#1 (permalink) |
![]() Join Date: Nov 2011
Member Number: 86873
ok my friend just gave me a pair of slicks they are Hoosier 26x11.50-15LT he said they will fit any 15" rim 8"-10" wide so first question
will a 15" rim fit over the stock 05 SRT brakes? and if so what offset/spacer would i need to keep from rubbing the inside wheel well or strut assy? |
| Sponsored Links | |||
Advertisement | |||
#2 (permalink) |
Fresh Meat Moderator
![]() Join Date: Dec 2009
Member Number: 76568
Yes 15's will fit.
Those are HUGE slicks and youll need coilovers at least to run them. They may be too wide.
![]() Diablo CMR tuner ~Dan~ 2004 Black Neon SRT4: E85 stock turbo SOLD ![]() 310HP 436TQ 2004 Eblue Neon SRT4: E85 5558 ![]() XXXHP XXXTQ |
#3 (permalink) |
![]() Join Date: Dec 2010
Member Number: 82185
my 23X8.5X15s barely clear my coilovers I have less than a half inch of clearance between the sidewall and the coilover with 35mm offset rim.
You're going to need to do some measuring to see what offset/spacer you will need. At the very least some huge spacers with longer wheel studs and most likely will still not fit
280whp 303wtq 16g bws, injen short ram, meth injection.
Stock intercooler, manifolds, o2 housing, wastegate, and motor. Best et: 13.4 Best trap: 107 |
#4 (permalink) |
![]() Join Date: Mar 2012
Member Number: 88421
My 26x8's clear with stock struts but they stick out about a half inch past the fenders. You would need a lot of offset to clear those 11's and even then I bet they would get into the fenders when you turn.
#5 (permalink) |
![]() Join Date: Aug 2010
Member Number: 80561
it is too wide of a tire, and more than likely too tall of one as well for your horsepower needs.
Pumpking.
10.71@140. 1st SRT in TENS in CA. Thanks to: TUNED BY MINDMELT101@DRAG-ON Tuning. - http://drag-ontuning.com/blog/ GOKEY RACING for anything fabrication related instagram for updates and pics: m_santiago37 |
#6 (permalink) |
SRTforums Admin
![]() Join Date: Aug 2003
Member Number: 3286
That's a 650+ whp tire.
And it'd be a bitch to get under the fenders anyway. Sell them and go with something more correct for your power level and intended use.
| Sponsored Links | |
Advertisement | |
| Thread Tools | |
| Display Modes | |
