Go Back   SRT Forums - SRT4, SRT6, SRT8, SRT10 & Dodge Forum > Regional Forums > Regional Forums 3 > Texas
Old 08-05-2008, 12:12 PM   #1 (permalink)
Member Number: 64771
Default Big turbo guys in the Texas heat ... questions for ya ....
Just wondering what, if anything, you big turbo/bolt ons guys with 400-500 whp do differently during the intense Tx summer heat ?
I mean, do you turn your boost down ? Or tune your AFRs differently ?
I'm concerned about running my 500whp, 50 trim car hard with any safety ( WOT ) when the temps are so crazy high outside.
bmpblue is offline   Reply With Quote
Old 08-05-2008, 12:16 PM   #2 (permalink)
IKanKerr's Avatar
Member Number: 39266
Trader Rating: (29)
do u have a wideband and a scanguage?
just normal driving you should be fine as long as your not racing during the 100 degree weather just monitor knock and your AFRs and you should be ok
Powered By AGP
ZHP Built
Tuned on AGP SCT
Canon Rebel XSi
www.rowboatproductions.net
IKanKerr is offline   Reply With Quote
Old 08-05-2008, 12:35 PM   #3 (permalink)
Yeah ... I have everything to make sure it's ok, but I've never owned a turbo car in this kind oh heat and humidity.
You say to not race the car in the high heat ... Does that mean that all big turbo SRT-4s in Texas race ONLY for the roughly 4 or so months when the weather is cooler ? That sucks if so !
Old 08-05-2008, 12:37 PM   #4 (permalink)
HCCAFan's Avatar
Member Number: 35768
Trader Rating: (19)
Humidity, in Texas?
HCCAFan is offline   Reply With Quote
Old 08-05-2008, 12:47 PM   #5 (permalink)
Josh@SNLPerformance's Avatar
Member Number: 36295
Trader Rating: (15)
It doesnt matter how hot it is. You are not going to make as much power but as long as your afr are right and there is no knock you should be ok.
Its just a V6 with an exhaust and vacuum leak
Josh@SNLPerformance is offline   Reply With Quote
Old 08-05-2008, 01:21 PM   #6 (permalink)
IKanKerr's Avatar
Trader Rating: (29)
thats what i ment just make sure the hot air isnt making you knock
Old 08-05-2008, 01:33 PM   #7 (permalink)
99camaro's Avatar
Member Number: 39085
Trader Rating: (44)
I never did anything... Just made sure my afrs were safe...
99camaro is offline   Reply With Quote
Old 08-05-2008, 02:55 PM   #8 (permalink)
1fastSRT's Avatar
Member Number: 11053
Trader Rating: (24)
you'll be fine
1fastSRT is offline   Reply With Quote
Old 08-05-2008, 04:17 PM   #9 (permalink)
Member Number: 63276
Quote: Originally Posted by HCCAFan View Post
Humidity, in Texas?
........I hope that's a joke.
You've never lived until you've stepped outside on a hot August day in Texas and literally breathed 110 water from the air.
SunshineUnderground is offline   Reply With Quote
Old 08-05-2008, 05:04 PM   #10 (permalink)
Member Number: 51243
isnt it great tho???
I LOVE TEXAS!!!!!!!
4banginTURBO is offline   Reply With Quote
Old 08-05-2008, 09:31 PM   #11 (permalink)
BluFlame's Avatar
Member Number: 8399
Trader Rating: (17)
Turn your boost down during the heat of the day. If you have a 50 trim making 500hp, you are maxing that turbo out and are on the edge of it's efficiency range. Everytime you hit boost you will make heat inless you have some kinda h20/alky injection or something. What are you using to tune? If it's the SAFC be careful and definately keep the boost down during the heat of the day. Also invest in a 180 degree stat and the fan mod. Does wonders while cruising and while stuck in traffic.
ZHP Built & Tuned
BluFlame is offline   Reply With Quote
Old 08-05-2008, 11:01 PM   #12 (permalink)
IKanKerr's Avatar
Trader Rating: (29)
Old 08-06-2008, 12:26 PM   #13 (permalink)
mightyxwhitey53's Avatar
Member Number: 30679
im running the AEM EMS and have been tuning for the heat...the Water/Meth injection ive got helps a lot...im sure you will be fine as long as you tune for the heat on your SAFC.
mightyxwhitey53 is offline   Reply With Quote
Old 08-06-2008, 05:23 PM   #14 (permalink)
BluFlame's Avatar
Member Number: 8399
Trader Rating: (17)
The "o2 feedback" should keep your car safe no matter the weather. Adjust your "o2 FB" chart to the a/f's you want and then turn the feedback on. It will keep you car at that airfuel no matter what. Having h20/alky injection works great with this also
Old 08-06-2008, 06:31 PM   #15 (permalink)
bitts's Avatar
Member Number: 29842
Trader Rating: (66)
First do go wot in the stupid hot heat, or just wait till the
evening to hit the go button.
Second get a DD if ur that concerned
Third w/m injection will do ur motor wonders.
Ur welcome
Powered by AGP3147 414/489 My timing is retarded
bitts is offline   Reply With Quote
» Sponsor Links
»Garage Storage and Cabinets
