Old 05-12-2009, 10:00 PM   #1 (permalink)
Member Number: 55847
Default Anyone try 2 ½ inch mass lip wheels
Has anyone tried 18 in mass lip wheels all around? i'm gonna try it this week
04CUSTOMBLUE is offline   Reply With Quote
Old 05-12-2009, 11:56 PM   #2 (permalink)
evo77's Avatar
Member Number: 1346
Won't fit over the front calipers. The mounting pad is too short and is meant for the rears with smaller calipers.
S2 no toys, Mopar bov, AGP bfmic, 3" turboback
Old 05-13-2009, 12:16 AM   #3 (permalink)
sikrsix's Avatar
Member Number: 72781
That's what Kics wheels spacers are for! Go aggressive or stay stock, that's my motto! Fenders should always need to be rolled or your wheel setup is lame. lol
Liquid cooled spark plug wires, Walbro 255 wired into dimmer switch for adjustable fuel flow, Huge front mount outercooler, Y'd tubular header plumbed into dual 3.15" downpipes, Y'd back into a 2" LFC, Y'd back out to 4.5" dual exhaust (no muffla's) exiting a 1 into 2 stainless exhaust tip welded on backwards for flow! Yes its fast. Don't let me catch you at a light cuz ill rev on you till my motor falls out!
sikrsix is offline   Reply With Quote
Old 05-13-2009, 05:03 PM   #4 (permalink)
so u dont think i can make a 40mm offset wheel with the lip fit? currently i have bc coilovers and rev model II's ( 45 offset) with 235/40 tire with 5mm spacers running -1.5 camber. im sure gonna try, ill make it work safely
Old 05-13-2009, 09:27 PM   #5 (permalink)
evo77's Avatar
Member Number: 1346
No, you don't understand. It won't look right with spacers.
Look at the picture above that I posted. Do you see how the rear wheel sits FLUSH with the fender? The way the Maxis Lips work is that in order to get a super deep lip while retaining the correct offset the material on the mounting pad is shortened. They do this because they know the rear calipers are always smaller.
If you put those rear wheels on the front you'll need large spacers. More like adapters. Probably at least an 1" just to clear the calipers. And what will you end up with? Wheels that stick out well past the fenders.
Old 05-13-2009, 09:44 PM   #6 (permalink)
XCLR8TN's Avatar
Member Number: 586
Fixed with: camber + fender rolling, lol.
1995 Neon Super Stripper
1991 BRG Miata Limited Edition
fusion210: Everytime I ride in a car you're driving I try to make it the last time. D:
XCLR8TN is offline   Reply With Quote
Old 05-13-2009, 10:06 PM   #7 (permalink)
kotu100's Avatar
Member Number: 4357
ya if u want ur ride to look like this...
Best run:12.167@113.93 mph with a 1.82 60'. same mods as below w/ 110octane on 24x8.5x15 MT drags.
Best Run on streets: 12.571@114.61 mph with a 2.0 60' on 18" all season tyres. mods=AGP WGA, S-AFC I, 750cc inj., HKS BOV on ATP UPP, Mopar sts, AGP dogbones, CCA FMIC, and 3" turboback no cat no mufflers.
Best MPH was 116.40 run with same mods as above!!!
Tuned by ME: 286whp 366wtq 22/13 FASTEST SRT-4 ON STREET TIRES, STOCK TURBO, OFF THE BOTTLE
kotu100 is offline   Reply With Quote
Old 05-13-2009, 10:07 PM   #8 (permalink)
XCLR8TN's Avatar
Member Number: 586
I didn't say -5 degrees of camber. -2 should work fine.
Old 05-14-2009, 12:40 AM   #9 (permalink)
sikrsix's Avatar
Kics spacers have built in lugs. If you don't want to roll your fenders, get a set of flared fenders and the correct spacer to clear your caliper. Nothing wrong with having a wider front track, since 1: Your FWD and 2: Wider front = better turn in. Aggressive wheel combo will out shine the car with 15 tv's, bodykit, off the shelf wheels and look so bad ass that youll be glad you "went and did it"
Old 05-14-2009, 06:09 AM   #10 (permalink)
XCLR8TN's Avatar
Member Number: 586
I'm running 25mm Kics spacer on my Miata, word of warning, look at whatever wheels you have and/or are contemplating and make sure that the area between the lug holes is carved out on the back. If it isn't, you have 2 choices. Grind/drill the wheel, or grind the stock studs. If you don't do either, the stock studs will contact the mounting pad on the wheels and you won't be able to fully seat the wheel onto the hub (which is now the Kics spacer). I chose to grind 1/16" off my stock studs.
