Old 10-06-2009, 09:23 PM   #1 (permalink)
Member Number: 68908
Default hp racing lighting hypersiver wheels fit on srt 4 with eibach sportline springs ?
HP RACING Lightning Hypersilver Wheel Rim Package at WheelsNext.com
wondering of those rims will fit with sportline springs 2" in the front 2.4" in the rear. if not how back would the rubbing be? ive read the wheel and tire thread so dont try to point me in that direction. any comments would be appreciated thankx.
tonsrt is offline   Reply With Quote
Old 10-06-2009, 10:12 PM   #2 (permalink)
bump plz
Old 10-06-2009, 10:40 PM   #3 (permalink)
UpShiftSRT4's Avatar
Member Number: 73592
Is the rolling diameter a match of your current diameter?
Are you going with wider rims/tires?
Post this in the wheels/tire forum to get the right attention.
2003 w/LSD
Stg.0 PCM ---Stg.1 Injectors---180º T-Stat---DSP
AEM SRI---Kinetic WGA---UPR CC---CCA BFMIC
Solid MM's---Bwoody Trans. Mount---PTP CV
QTP E-Cutout Exhaust---ED Hard Pipes
Boomba 70mm TB---AEM Wideband
MSD Wires---Mopar Blue Plate
UpShiftSRT4 is offline   Reply With Quote
Old 10-06-2009, 11:01 PM   #4 (permalink)
im going to need to go with wider tires. right know im running 215/45/17 on stockers.. going to need to go to 225/?/ 18
Is the rolling diameter a match of your current diameter? not sure
Old 10-07-2009, 09:54 AM   #5 (permalink)
Rolling diamter of a 215/45/17 =
215 x .45 = 96.75
96.75 x 2 = 193.5
193.5/10/2.540005= 7.618''
7.618'' + 17'' = 24.62'' rolling diameter (stock is 25.07'')
Wider may have confliction with the strut assembly.
Old 10-07-2009, 08:07 PM   #6 (permalink)
ok so most likely they will not fit without taking sportlines off and putting stock springs off or getting coilovers. if soo the cost is greater then what i can spend.
Old 10-08-2009, 12:10 AM   #7 (permalink)
bump please
Old 10-08-2009, 10:51 AM   #8 (permalink)
evo77's Avatar
Member Number: 1346
Bump for what?
The Wheel & Tire Tech thread already tells you about how low you can go with lowering springs and wide wheels and whether or not you will rub.
S2 no toys, Mopar bov, AGP bfmic, 3" turboback
Old 10-08-2009, 07:25 PM   #9 (permalink)
i understand what the thread says if dropped more than 2 inches then you MAY have some rubbing. im trying to find a way around this with out changing my springs again. mabe a lower profile tire instead of 225/40/18 i could go 215/40/18.
Old 10-08-2009, 09:20 PM   #10 (permalink)
evo77's Avatar
Member Number: 1346
Straight from the Wheel & Tire Tech thread. SEE THE VERY IMPORTANT BOLD SENTENCE. This will answer your question.
What if my ride is lowered on springs or on coilovers? Which sizes work without rubbing?
You can avoid any kind of rubbing by maintaining a proper ride height. If your car is dropped more than 2.0 inches than expect some rubbing on anything wider than the stock wheels. Hard cornering, passengers in the back seat and extreme bumps in the road can cause rubbing. There is no way around this. If you want those phat looking 8.5" wide wheels to go along with the massive drop on your coilovers than prepare for the fenders and tires to constantly be in contact. The good thing about coilovers is that you have the ability to adjust the height to give you the clearances needed. So please, don't ask if a certain wheel and tire will fit on your coilovers because common sense will tell you that if it doesn't you need to RAISE THE CAR! On lowering springs you don't have that luxury. Just be aware when you buy those mega drop lowering springs if you plan to buy wider wheels in the future.
Old 10-08-2009, 09:50 PM   #11 (permalink)
kk thankx for the info not trying to be obnoxious or anything just really liked those wheels they are so dam sexy. i appreciate all's info
Old 10-12-2009, 07:25 AM   #12 (permalink)
SRTforums Junior Admin
stowaway's Avatar
Member Number: 3286
since you didn't say what size wheel you have (and I don't feel like looking it up right now) then the wheel make and model have ZERO influence on what size tire you need to run. All 18x7.5 w/ 38mm offset wheels will put the tire in EXACTLY the same spot. If a 225/40-18 doesn't work then you don't really have many options that don't cause some conflict elsewhere.
Old 10-12-2009, 07:27 AM   #13 (permalink)
stowaway's Avatar
Member Number: 3286
215 x .45 = 96.75
96.75 x 2 = 193.5
stock Michelin (03) is 25.1" but stock BFG (04-05) is 25.4". You CAN NOT just go on math. You need to pull up specs on any given tire and see what is measures. Some are wider, some taller, etc and they are all technically the same size. There are even some 205 width that have more contact patch than some 225s, and some 225/45-17s that are over 1/2" shorter than what the numbers say they should be.
Page generated in 0.18789 seconds with 13 queries
