Old 11-03-2009, 09:32 AM   #1 (permalink)
radicalmark29's Avatar
Member Number: 55274
Trader Rating: (20)
Default 9 inch wide wheels
So i know its said to be impossible, but what about with a spacer? Currently running an 8.5 wide wheel with a 10mm spacer and no problems whatsoever. Yes i have extended studs.
In the market for new wheels and looking to squeeze out that extra .5 of an inch.
What do you think? Gonna work? What offset should i order? 35?
Does it matter if i do 17 or 18?
WTB: CF rear diffuser
radicalmark29 is offline   Reply With Quote
Old 11-03-2009, 09:33 AM   #2 (permalink)
Trader Rating: (20)
Oh and i have BC coils.
Old 11-03-2009, 04:47 PM   #3 (permalink)
evo77's Avatar
Member Number: 1346
There are only a handful of off the shelf 9" wide wheels in a 5x100 bolt pattern with an offset close enough to keep the wheel inline with the fender.
Its better to fit a wheel with a higher offset that way you can play with the fitment by adding the appropriate spacer to get it just right.
A wheel with too low of an offset will result in a wheel that sticks out well past the fenders. And there isn't anything you can do to correct it except for having the wheel hub machined to remove material to bring the wheel in. Basically increasing the offset. But this is costly and is an extreme route to take.
S2 no toys, Mopar bov, AGP bfmic, 3" turboback
evo77 is online now   Reply With Quote
Old 11-03-2009, 05:36 PM   #4 (permalink)
evo77's Avatar
Member Number: 1346
Good candidates...
Drag DR-31 / 17x9 / 38 offset
Drag DR-31 / 18x9 / 38 offset
Privat Motiv / 18x9 / 35 offset
Drifz 520S / 17x9 / 35 offset
Rota DPT / 17x9 / 35 and 42 offset
Rota DPT / 18x9 / 42 offset
Rota D2 / 18x9 / 48 offset
Rota G-Force / 18x9 / 35 offset
A few more to add later. So much for my previous comment about only being a handfull out there...lol
Old 11-03-2009, 08:43 PM   #5 (permalink)
Trader Rating: (20)
I have a certain wheel in mind. Same wheel i have now but wider
Rota Grid.
Right now is an 18x8.5 with i believe a 40mm offset.
Old 11-03-2009, 09:00 PM   #6 (permalink)
Trader Rating: (20)
Post 226 in your wheel pics thread is me.
Old 11-09-2009, 06:06 AM   #7 (permalink)
Member Number: 50094
Does rota torque 17x9 work as well as the dr31?
dave. is offline   Reply With Quote
Old 11-09-2009, 08:34 AM   #8 (permalink)
ptperformance's Avatar
Member Number: 25514
Trader Rating: (567)
Quote: Originally Posted by evo77 View Post
Good candidates...
What about a 15" wheel? I have a set of 10" slicks I need to get mounted up and really don't care about how far they stick out past the wheel well. I have not been able to find a 9 or 10" wheel for this application (must not be looking hard enough). Any advise?
Home of the DSP Tuned 657 WHP SRT4 Neon, 593 WHP SRT4 Caliber and the fastest stock turbo DSP tuned SRT4
DSP or Trinity
Old 11-09-2009, 10:09 AM   #9 (permalink)
jnathan68's Avatar
Member Number: 59167
Trader Rating: (43)
As you have already figured out, 17x9 or 18x9 will be a tough fitment. There is probably not going to be much of a chance of fitting that size wheels without hitting the coilover (with wheel and/or tire) or having the wheel/tire stick out past the fender. Best bet is to do the measurements and see what backspacing (offset) would get you closet. Then you can work on the finding the proper wheel/spacer combination or have a set of custom wheels made. Also could flare the fenders (or buy flared fenders).
Also, check out VW Vortex. The early 2000 VW's used 5x100 and those guys have gotten really creative on wheels. Including spacers that convert your 5x100 into a 5x114.3 setup which has more wheel offset options.
All this is making the assumption that you want to go to a wider than 245 tire. If not, best to stick with 17x8 or 18x8 wheel.
jnathan68 is offline   Reply With Quote
Old 11-09-2009, 12:36 PM   #10 (permalink)
s14_sr20_silvia's Avatar
Member Number: 74899
This is totally true... assuming you have know idea how to measure anything and dropped out of school in third grade...
I'm glad to see someone with enough balls to get some wheels that fit.. to OP just make sure you measure everything carefully (measure twice.. and cut.. er order wheels once) and good luck! Let's see some pics when you get them in!!!
SRTwenty
s14_sr20_silvia is offline   Reply With Quote
Old 11-09-2009, 02:11 PM   #11 (permalink)
Member Number: 32896
Wait a couple of months, you'll see a 18x10 et 33 on the rear of an srt4 =) Stock body, no spacers..
LMAO, wow.
I can't support companies.
B00st Junkie is offline   Reply With Quote
Old 11-09-2009, 03:50 PM   #12 (permalink)
Trader Rating: (20)
Old 11-09-2009, 06:46 PM   #13 (permalink)
Member Number: 57123
pics please
HP61(Blown),Porfueler, Mapclamp,Greddy Profec II EBC, AGP Hard Pipes, Synchronic BOV, MPX BFMIC, Race motor mount inserts, MSD Cap and Wires, Needswings Downpipe w/cut out, AEM Wideband, AGP CAI.
Best time on Garrett 50 trim 12.3 at 113MPH.Elevation 4,XXX.
on 26PSI. Boost leak maybe?
Garrett 50 trim SOLD
20g turbo kit SOLD.........
up_in_boost is offline   Reply With Quote
Old 11-09-2009, 07:55 PM   #14 (permalink)
evo77's Avatar
Member Number: 1346
As long as the offset is no less than 35 mm. Anything higher and you can play with the fitment with spacers.
Remember, its recommended to install longer studs when using spacers 5mm and up.
Old 11-09-2009, 07:58 PM   #15 (permalink)
evo77's Avatar
Member Number: 1346
Those WILL NOT clear a stock body. They'll stick out.
Page generated in 0.17786 seconds with 13 queries
