Quote: Originally Posted by
QFC
Its about time to finally put some new rims on my SRT.
I want to go with 18s.
I want to keep the overall OD of the tire stock so I don't have to worry about the speedometer and all that good stuff.
I want to reduce the weight on the corners.
I don't really want to go too wide(8 would be nice).
My knowledge of the rim and tire world isn't that extensive so any help would be amazing thanks all!
As far as keeping the wheel/tire combination the same diameter as stock, this is a great website to visit -
Tire size calculator
The site allows you to put in the stock diameter and then compare to 18 tire sizes to see the difference.
As far as weight, the lighter you want to go, usually, the more money. Just remember that although the stock wheels were heavy for their size, you are jumping up to a much bigger size if you go 18x8 so expect that the wheels will be about the same weight, or if lighter, probably won't be by much unless you want to spend the really big bucks or find a great deal. You can use
WHEELWEIGHTS.NET to see the weights of a huge number of wheels.
I am a "constant" shopper and the best deal on new wheels I have seen recently is Tire Rack has Kosei K3's in 5x100, 18x7.5 size, 35mm offset for $149 a piece. Kosei's are a pretty decent set of wheels and these weigh 18.5 lbs a piece. Will hold a 235 tire so get a decent amount of tread.
