Old 05-14-2009, 02:42 PM   #1 (permalink)
darksrknight's Avatar
Member Number: 60192
Default ZKW lense swap for Hella E-55 projectors
How should I approach doing this? I have never really done a retro before and all I really want to do is swap out the fresnel (spelling?) lenses for some clear ZKW ones. Link: The Retrofit Source (U.S.) - HID Projector Retrofit Kits, Retrofit and HID Componenents, Projectors Lens, Wiring Harnesses, Shrouds and more!
Any and all help is appreciated, since I am just modifying a retrofit I purchased from BoostLee. (Maybe Boost could chime in?)
Thanks Guys ,
-Dave
2005 SRT-4
darksrknight is online now   Reply With Quote
Old 05-14-2009, 03:36 PM   #2 (permalink)
aww sheet's Avatar
Member Number: 20431
Trader Rating: (31)
those lens will work fine with e55's. are you asking how swap them out?
View Modifications
Old 05-14-2009, 03:59 PM   #3 (permalink)
Yessir!!! Have you ever done one?
Old 05-14-2009, 04:30 PM   #4 (permalink)
aww sheet's Avatar
Trader Rating: (31)
standard e55 projector
pry the metal flaps w/ screw driver
remove the metal ring
and there you go
reverse the order for assembly
Old 05-14-2009, 04:39 PM   #5 (permalink)
Thanks!!! Much appreciated!!!!!
Page generated in 0.15424 seconds with 13 queries
