Go Back   SRT Forums - SRT4, SRT6, SRT8, SRT10 & Dodge Forum > Chrysler/Dodge Garage > Chrysler Vehicles > Turbo PT/GT Cruiser Discussion
Old 02-21-2004, 01:30 PM   #1 (permalink)
dfunkdj's Avatar
Member Number: 8230
Question Boost Controlers
Hey All,
I am looking into buying a after market boost controler. I am not shure if I should get a electronic one or a manul one. Does anyone have one and which is the best to get ??
Don
Tampabay Pt cruisers
dfunkdj is offline   Reply With Quote
Old 02-21-2004, 02:34 PM   #2 (permalink)
djgainsbond's Avatar
Member Number: 962
Trader Rating: (78)
if ur looking for a manual i have one for 75 shipped its an hks brand new
EVEN A BROKEN CLOCK IS RIGHT TWICE A DAY
Quote: Originally Posted by noTe
You can use dish wash soap to wash a car.
Quote: Originally Posted by slow4dr
You can install your hot side pipe on my ass anytime.
www.myspace.com/djgainsbond Top Floor Ent.
djgainsbond is offline   Reply With Quote
Old 02-23-2004, 12:13 AM   #3 (permalink)
White Heat's Avatar
Member Number: 512
Trader Rating: (10)
Quote: Originally Posted by dfunkdj
Hey All,
Don
Having Stage 1 a boost controller won't work. You boost too high and the Stage 1 pcm will retard the timing and shut you down. You can have either a boost controller or a Stage 1 but not both together.
'05 Stone White SRT 4
Mods - Yes
Web Page
http://qt.ptenthusiasts.net/
White Heat is offline   Reply With Quote
Old 02-23-2004, 12:37 AM   #4 (permalink)
SRToc Member
alpine's Avatar
Member Number: 5844
Any truth to this? I haven't heard of that before... If so, it's
alpine is offline   Reply With Quote
Old 02-24-2004, 12:38 AM   #5 (permalink)
White Heat's Avatar
Member Number: 512
Trader Rating: (10)
Actually, a guy on PT Cruiser Links wrote this about using S1 and a bc> First time I heard anyone say it will work:
"yes, you can. to get the best results and easiest set-up, you'll want to bypass that WGA solenoid..
Your BC will need a pressure source. there's a black line for the TIP sensor (which isn't used anyways with S1) that connects right in front of the TB. Either tee into that line, or pull it and use the now available nipple.
Next, you'll need to run a line from BC to your WGA. There's a brown line that connects to the WGA. pull it off and cap. Run your new line from the BC to the nipple where the brown line was attached to. The PCM now has no control over your boost, and you're using "clean" lines for pressure, etc.
There's numerous people out there getting over 300, 400,and even 500 hp out of these motors (and PCM), with the only electonic trickerey needed being at the MAP sensor - but unless you're looking to ge over 18psi you should be fine."
Old 02-24-2004, 02:04 PM   #6 (permalink)
dfunkdj's Avatar
Member Number: 8230
Default boost controlers
Is this for a electronic controler or a Manual boost controler ???
Don
Old 02-25-2004, 12:27 AM   #7 (permalink)
White Heat's Avatar
Member Number: 512
Trader Rating: (10)
Don
Don't know but my guess would be he was talking about a manual bc. Most people have the manual bc because it is cheaper.
Old 04-30-2005, 10:27 AM   #8 (permalink)
Srt4black's Avatar
Member Number: 14743
Is this true?? i was just doing some research on this topic first i heard of this.. is any body out there willing to give some basics for the Electronic boost controllerand the MBC ?? that would be helpful here.. like are they hard to install and tune .. what are some basic settings.
Mopar Short throw shifter, w/grant shift knob, Mopar Blow off valve, Dogbone MM's, Atp 3'' downpipe w/hi flow cat, and it also has custom 3'' exhaust from the cat back, Nitrous Express intercooler kit, stage 1, a bad ass Panasonic head unit, and 5% tint Halogen lights, clear corners.
Srt4black is offline   Reply With Quote
Old 05-01-2005, 08:28 PM   #9 (permalink)
SuGamer's Avatar
Member Number: 23340
Talking
Hey All,
Don
It can be done easily. I have a Hallman Pro RX MBC. Don look at the solinoids on the passenger side strut tower. Unplug the creme colored vac line. now plug it in to the back end of the boost controller. Take a line from the side of the BC and plug it into were the creme colored line was in the solinoid. Turn the MBC all the way to it's most open postion, and make one rotation. Drive and adjust. Keep doing it until you get it right. If you want to go beyond 15psi, you can easily do it but you need to install a map clamp first so the PCM doesn't pull timing.
Right now I'm spiking at 16psi, and holding all the way to redline at 12psi whereas I used to spike at 13psi and it would fall slowly to 8-9psi by redline.
SuGamer is offline   Reply With Quote
Old 05-01-2005, 09:16 PM   #10 (permalink)
Member Number: 27278
not true.
rjaylo is offline   Reply With Quote
Old 05-07-2005, 12:20 AM   #11 (permalink)
White Heat's Avatar
Member Number: 512
Trader Rating: (10)
Quote: Originally Posted by rjaylo
not true.
You are right. I now have a 2 stage bc with my stage 1.
Old 05-31-2005, 09:28 AM   #12 (permalink)
GTPT05's Avatar
Member Number: 28974
Nice PT
GTPT05 is offline   Reply With Quote
Old 05-31-2005, 05:41 PM   #13 (permalink)
weve got the needswings bc in our GT. Its the bleed type, but I would honestly like to try a ball and spring just to see the difference.
Old 06-05-2005, 10:24 PM   #14 (permalink)
Member Number: 17068
I've got the same Hallman Pro RX (ceramic ball & spring) as SuGamer, it's even hooked up the same way. I'm spiking at about 17psi and holding 13~14 to redline in 3rd (a bit lower in 2nd - automatic tranny). No part throttle boost problems either. Keep in mind that if you don't make use of a MAP clamp and hold over 15psi the PCM will pull timing and you won't gain much of anything.
Mike-in-Orange is offline   Reply With Quote
Old 06-09-2005, 06:46 AM   #15 (permalink)
SuGamer's Avatar
Way to go Mike! I got mine set about the same now also. I'm spiking at between 17 and 18psi and holding at almost 15psi. Well trying to, it slowly droops further down until about 12-13psi at redline. An upgraded WGA should fix that soon, but I may have to clamp the MAP.
Page generated in 0.24218 seconds with 11 queries
