Go Back   SRT Forums - SRT4, SRT6, SRT8, SRT10 & Dodge Forum > Regional Forums 3 > Texas
Old 07-23-2008, 12:47 PM   #1 (permalink)
SRTGORDO's Avatar
Member Number: 45062
Trader Rating: (15)
Default need help ASAP
well im looking to see if u guys could help me out with this issue that has been messing with my head. ok here it goes
my friends srt is been jacking up turbos so bad, the first issue was that my friend was driing and all of a sudden the turbo went out, so ok screw it, i put another one in its place and it messed that one up too..so i put another one and same story, so this last time yesterday, we switched the manifold and put another trubo..and i intalled it and watched it idle and everything and it was fine..i took it for a test drive and in less than 10 min the turbo went out and started to have a nasty shaft play, so right now i took the turbo apart, and the shaft bearing looked burned and smelled like ugly burnt oil..
what could be casuing this problem, i was thinking the oil lines are clogged?? also the car had very dirty oil, like it hasnt been changed in a while
so help me out figuiring this thing out please
SRTGORDO is offline   Reply With Quote
Old 07-23-2008, 01:28 PM   #2 (permalink)
vicious118's Avatar
Member Number: 64316
Sounds like somehow oil isn't making it to the turbo. Now how the oil isn't making it there I don't know, could be a clog somewhere. How's the oil pressure?
vicious118 is offline   Reply With Quote
Old 07-23-2008, 03:22 PM   #3 (permalink)
CHANCEKIRKSEY's Avatar
Member Number: 55174
Yep, no lube sounds like the problem. Damn who has acess to that many turbos.
CHANCEKIRKSEY is offline   Reply With Quote
Old 07-23-2008, 03:30 PM   #4 (permalink)
Member Number: 31283
exactly what i was thinking
black03 is offline   Reply With Quote
Old 07-23-2008, 04:23 PM   #5 (permalink)
dynamic duo's Avatar
Member Number: 43240
Yup no oil is going to the turbo. Mine did the same check all the oil lines and the lil holes
that feed the turbo. Make sure it does not have any burnt oil in the lines and holes.
Emilio0o0...
Yo Mama Smokes Crack.
dynamic duo is offline   Reply With Quote
Old 07-23-2008, 05:59 PM   #6 (permalink)
cano's Avatar
Member Number: 2373
Dammmm, dat sucks.
Def. a lubrication problem.
12.827 @ 108.66 2/10/08 - 12.827 @ 109.23 2/10/08 - 13.01 @ 109.5 1/21/08
Stage 1, dTec FC, AGP Wategate, 3" HP Racing turboback, Filled Motor Mounts, Spearco FMIC, Fuel Return Kit. BFG DR's on Rota Slipstreams
cano is offline   Reply With Quote
Old 07-23-2008, 06:02 PM   #7 (permalink)
RUSH@TKMotorsports's Avatar
Member Number: 18925
Trader Rating: (139)
x2. Don't just check the line but check the fitting that comes out the back side of the engine. It might be clogged from the engine side
TK Motorsports "Building Horsepower Dreams"
**RIP Tim Kim**
Tele: 706-288-9203
Website: WWW.TKMOTORSPORT.COM
2005 SRT-4 (603whp race gas at 28 psi/535whp pump gas at 22 psi). No spray!!!
2008 Lexus IS350 (stock)
2006 Ram SRT-10 Reg Cab (for sale: $25,000 firm; 22k miles).
RUSH@TKMotorsports is offline   Reply With Quote
Old 07-23-2008, 08:42 PM   #8 (permalink)
Netou's Avatar
Member Number: 29372
Trader Rating: (59)
I can't believe no1 has mentioned this....
But, check the oil lines...they might be clogged.
Netou is online now   Reply With Quote
Old 07-24-2008, 04:44 PM   #9 (permalink)
BluFlame's Avatar
Member Number: 8399
Trader Rating: (17)
Yeah check the oil lines. You can also take the pressure line off the turbo and remove the coil wire harness and have hime turn it over to see if oil shoots out.
ZHP Built & Tuned
BluFlame is online now   Reply With Quote
Old 07-24-2008, 05:47 PM   #10 (permalink)
Crazy1's Avatar
Member Number: 56868
NO lube bro! check the lines, gotta be a leak or clog!
Crazy1 is online now   Reply With Quote
Old 07-25-2008, 12:35 AM   #11 (permalink)
99camaro's Avatar
Member Number: 39085
Trader Rating: (44)
Check the lines, they may be clogged.
99camaro is offline   Reply With Quote
Old 07-25-2008, 12:28 PM   #12 (permalink)
Crazy1's Avatar
yup has to be that^^ we've all said the same.
Old 07-25-2008, 12:30 PM   #13 (permalink)
Member Number: 63276
Definitely clogged lines.
Check them.
SunshineUnderground is offline   Reply With Quote
Old 07-25-2008, 12:32 PM   #14 (permalink)
SRTGORDO's Avatar
Trader Rating: (15)
THANKS GUYS it was the oil line
Old 07-25-2008, 12:34 PM   #15 (permalink)
Crazy1's Avatar
good you found the problem, yo you know anyone selling a ported I-mani?
Page generated in 0.26308 seconds with 11 queries
