11-02-2009, 04:35 PM
#1 (permalink )
Member Number: 34502
Would I see a improvement?
Right now Im running 6K HIDS. The light output is ok I suppose. I'm thinking of switching to 4300k. Will the difference be noticeable?
AGP D44 /DSP /Coolingmist Meth Addict
Tuned By TDSAaron!!
My Goal: 100+Mph in the 1/8
11-02-2009, 04:38 PM
#2 (permalink )
Member Number: 70605
4300 has the highest light output to my knowledge, so yes you should be able to see an increase in distance.
11-02-2009, 04:39 PM
#3 (permalink )
Member Number: 16491
Yes, everything wont be so bluish (Im running 6k HIDs now).
keep your signature safe for work
edited by peteblksrt4
11-02-2009, 04:41 PM
#4 (permalink )
Yea. its VERY blue. Im sure I can just buy the replacement H1 bulbs correct. And plug them into the ballast since I already have the adapter and all.
Also where can I get a good set of bulbs at?
11-02-2009, 04:45 PM
#5 (permalink )
Yep, just the bulb will do it.
11-02-2009, 04:49 PM
#6 (permalink )
Member Number: 9691
Quote: Originally Posted by
Kason23
Im running 6K headlights & 4500K fogs & the only difference i can see is the color.........light output appears about the same.
_____5TOEZ______ 1967 Cadillac Calais 429 2dr., 1967 Chevelle 4sp. Conv. ,1978 Dodge 318 "Factory Custom"van., 2004 Dodge Srt-4,Stage1.5(E-Blue) & a couple motorcycles.
11-02-2009, 05:08 PM
#7 (permalink )
Member Number: 24279
fivetoez
If your fogs are as bright as your headlights , ...........that should tell you something about 6k vs 4.3k output .
All things being equal , your headlights should put out MUCH more light than your fogs .
_____
_____
11-02-2009, 06:50 PM
#8 (permalink )
Member Number: 20431
fivetoez
thats because the hids are not regulated by a casper shield or projector. so the beam is all over the place.
11-02-2009, 08:43 PM
#9 (permalink )
Well thanks guys I got got some replacement 4300k bulbs from hidoutlet.com.
11-03-2009, 07:35 AM
#10 (permalink )
Forum Moderator SRT of the Month
Member Number: 17636
4300k has more usable light and less "blue" tint to it than 6000k. You will notice a difference when you install them.
11-03-2009, 04:11 PM
#11 (permalink )
Member Number: 76002
hi
surely there will be differences
11-04-2009, 09:50 PM
#12 (permalink )
Premium Member (Lifetime) SRT of the Month
Member Number: 29842
I will be switching to 4.3k .
11-04-2009, 09:59 PM
#13 (permalink )
Member Number: 71493
so the 3ks are going to have more light output than the 4ks right? lower the temperature, the more usable lumens? correct me if im wrong, please
Full rebuild in progress
11-05-2009, 06:35 AM
#14 (permalink )
No I believe 4k-4.3k is the "most light" at least on the info I recieved.
Also I have looked around. What is the cheapest retrofit for a modern performance halo headlight. I want cheap,easy to install and "better" light output then these damn halo ones.
11-05-2009, 09:31 AM
#15 (permalink )
3k is yellow light and will not have more output than the 4300k. 4300k closely mimics the output of the sun, light wise, which is why it is deemed to have the most usable light.
Linear Mode
» Site Navigation
> Other Vehicles
» Buyers Guide
» Network Links
