Go Back   SRT Forums - SRT4, SRT6, SRT8, SRT10 & Dodge Forum > Regional Forums > Regional Forums 3 > Texas
Old 05-16-2008, 03:07 PM   #1 (permalink)
Member Number: 60882
Default Maintaining Boost when Shifting?
Maybe it's because I'm a bad driver, but lets say I'm in first and floor it, and then when I shift into 2nd it seems like I lose a lot of power and start 2nd gear at 5-6 psi and rising. When I was in my friend netou's car it seemed like he held boost even while shifting? Is there somethign I'm doing wrong or a technique to maintain the boost after shifting?
korean_evan is offline   Reply With Quote
Old 05-16-2008, 03:35 PM   #2 (permalink)
RoosterDougan's Avatar
Member Number: 51924
WOT BABY........ I do know with the stages 2 and 3 you can hold boost while shifting wide open, but you are going to lose boost while shifting because the bov is removing the backpressure from the turbo. when you lose your boost the componets of the turbo are doing its job. but with the staged psm you can hold it if you can shift fast enough. is that right guys
MODs: 500 hp Modern Performance sticker lol.
CAR IS UNDER CONSTRUCTION
RoosterDougan is offline   Reply With Quote
Old 05-16-2008, 04:16 PM   #3 (permalink)
rollwitstyle's Avatar
Member Number: 60104
^^ fail lol, you need a wot box to do wot shifts, if you shift right you shouldn't lose that much boost.
agp solid motor mounts and trans mount, agp cold air intake, forge blow off valve,s2 wga, msd wires, mopar exhaust, atp 3inch down pipe, real tune 3inch o2 housing, wot box with 2 step.
wideband for my map clamp coming soon
rollwitstyle is offline   Reply With Quote
Old 05-16-2008, 04:24 PM   #4 (permalink)
srt4760's Avatar
Member Number: 61489
try getting a stage 2 wga...it will help u to hold boost..
even at high rpms...
srt4760 is offline   Reply With Quote
Old 05-16-2008, 05:13 PM   #5 (permalink)
CHANCEKIRKSEY's Avatar
Member Number: 55174
Correct except that Netou does not have a staged pcm he has stock. He is just that good. You cannot compare ur driving to Netous.
But yea its called
WideOpenThrottle Shifting a.k.a. Power Shifting.
CHANCEKIRKSEY is offline   Reply With Quote
Old 05-16-2008, 05:25 PM   #6 (permalink)
Josh@SNLPerformance's Avatar
Member Number: 36295
Trader Rating: (15)
You do not need a WOT box at all. You can either WOT shift or just practice shifting. If you shift fast enough it will hold boost.
Its just a V6 with an exhaust and vacuum leak
Josh@SNLPerformance is offline   Reply With Quote
Old 05-16-2008, 05:36 PM   #7 (permalink)
thanks guys!
Old 05-16-2008, 05:55 PM   #8 (permalink)
Netou's Avatar
Member Number: 29372
Trader Rating: (61)
Oh my fukin god...!
Do not listen to the noobs on top, please!
In order for you not to loose boost when shifting, you WOT(wide open throttle) Shift. You hold the gas pedal to the floor while you rapidly engage the clutch and shift as quickly as possible without repleasing the gas pedal. It takes pratice, but if done right...you can beat cars with 40+more hp by a car or more....right Kerr?! But, you run the risk of damaging your syncros if done incorrect. You do not need a "WOT BOX" or a staged pcm...what I do recommend is a WasteGate. The stock WGA is weak sauce.
Netou is offline   Reply With Quote
Old 05-16-2008, 06:37 PM   #9 (permalink)
^^ No you fail, and I've read nothing that deserves a lol.
True if you shift right you won't lose much, but why do that when you can WOT and keep all the boost and lose maybe a couple psi and not ALL.
Stage 2/3 pcm(I don't remember if stage 1 is or not) ARE caliabrated for WOT SHIFTING.
Try reading up on ur car it says it somewhere on this website I would link it but I'm on my phone... Mopar - Original Equipment Parts and Accessories <-- check it out MR.Failure now roll wit that.
Yes a WOT box will be safier and help you with WOT but you don't need it. You can get some balls and skills and save ur money.
But the WOT is great insurance. Needed for some laughed at by others
Old 05-16-2008, 07:44 PM   #10 (permalink)
Quote: Originally Posted by Netou View Post
Oh my fukin god...!
Noob my ass Netou. I'm no Noob above and neither is Mr. SNL. So watch out b4 u speak sometime.
Old 05-16-2008, 07:52 PM   #11 (permalink)
Netou's Avatar
Trader Rating: (61)
I was talking about the first posters (rollstyle and 4560)...not you and definetly not not Mr SNL.
Think of the obvious before you speak.
Old 05-16-2008, 07:54 PM   #12 (permalink)
IKanKerr's Avatar
Member Number: 39266
Trader Rating: (29)
Oh my fukin god...!
no lie but when carlos wot shifted mine we beat u by a car and now i can wot too so
Powered By AGP
ZHP Built
Tuned on AGP SCT
Canon Rebel XSi
www.rowboatproductions.net
IKanKerr is offline   Reply With Quote
Old 05-16-2008, 07:57 PM   #13 (permalink)
Netou's Avatar
Trader Rating: (61)
Carlos never beat me when he drove your car...we were dead even and you were never ahead. I even pulled Carlos 2+ cars from a dig.
All in video kerr...
Old 05-16-2008, 07:59 PM   #14 (permalink)
IKanKerr's Avatar
Trader Rating: (29)
ok ok i guess ur i couldnt hear the horn excuse will work this time but WOT shifting makes a GIANT difference
Old 05-16-2008, 08:05 PM   #15 (permalink)
Netou's Avatar
Trader Rating: (61)
Excuse?! U can ask 99Camaro...he was in the passenger seat with me and closest to ur car's horn and he couldnt even hear it.
U cant really hear much of anything when 2 cars are break boostin...specialy with both of them having an open downpipe.
