great, no issues so far with sand, spinning, etc in normal conditions.
- Wet weather, no hydroplaning, no sliding, but a bit of spin on a start-off is likely.
Overall, I like em! I'll give more results when we get more white stuff
Old 12-20-2007, 05:00 PM   #175 (permalink)
Member Number: 60239
What oem steelies will fit our srt-4s? local shops here don't have any steelies that will fit my srt. 16s steelies will be preferred. Thanks
TurboTom88 is offline   Reply With Quote
Old 12-21-2007, 02:28 PM   #176 (permalink)
Elected Moderator
05Flame red's Avatar
Member Number: 37340
15 inch steelies from VW fit. theres about a whole centimeter between the rim and caliper
05Flame red is offline   Reply With Quote
Old 01-17-2008, 06:13 PM   #177 (permalink)
reed32's Avatar
Member Number: 4648
Trader Rating: (24)
The Official Wheel Picture Thread - Florida Car Club Forums
here is a whole list of wheels that should fit our car
JnR Performance=envied by many in norcal
Sponsored by DCR
reed32 is offline   Reply With Quote
Page generated in 0.29508 seconds with 11 queries
