Quote: Originally Posted by
Dub KllR
do i need to run a 235/40 or can i do a 235/45 without any issues? which would be better? thanks for the input
Do you have coilovers? If so, how lowered are you?
The 235/40 helps a little with clearance on some coilovers and has a smaller sidewall which should provide a stiffer sidewall (comparing the same brand/type of tires).
While the 235/45 is closer (I believe) in overall diameter to the stock tire and usually cheaper to buy (more options).
