Old 07-24-2007, 04:09 PM   #46 (permalink)
Black Beast's Avatar
Member Number: 51114
Trader Rating: (40)
225/45 BFG G-force sport on stock rims for about a year then I recently changed to 215/45 595 Federal. I had NO problems with 225/45s or the 215/45 but I only STREET RACE!!!!!!! Any other time I drive like a 90 year old man so Ive never had the floting experence. I know that tires that are verified in EUROPE are wider than the same size verified in the USA
Black Beast is offline   Reply With Quote
Old 08-14-2007, 02:10 PM   #47 (permalink)
Member Number: 18856
if you wouldn't just slap the tires on and go with the stock psi on these wider tires than your sidewall would not "squish." the wider the tire the more air you will need to carry the proper load. read the side wall of the tire says xxxx load @ XX psi usually this is the maximum air the tire can hold.
not a thing just another slow a$$ neon
joe smalls is offline   Reply With Quote
Old 09-25-2007, 05:08 PM   #48 (permalink)
scottw03's Avatar
Member Number: 23435
Trader Rating: (39)
Ok read through all these threads and saw one guy ask a retorical question I guess about fitting a 235/45/17 tire on a 17x7 rim. can this be done without hurting handling capabilities much? I mostly race straightline, but do enjoy the every once in awhile spirited drive through the curving country roads.
I have rims with a 45 offset, no clearance issues on the calipers and I have BC coilovers so no perches to worry about rubbing.
I am looking at going with either the BFG KDW2's or the Goodyear F1 GS-D3 tires on these 17x7 rims. I would like to get as wide of a tire as possible with keeping handling issue to a minimum. I know a 225 will fit no problem but if I can get the 235 on there without an issue I would rather do that.
Thanks guys.
scottw03 is offline   Reply With Quote
Old 09-25-2007, 05:14 PM   #49 (permalink)
SRTforums Junior Admin
stowaway's Avatar
Member Number: 3286
it is not safe to mount a 235/45 on a 7" rim. it needs a 7.5" wide rim. Also, with that offset, you'll be VERY close to the strut body, even with coilovers. Get an extreme performance 225/45 tire for the best traction with your wheels.
Old 09-25-2007, 05:36 PM   #50 (permalink)
scottw03's Avatar
Trader Rating: (39)
Gotcha, thanks Stowaway. Any recommendations on tires?
I am looking at the 225/45 Goodyear F1 GS-D3's, BFG KDW2's, or the Bridgestone Potenza RE-01R.
Old 09-25-2007, 05:41 PM   #51 (permalink)
stowaway's Avatar
Member Number: 3286
out of those, the re-01r. but the best (short of the BFG drag radial) will be the falken azenis RT-615.
Old 09-25-2007, 05:54 PM   #52 (permalink)
scottw03's Avatar
Trader Rating: (39)
Yeah I wanted the falken azenis, but I am having a hard time trying to find a place that will ship via USPS to an APO box overseas. Tirerack.com atleast ships to them and has your tires to you in like 2 weeks. I wanted to go through edgeracing for rims and tires (they have the Falkens there) so I could get a nice combo for about $800-900. But emailed them on Sunday and still haven't heard from them if they would be willing to assist with this request.
So I might have to go with the re-01r's for the moment then and then get the falkens when I get back to the states next year and buy some new rims. how is the tread life with the re-01r's? decent? or am I going to have to replace them in 6000 miles.
As long as I can get say about 15k out of them I will be happy. only $540 for them
Old 09-25-2007, 06:13 PM   #53 (permalink)
stowaway's Avatar
Member Number: 3286
either the RT-615 or the re-01r will get 12-15k miles out of a set under normal driving.
hmmmm, Falken doesn't sell the RT-615 in Europe.........
Contact Discount Tire Direct, they ship to APO. They have them in stock right now too, for $127 each.
Old 09-25-2007, 06:25 PM   #54 (permalink)
scottw03's Avatar
Trader Rating: (39)
I am sure they do, but it is $2+ to the pound at the moment. It would cost me less probably to buy them from the states, pay for shipping mounting and balancing than it would to get them over here. LOL
I will check that site out. If they will ship then I am sold. that mileage is perfect. I got all seasons on stock rims for the winter anyway.
Old 09-25-2007, 06:48 PM   #55 (permalink)
scottw03's Avatar
Trader Rating: (39)
order placed. Thanks Stowaway. Been looking to buy those tires now for like the last week or two.
Old 09-25-2007, 06:55 PM   #56 (permalink)
stowaway's Avatar
Member Number: 3286
no problem.
Old 10-09-2007, 04:34 PM   #57 (permalink)
Fonzie544's Avatar
Member Number: 46665
ok so no one here has tried to mount a 235 on a 7inch wheel?.... no one at all?
i think it can be done... but i dont want to blow that money away and then have then not work...
Fonzie544 is offline   Reply With Quote
Old 10-09-2007, 04:42 PM   #58 (permalink)
stowaway's Avatar
Member Number: 3286
it's not the width only that makes a tire fit or not, it's the width plus aspect ratio (sidewall height). a 235/40 needs an 8" wide wheel, a 235/45 needs a 7.5" wide wheel, and both fit on an srt-4 with stock suspension. A 235/50-17 can actually fit on a 6.5" wide rim, but is much too tall to fit on an SRT-4.
Old 10-18-2007, 10:28 AM   #59 (permalink)
Member Number: 45696
Trader Rating: (10)
Will 215-45-17's work? It would only be a little shorter, right?
I really like the Nitto NeoGens but they don't come in a 50 series
Thanks!
2005 Flame Red SRT-4 (About To Be Gone)
Reborn Ride: 1990 Taurus SHO White w/Black Leather
Mods: K&N, Catless Exhaust, Flowmasters, Intrax Lowering Springs w/KYB Struts, Aluminum Subframe Bushings, Solid MM's, Reinforced Diff., Clutchmasters S1 Clutch, and Fidanza Aluminum Flywheel
'05NeonMaaaaan is offline   Reply With Quote
Old 10-18-2007, 10:30 AM   #60 (permalink)
stowaway's Avatar
Member Number: 3286
no, and look at different tires. The Nitto's aren't that good in comparison to other tires on the market.
Page generated in 0.21162 seconds with 13 queries
