Old 10-20-2009, 04:21 PM   #1 (permalink)
bsrt's Avatar
Member Number: 52716
Default help! just bought new rims and tires
I have the megans c.o.'s and just recieved the tsw vortex 17x8 and a 245/40/17 tire. With the car jacked up a little the rim barely clears the c.o.(maybe about 1/4") and the tire looks like it's not gonna even have a chance clearing the c.o. Is it because my cars on a jack? My car is not slammed either.
Schwitzer/Borg Warner S362,DNP Manifold,AEM EMS,TialV44 WGA,AIS fmic,DSS stg5 Axels,Megans Coilovers+more.
bsrt is offline   Reply With Quote
Old 10-20-2009, 04:24 PM   #2 (permalink)
Member Number: 67038
you need a spacer. what offset are your wheels?
Delta 55 Turbo kit, agp catch can, agp solid motor mounts,scangauge and wideband, 3 bar map and tip, Injen Sri, Jmb with hks, stage 1, exhaust depot custom undercar dump, grantelli wires,DW 750's, walbro. rescale by turbo 666
AllBoost is offline   Reply With Quote
Old 10-20-2009, 04:32 PM   #3 (permalink)
bsrt's Avatar
35mm.Ugh I hate spacers.
Old 10-20-2009, 06:06 PM   #4 (permalink)
Discount Tire Direct's Avatar
Member Number: 63664
Are the new tires/wheels already mounted/balanced? If so have you set the car back on the ground to see how much clearance there is?
Lowest delivered price on tires and wheels guaranteed through the web.
1.888.459.4080
www.discounttiredirect.com
www.myspace.com/discounttiredirect Add us!
Discount Tire Direct is offline   Reply With Quote
Old 10-20-2009, 06:28 PM   #5 (permalink)
SrtKId416's Avatar
Member Number: 54183
Trader Rating: (13)
You dont need spacers with a 17x8 35mm offset...
what tire do you have though? some are wider then others
SrtKId416 is offline   Reply With Quote
Old 10-20-2009, 10:14 PM   #6 (permalink)
bsrt's Avatar
the tires are sumitomo htrzII 245/40/17. The tires are not mounted and balanced. I just placed tire inside the wheel well and took the measurements and it's to close for my liking. I want simple and reliable. I bought the rims from discounttires.com and tires from tirerack. S&h is gonna be $200.00 when all said and done. $100 rims and tires here and another $100 back. Yay.
Old 10-20-2009, 11:46 PM   #7 (permalink)
jnathan68's Avatar
Member Number: 59167
Trader Rating: (43)
It is tough to tell anything until the tires are mounted and you put everything on and tighten down. A 17x8 35mm offset with 245/40-17 should clear the coilovers without a spacer but it was tight on mine.
Some things you can play with -
1) Alignment. By this, I mean you need to loosen the coilover bottom mounting bolts and try to get as much clearance before retightening the bolts. After that, get an alignment with camber adjusted through the camber plates.
2) Height adjustment. You say you aren't slammed so I am guessing you don't want to go higher but that is an option.
3) Adjust the pre-load. You don't want to tighten too much on the spring but by bringing the bottom spring collar up, you should be able to reduce the chance for rubbing.
4) Spacers - I agree with you on the spacers, especially if you have stock wheel studs but 3mm might just gain you enough without a worry.
Otherwise a 235 tire.
jnathan68 is offline   Reply With Quote
Old 10-21-2009, 03:15 PM   #8 (permalink)
bsrt's Avatar
Thanks for the help man.
Old 10-22-2009, 04:03 PM   #9 (permalink)
mopartune's Avatar
Member Number: 60951
3mm spacers and your good!
mopartune is offline   Reply With Quote
Old 10-22-2009, 04:12 PM   #10 (permalink)
jlaymanmoto's Avatar
Member Number: 69617
The alignment kit I was telling you about will replace one of these bolts that jnathan is talking about for each side and will give that much more adjustment for some positive camber away from the coilover. I was told that these bolts will not fail and that the coilover would actually bend before the bolt would fail.
2005 Silver SRT4- Mopar Stage 2 w/o toys, AEM CAI, Mopar/Borla CBE, MSD Coil Pack, MSD Superconductor Wires, NGK Plugs, Saikou Michi Co. Dual Catch Can, PTP Checkvalve, Mopar short throw shifter, Megan Racing Coilovers, 17x8 OZ Superleggeras, 255/40/17 ContiSport Contact 3's
jlaymanmoto is offline   Reply With Quote
Page generated in 0.16634 seconds with 13 queries
