Old 07-05-2008, 10:31 AM   #1 (permalink)
srt4crazy05's Avatar
Member Number: 54763
Default 215/?/17 on stock wheels?
i wanna put 215's on my stockers but i forgot what the right wall size was. can anybody help?
to me... every lane is a passing lane... on the highway
254.30WHP-299.28WTQ on RAGE-TEK DYNOJET 7/21/07
looking for parts: ported i-mani, ported tb, h-brace w/ t-bars, wideband, scangauge
myspace.com/pr0stidud3
srt4crazy05 is offline   Reply With Quote
Old 07-05-2008, 12:35 PM   #2 (permalink)
rrmike1's Avatar
Member Number: 55729
We have someone down here running a 215/45 on the stock wheel and it looks pretty good. It's a little shorter than stock, but it's hardly noticable with the car lowered.
Stage 2 w/o toys, FBM pnp'd turbo/mani., Rage 55mm T/B, AGP WGA, AGP CAI, MPx 3" O2, Maxxfab 3" DP no-cat, Mopar Exhaust, AEM UEGO, SprayItRacing BOV, Crane 8.5mm wires, Champion RE10pmc5's, 180 thermo, RFR check valve, Prothane race MM inserts, Autometer 30/30, SCT Tuner, Tein H-techs, Proparts dual-gauge pillar, Fuel pump re-wire.
rrmike1 is offline   Reply With Quote
Old 07-05-2008, 01:03 PM   #3 (permalink)
Freaky's Avatar
Member Number: 47525
i'm running 215 50 17 but i'm a tad bit taller than stock. i've been thru radar at 70 in a 65 with no problems so my speed didn't get thrown off to much . very minimal help with spinning , i just went with the 215 50 17 cause i wasn't sure an the tire place said it was really close .
stage0,cca bfmic, needswings dp no cat, mccord electric opener , agp wga ,dtec fc/bc , front an rear strut bars ,progress front an rear sway bars an springs, tripple pillar pod with auto meter volt an oil pressure guage , turbo xs wideband, turbonetics cold side pipe raptor bov , aem cai,return line ,255 walboro fuel pump, Granatelli wires , 4306 plugs
Freaky is online now   Reply With Quote
Old 07-05-2008, 01:39 PM   #4 (permalink)
Super Moderator
stowaway's Avatar
Member Number: 3286
215/50-17 is the only other size you should EVER use on stock wheels. They are going to be .1" taller than the stock KDW2 tires, .4" taller than stock Michelins on 03s.
Old 07-05-2008, 01:43 PM   #5 (permalink)
rrmike1's Avatar
That skinny ass rim is f*ckin' useless...
Old 07-05-2008, 02:07 PM   #6 (permalink)
ocsrt4's Avatar
Member Number: 64555
i got some 235-45-17 eagle f-1s for free and threw them on and they work good especially on the track with about 18psi in the tires theres a big foot print
ocsrt4 is offline   Reply With Quote
Old 07-05-2008, 02:27 PM   #7 (permalink)
Member Number: 65076
They are great for snow tires if you drive in the winter. But thats probably all.
HWY* is offline   Reply With Quote
Old 07-05-2008, 02:45 PM   #8 (permalink)
there isnt a size that will match the stock kdw2? im gonna get yokohama s.drives 215's but i wanna make sure they r the same height or the closest possible to the stock kdw2's.
Old 07-05-2008, 06:37 PM   #9 (permalink)
rrmike1's Avatar
We haven't seen snow since '77 down here...
Old 07-05-2008, 07:05 PM   #10 (permalink)
Super Moderator
stowaway's Avatar
Member Number: 3286
if you put them on different ends, it doesn't matter about a little diameter difference. Pretty much any of the 205/50 will be damn similar (a tenth or two at most) and then the 215/50 are all pretty much 25.5" tall. The very most difference you could get would be right around 1/2" and that's if you find the shortest 205/50 and tallest 215/50.
Old 07-05-2008, 07:09 PM   #11 (permalink)
so 215/50 will be fine? or 215/45?
Old 07-05-2008, 07:10 PM   #12 (permalink)
Super Moderator
stowaway's Avatar
Member Number: 3286
do not use the 45 series tire.
Old 07-06-2008, 04:15 AM   #13 (permalink)
rrmike1's Avatar
This must be the same issue as the 235/40 on the 7.5" rim??
Old 07-06-2008, 07:29 AM   #14 (permalink)
i was thinkin the same thing. y is he sayin 235? its way bigger than a215 n way too big on a stock wheel. lol
Old 07-06-2008, 07:35 AM   #15 (permalink)
Freaky's Avatar
i was told by the tire company that they wouldn't put anyting bigger on my stock wheels than a 215 . to much risk of the tire rolling over the lip of the rim an then they would be at fault . so they straight up said no . which was fine with me the last thing i want is a set of unsafe tires
