Old 07-03-2008, 10:42 AM   #1 (permalink)
Member Number: 64771
Default 235 tire width ... go with 40 or 45 high ??
In other words, when choosing between these two, which is correct for a 7.5" rim on a SRT-4 ?
235/40R17 or 235/45R17 ? One is 1/2" taller than what I am now using, and one is 1/2" shorter.
Thank you
bmpblue is offline   Reply With Quote
Old 07-03-2008, 01:37 PM   #2 (permalink)
rrmike1's Avatar
Member Number: 55729
Go with the 40. Wider tire with a lower profile...FTW!!!
Stage 2 w/o toys, FBM pnp'd turbo/mani., Rage 55mm T/B, AGP WGA, AGP CAI, MPx 3" O2, Maxxfab 3" DP no-cat, Mopar Exhaust, AEM UEGO, SprayItRacing BOV, Crane 8.5mm wires, Champion RE10pmc5's, 180 thermo, RFR check valve, Prothane race MM inserts, Autometer 30/30, SCT Tuner, Tein H-techs, Proparts dual-gauge pillar, Fuel pump re-wire.
rrmike1 is offline   Reply With Quote
Old 07-03-2008, 01:39 PM   #3 (permalink)
lyncoo's Avatar
Member Number: 43166
Trader Rating: (58)
id go with the 45s depending on the offset
thats fantastic
AGP S256 + B&G FLASH
Old 07-03-2008, 01:42 PM   #4 (permalink)
kup@l's Avatar
Member Number: 53972
^^ x2 but I am on 235/45/17s 17x8in rim with a 35+ offset
kup@l is offline   Reply With Quote
Old 07-03-2008, 01:43 PM   #5 (permalink)
1LAPSRT's Avatar
Member Number: 38267
Trader Rating: (19)
Check this out....
Tire Size Calculator - tire & wheel plus sizing
Heading for a new track? Just want to improve your times at a track you already run?
Old 07-03-2008, 01:49 PM   #6 (permalink)
lyncoo's Avatar
Trader Rating: (58)
taller tire= better ride and traction
Old 07-03-2008, 01:56 PM   #7 (permalink)
1LAPSRT's Avatar
Trader Rating: (19)
I'd try to get the one closest to the stock size to keep the speedometer correct....
My $0.02
Old 07-03-2008, 02:17 PM   #8 (permalink)
Thank you everyone. I'm going with the 45, as it throws the speedo off by almost 2mph less than the 40 will, and offset isn't an issue.
Old 07-03-2008, 02:28 PM   #9 (permalink)
rrmike1's Avatar
Ftl...
Old 07-03-2008, 03:09 PM   #10 (permalink)
1LAPSRT's Avatar
Trader Rating: (19)
How exactly is a 40 series tire wider than a 45 series tire? Just curious!
Old 07-03-2008, 03:18 PM   #11 (permalink)
rrmike1's Avatar
Wider than stock...
...with a lower profile...
Old 07-03-2008, 03:21 PM   #12 (permalink)
1LAPSRT's Avatar
Trader Rating: (19)
Wider than stock...
Ahh.... thought you were comparing his two choices to each other with your first comment....
Old 07-03-2008, 03:26 PM   #13 (permalink)
rrmike1's Avatar
It was kinda vague...
I prefer the lower profile cause it makes the tire look wider. It's like comparing a 235/40/20 on 20x8 rim to a 235/40/17 on a 17x8 rim. It's the same width, but with the lower height it "looks" wider...
...just me though...
Old 07-03-2008, 07:07 PM   #14 (permalink)
Super Moderator
stowaway's Avatar
Member Number: 3286
this is an easy one. the 235/40 can not be safely used on a 7.5" wide wheel.
Old 07-03-2008, 07:41 PM   #15 (permalink)
addictedtosin's Avatar
Member Number: 30537
Trader Rating: (113)
yup, I would go with the 235 45 17
Basically it looks like this minus a turbo...... oh and wheels too
addictedtosin is offline   Reply With Quote
Page generated in 0.27429 seconds with 11 queries
