Quote: Originally Posted by
kup@l
scan gauge for?
monitoring knock? and...
# RPM
# MPH
# Intake Air Temperature (post Intercooler)
# Ambient Air Temperature (pre Intercooler)
# Engine Coolant Temperature
# Exhaust Gas Temperature
# Transmission Temp. (auto trans)
# Fuel Temperature
# Battery Voltage
# Battery Temp
# Injector Pulse Width in msec.
# Injector Duty Cycle (%)
# Air Flow Rate into engine
# Long Term Fuel Trim
# Short Term Fuel Trim
# O2 Sensor Voltage
# Barometric Pressure
# Manifold Pressure (vacuum/boost) displayed in PSI
# Ignition Advance
# Base Spark
# PCM Spark Adjust
# Fuel Status (open/closed loop)
# Wastegate Solenoid Duty Cycle (%)
# Knock Retard
# Knock Sensor Raw Voltage
# Throttle Position Percentage
# Throttle Position Sensor Raw Volts
# Fuel economy (instantaneous and average)
# Calculated Net Horsepower
# Engine Load
# Misfire screen showing individual cylinders
# P-Ratio - pressure ratio MAP/Barometer
# 2 user configurable analog inputs**
# High and Low speed fan control
