Go Back   SRT Forums - SRT4, SRT6, SRT8, SRT10 & Dodge Forum > Regional Forums 3 > Texas
Old 06-26-2008, 12:42 PM   #1 (permalink)
Member Number: 60231
Default e1 turbo ????
with the e1 are you forced to use a aftermarket wastegate??? i just put mine on and its seems to bleed off around 10psi?? there is no shaft play and all the correct vac. lines are hooked up . please let me know if you think it could be because of the wastegate???
rsswhitlightning is offline   Reply With Quote
Old 06-26-2008, 01:36 PM   #2 (permalink)
Netou's Avatar
Member Number: 29372
Trader Rating: (58)
R u on the stock Wga?!
Netou is online now   Reply With Quote
Old 06-26-2008, 03:38 PM   #3 (permalink)
yes im waiting on the new wastegate so i put the stock one back on i just want to make sure that is the problem
Old 06-26-2008, 03:40 PM   #4 (permalink)
Netou's Avatar
Trader Rating: (58)
Im 80% sure that is the problem.
Just dont mess with anything on the car until you get your new wga. Remember that you will have to re-wire the boost selenoid lines soo the wga can control the boost and not the pcm.
What type of wga did u get?
Old 06-26-2008, 04:08 PM   #5 (permalink)
scottw03's Avatar
Member Number: 23435
Trader Rating: (33)
Stock wastegate only has a 4lb spring in it.
scottw03 is offline   Reply With Quote
Old 06-26-2008, 11:30 PM   #6 (permalink)
IKanKerr's Avatar
Member Number: 39266
Trader Rating: (28)
check for leaks the charge pipe will probly be where the leak will be
Powered By AGP
ZHP Built
Tuned on AGP SCT
Canon Rebel XSi
IKanKerr is online now   Reply With Quote
Old 06-26-2008, 11:53 PM   #7 (permalink)
Josh@SNLPerformance's Avatar
Member Number: 36295
Trader Rating: (15)
If you are running the stock lines then that will cause it to run lower. The computer is seeing more air and it is compensating for that.
Its just a V6 with an exhaust and vacuum leak
Josh@SNLPerformance is offline   Reply With Quote
Old 06-26-2008, 11:57 PM   #8 (permalink)
scottw03's Avatar
Trader Rating: (33)
Stupid question, but how does the computer see more air? We don't have a MAF? all it knows is how much pressure it is seeing. So how much boost you are getting.
I would assume that the computer can not tell the difference between a 50 trim flowing 15 psi and a stock turbo flowing 15 psi. 15 psi is 15 psi.
Now if we had a MAF sensor then I could see the computer reading how much air is flowing.
Old 06-27-2008, 12:06 AM   #9 (permalink)
IKanKerr's Avatar
Trader Rating: (28)
i agree
Old 06-27-2008, 08:17 AM   #10 (permalink)
Trader Rating: (15)
I cant find the link that explains this.
Old 06-27-2008, 11:51 AM   #11 (permalink)
scottw03's Avatar
Trader Rating: (33)
If there is a good explaination on the forums on this, please let me know. I don't like being wrong and I do like learning new things.
But the part that I posted up above is my current understanding of how the car works and the PCM reads the sensors. If this is inaccurate or wrong, please let me know so I can improve my knowledge.
Old 06-27-2008, 02:49 PM   #12 (permalink)
Trader Rating: (15)
You are correct but if the car is sensoring more air than usual than it will lower the boost. That is part of the reason why it varies so much.
Old 06-28-2008, 12:46 AM   #13 (permalink)
scottw03's Avatar
Trader Rating: (33)
I think the only way the car can sense how much air is flowing would be based on calculations based on IAT, TIP, and MAP sensors. How cold is the air coming into the engine, how much boost is running, Boost x air temp = calculated airflow. That is the only way that the car can determine that with the air temp cooler the car will make more power due to more oxygen in it than when the air is hotter and the oxygen is less condensed.
Page generated in 0.28036 seconds with 11 queries
