Old 10-30-2008, 09:16 AM   #1 (permalink)
Member Number: 65669
Default Bfg Kdw
Since I cant put those words into the search. Im looking at the BFG KDW i know the II's are more of a drag radial which is why im skeptical on purchasing those because of the chance of getting caught in the rain, unless its not really that big of a deal. So in your guys' opinion are the KDW my best option?
Phan10m is offline   Reply With Quote
Old 10-30-2008, 09:23 AM   #2 (permalink)
conroy9940's Avatar
Member Number: 46401
Trader Rating: (114)
i never had a problem with the KDW 2's in the rain... in fact, they are perfect rain/dry traction tires but there are plenty other brands that are as good if not better for a better price.. just do some research on them on like tirerack.com
Pittsburgh Penguins 15-8-0 28 points
Old 10-30-2008, 10:03 AM   #3 (permalink)
then why do you have the kdw 2's?
Old 10-30-2008, 11:28 AM   #4 (permalink)
SRTforums Junior Admin
stowaway's Avatar
Member Number: 3286
because he already had the tires and doesn't want to buy something else before his current tires wear out?
or he HAD the KDW2 and now has a better cheaper tire.
The KDW2 is NOT a drag radial. It shares a somewhat similar tread design to a model of drag radial BFG makes, but they are two completely different tires.
In my opinion the BFG KDW NT (KDW 2) is a crappy tire that is bought more for looks than anything else. I had better wet traction with half worn Falken Azenis RT-615s (which are supposed to be HORRIBLE in the wet) than I did with barely worn KDW 2. Dry traction was never a problem, but they made tons of noise and even with a perfect balance caused vibrations through the steering wheel due to the tread design. Also, the tire dates back 6 years, which is HUGE when it comes to tire designs these days. Construction and compounds make tires ride better, grip better, have lower rolling resistance, and last longer.
Old 10-30-2008, 11:33 AM   #5 (permalink)
Flame's Avatar
Member Number: 37340
KDW 2's are FTL. Don't get them. I can not wait until mine are bald so I can get different tires. They absolutely suck in the rain. If there is even a slight angle on the road at a red light, when I start going my tires will spin and I'll slide down the hill.
Flame is offline   Reply With Quote
Old 10-30-2008, 11:49 AM   #6 (permalink)
EssArrTee4's Avatar
Member Number: 57835
as said above, if your looking for a street tire that resebles a drag radial and performs well go with the falken azenis. i have ad no problems with them on mine, in heavy, on the highway. occasionally you feel a little "hydroplane" if you want to call it that it lasts for half a second.
EssArrTee4 is offline   Reply With Quote
Old 10-30-2008, 12:18 PM   #7 (permalink)
scox1026's Avatar
Member Number: 61138
I never liked the KDW II's, especially living in Ohio were we have extreme winters, i never understood why dodge put a 3 season tire on a car that will sell in northern america and canada... I think its because they realized they goofed when giving us a 6" wide tire with 230+ ft lbs of torque, so to make up for their mistake they had to give us one of the stickiest street tires available to make it drivable... just my 2 cents, im sure thats not the reason but i like to overthink things
Coming Soon.... D44
scox1026 is offline   Reply With Quote
Old 10-30-2008, 12:37 PM   #8 (permalink)
stowaway's Avatar
Member Number: 3286
I'm damn glad they didn't throw a junk all-season on the car.
Old 10-30-2008, 12:51 PM   #9 (permalink)
Bebo's Avatar
Member Number: 46331
I have the KDW 2's & they are much better than the crapo michelins that were on there. I went with a slightly larger size to help with traction so, I get a little bit of roll going into the corners & they scrub on hard corners. It rains all the time here & I like how you can drive in the ruts without hydroplaning. I think when I buy my next set though I might check out the Azenis.
Bad points on the KDW's are: expensive, noisy (think truck tire)
Good points: hook well, predictable in corners, excellent wet, wider foot print than other tires of the same size, factory equipped on '04-'05
They are good tires but, as stated above you can probably find a better tire for the money. Just need to do some research.
Quote: Originally Posted by joe r View Post
bare foot,I race naked.
LOL...
joe r
Quote: Originally Posted by Pablo View Post
Try and post some pics if you can.
Bebo is offline   Reply With Quote
Old 10-30-2008, 12:53 PM   #10 (permalink)
Sota's Avatar
Member Number: 31159
I guess I like the KDW2s since I don't ever drive in the rain with the car.
Personally I've found them to be a nice grippy tire and held up very well at a road course day.
I'd love to try a set of the KD's though... THOSE would be absolutely horrid in the rain
  • N2MB / Jay & Jon
  • S&P Development / Jimmy
  • Maddog Shifters / Chuck
What else needs to be said?
Sota is offline   Reply With Quote
Old 10-30-2008, 12:58 PM   #11 (permalink)
So Falken Azenis is my best bet, wow i was totally going in the wrong direction then. Well i guess ill look into it some more.
Old 10-30-2008, 01:35 PM   #12 (permalink)
stowaway's Avatar
Member Number: 3286
actually, they are not the best option out right now. What size do you need? That there can throw out 90% of the top level tires depending on what size you want/need to run.
Old 10-30-2008, 02:25 PM   #13 (permalink)
stock size 205/40/17
Old 10-30-2008, 02:27 PM   #14 (permalink)
EssArrTee4's Avatar
i recomend the falkens to anyone that will listen, i have yet to find something bad about them. i went from being able to break the tires loose in a 3rd gear (Hankook K106) to being able to power all the way through second with more torque steer then i know what to do with. also with a launch on the street i usually spin first and immediately hook in second the whole way through. I used to have a different set of falkens on a different vehicle (Falken 912 on an awd eagle talon) they were very loud at highway speed, something i dont notice with the azenis.
also the falkens can be found for around $105-120 depending on size and where you shop. if i remember right the BFGs are in the $130 range.
Mine are 225/45/17 and i paid $104 through my work but Home - Discount Tire Direct was selling them for $115 shipped
Old 10-30-2008, 02:28 PM   #15 (permalink)
tq steer is bad..is it not????
Page generated in 0.25015 seconds with 13 queries
