Old 07-04-2008, 08:29 PM   #1 (permalink)
Member Number: 47422
Default Adjusting ride height with coilovers.
I got a quick question guys. First do you guys do this your self. I am really anal about having the car be equaly level on all 4 corners. Do you just count the rings? If that is the case what if there is more weight on 1 corner then the other? Wouldn't counting the rings be pointless? I dont know so i am asking you guys help!
sta11ker is offline   Reply With Quote
Old 07-04-2008, 09:47 PM   #2 (permalink)
rasp's Avatar
Member Number: 56076
I used auto-scales on all 4 tires to get the weight proportion 100% correct. Others have fine luck using simple measuring tools.
Old 07-05-2008, 07:54 AM   #3 (permalink)
Elected Moderator
stowaway's Avatar
Member Number: 3286
have someone your weight sit in the drivers seat and with the car on perfectly level ground and equal air pressure both front and both rear tires, measure from the ground to the pinch seam on both sides, then raise/lower things until you get them even and at the height you want. Changing one corner will affect other corners as well.
Page generated in 0.13262 seconds with 11 queries
