Old 06-05-2008, 07:15 AM   #1 (permalink)
SRTforums Veteran²
onthedwnlow's Avatar
Member Number: 27125
Trader Rating: (43)
Default 15" drag wheels
im having a hard time finding a at least 7" wide wheel to have a set of slicks mounted on....really looking for a 7.5" but 7" will do.....
sorry guys but the car is for sale....all out first gen is in the works
onthedwnlow is offline   Reply With Quote
Old 06-05-2008, 08:13 AM   #2 (permalink)
redteaser4's Avatar
Member Number: 48736
in just got some rota slipstreams for 250 shipped
redteaser4 is offline   Reply With Quote
Old 06-05-2008, 08:16 AM   #3 (permalink)
SRTforums Veteran²
Trader Rating: (43)
i dont care on the price im looking for the width
Old 06-05-2008, 08:18 AM   #4 (permalink)
redteaser4's Avatar
Slipstream
Old 06-05-2008, 08:24 AM   #5 (permalink)
SRTforums Veteran²
Trader Rating: (43)
not bad.....id really like ome 8" wides......and they dont offer them in a 5x100 pattern
Old 06-05-2008, 08:32 AM   #6 (permalink)
redteaser4's Avatar
yea sorry good luck
Old 06-05-2008, 11:02 AM   #7 (permalink)
SRTforums Veteran²
Trader Rating: (43)
thankx......im just trying to get a good 7.5 or 8" wheel for 8.5" slicks
Old 06-05-2008, 11:06 AM   #8 (permalink)
NoisufnoC's Avatar
Member Number: 136
i run M&H 8.5/24.5-15 slicks on the kosei k1 15x7's with no issues
omgz!! i haz mods!!
Old 06-05-2008, 11:13 AM   #9 (permalink)
SRTforums Veteran²
Trader Rating: (43)
im not saying there is issues with smaller wheels......but i have been noticing and came to the conclusion that running smaller wheels is affecting the performance of the slicks.....it making the slick not put a full contact patch down......
i used to pull 1.8 60's all day on a set of 7.5" wheels with dot approved street slicks.....and with full out slicks on pt cruiser wheels i cant pull any better....and the wear pattern on the slick even shows only a partial patch
Old 06-05-2008, 11:15 AM   #10 (permalink)
NoisufnoC's Avatar
Member Number: 136
good luck finding a wheel.
the kosei or the rota wheel has been used very often with slicks of that size with good results.
keep in mind that you're going to be running real slicks at lower tire pressure which should increase the contact patch.
or are these wheels for your dot tires?
Old 06-05-2008, 11:26 AM   #11 (permalink)
SRTforums Veteran²
Trader Rating: (43)
if i have to go with a 7" i will.....i know the kosei's and rota work......
these wheels are going to be for 8.5x26x15 slicks....i know on lower pressures the slicks have more of a patch.....but when the tires start spinning it amplifies the problems.....because he center of the tire will expand when spinning.....so during the first 330 feet is where the problems lie.....
Old 06-05-2008, 11:55 AM   #12 (permalink)
Super Moderator
stowaway's Avatar
Member Number: 3286
You need to contact a company like Bogart or Diamond Wheels and get a set custom made.
Old 06-05-2008, 11:58 AM   #13 (permalink)
SRTforums Veteran²
Trader Rating: (43)
what kind of offset do you suggest.....ipp coilovers.....im going to have it sit the same hight as my eibach sportlines.......so the tires will be really close....
Old 06-05-2008, 12:07 PM   #14 (permalink)
lepolesconcepts's Avatar
Member Number: 26836
Trader Rating: (50)
american racing Estrella work. there 15x7 with a 35mm offset and can be had for less than $100 per wheel
S3R w/toys,44lb wheel,AGP WGA, Lorenzo 60mm TB,Dtec FC,Crane 16's,Fidanza Gears,CTI 2.5" IC Pipe,ED IC Pipes,RFL Bov,AGP MM's,CCA FMIC,JMB Intake,SBC Stage 5 ,750cc Inj.,Walbro 255,CTI o2 & TBE,AEM UEGO,Koyo Radiator,A/C Delete,MSD DIS-2,ED Crank Scraper & Windage Tray,Megan Racing C/O's, Lepoles Concepts Racing Built Head Full Race Ported Oversized Valves,5 Angle Valve Job, Crane Springs & Retainers,Ported Intake Manifold,Turbo & Exhaust Manifold.
lepolesconcepts is offline   Reply With Quote
Old 06-05-2008, 12:09 PM   #15 (permalink)
SRTforums Veteran²
Trader Rating: (43)
good to know but like i said im really looking for either a 7.5 or 8"
Page generated in 0.31332 seconds with 11 queries
