5mm Spacers...Need longer studs? - Dodge SRT Forum
post #1 of 24 (permalink) Old 05-01-2011, 07:55 PM Thread Starter
Quoted: 0 Post(s)
Ok guys here's my problem.
I bought a set of 17x7 + 42 Offset MSR wheels, they look great, I've bought a set of 4 Toyo Proxes 4 to put them on my NSRT-4...The problem is, wheels are rubbing against the front caliper...Not by much, I can turn them with my hands, but I don't want to hurt anything...
I've been looking around here for wheel spacers, and they don't seem to sell anything smaller than 5 MM..If I buy those, will I need longer studs??? I don't want to get home and have not enough thread left in my studs to put on my nuts!
Should I just wait and buy 3MM spacers just to make sure everything is ok?
Thanks guys!
Sorry about my poor english!
darkounet is offline
post #2 of 24 (permalink) Old 05-01-2011, 08:01 PM
evo77's Avatar
Quoted: 2 Post(s)
5mm spacers will not require longer wheel studs.
Just curious, which model MSR wheels did you get?
OLD: 2003 SRT-4 is gone... thanks for the good times.
NEW: 2012 Chevy Cruze Eco... well, at least its still turbo right?
evo77 is offline
post #3 of 24 (permalink) Old 05-02-2011, 04:29 AM Thread Starter
Quoted: 0 Post(s)
Those.
And thanks by the way for the answer!
post #4 of 24 (permalink) Old 05-03-2011, 10:41 AM
2011 Calendar Car
SRT of the Month
Quoted: 0 Post(s)
My buddy had those. Looked EXACTLY like my Tenzos just way cheaper.
wiggy is offline
post #5 of 24 (permalink) Old 05-03-2011, 10:53 AM
SRToad4's Avatar
Quoted: 0 Post(s)
I have 5mm spacers on the rear, and used to have 3mm spacers in the front. No issues whatsoever
E85 POWERED 416whp/401wtq @ 21ish psi
DSP dialed in by Turbo666
12/12/2010 - 12.51 @ 116mph - 1.91 60'
www.buyblackline.com - Enthusiast Apparel!
SRToad4 is offline
post #6 of 24 (permalink) Old 12-08-2011, 03:03 PM
bman5701's Avatar
Quoted: 0 Post(s)
im getting 15mm spacers up front and 25mm spacers on back and i have a +35 offset wheel..am i going to need to buy longer studs or just extended lug nuts? can i get away with just extended lug nuts? or do i need to buy longer studs as well?
Twitter-@brandonpeavey
Instgram-brandonpeavey
bman5701 is offline
post #7 of 24 (permalink) Old 12-10-2011, 06:14 AM
Fresh Meat Moderator
Quoted: 3 Post(s)
Why are you getting that big of spacers with that offset? They will fit without spacers.
Oh I forgot you're a hellafaggot.
No youll need extended studs.
tunerlover3 is offline
post #8 of 24 (permalink) Old 12-10-2011, 06:31 AM
SRTotM Moderator
Bad98rt's Avatar
Quoted: 1 Post(s)
Yeah i got 20mm and 25mm spacers chill out on the hellafagoot shit dan.. or ill come down there and pay you a visit LOL
Huge thanks to Chris, Bill, And Bob @MAPerformane for 95% of all my parts
Huge Thanks to Kevin Warren For.. Many many things
MAP EF4 stock block, stock head
452whp on EMS at 26 psi
100&92 octane mix
Fully built long block and big numbers coming!
Bad98rt is offline
post #9 of 24 (permalink) Old 12-10-2011, 12:24 PM
Quoted: 3 Post(s)
COME AT ME BRO!
And your situation is a little different Chris. lol
post #10 of 24 (permalink) Old 12-10-2011, 05:29 PM
bman5701's Avatar
Quoted: 0 Post(s)
dude grow up a little bit..
bman5701 is offline
post #11 of 24 (permalink) Old 12-10-2011, 10:17 PM
SRTotM Moderator
Bad98rt's Avatar
Quoted: 1 Post(s)
my rims are a 42mm off set and here is how it sits with 17x7's and 205/50s
100&92 octane mix
Bad98rt is offline
post #12 of 24 (permalink) Old 12-14-2011, 03:17 PM
SRTForums Member
2011 Calendar Car
SRT of the Month wannabe
whiteSRT69's Avatar
Quoted: 2 Post(s)
1999 Plymouth Neon = SOLD
2005 Dodge Neon SRT4 = SOLD
2014 Scion FRS = current
whiteSRT69 is offline
post #13 of 24 (permalink) Old 12-18-2011, 07:55 PM
bhambutchnsrt4's Avatar
Quoted: 0 Post(s)
Hey guys, I have the facto 17s and I'm about to get the Eibach pro-kit lowering springs. I was gonna order wheel spacers too jus to get the wheels flush with the fenders (nothing crazy). Any suggestions on what size spacers i would need?
thanks
bhambutchnsrt4 is offline
post #14 of 24 (permalink) Old 06-18-2015, 03:55 AM
Quoted: 0 Post(s)
Okay so I bought the drag dr 34 17's, I forgot what the offset...So I installed my BC coil over BR type and now the two front tire is rubbing against the coil overs would a 5 mm spacer work with my application or do i need to get 10mm and on the 5 and 10 mm do I need a longer stud bolts?
timeshoot is offline
post #15 of 24 (permalink) Old 06-19-2015, 10:44 AM
SRTforums Admin
stowaway's Avatar
Quoted: 968 Post(s)
need to know the offset, width, and if you actually set up your camber correctly. You have two ways to adjust camber on the front of BC coilovers (rear too if you bought the upgraded rear mounts), the slotted clevis bolt hole and the camber plates. You adjust the tire clearance via the clevis bolt holes and then get the camber back in line via the camber plates. If you just use the clevis bolts to get camber you'll have tire clearance problems.
stowaway is offline
User Tag List
Linear Mode Linear Mode
